[petsc-users] Would Mac OS version affect PETSc/C/C++ performance?
Junchao Zhang
junchao.zhang at gmail.com
Thu Aug 22 09:28:20 CDT 2024
Hi, Ling,
MatMult almost degraded 20%, which is a lot. Do you have configure.log
for the two builds? We might find compiler discrepancies from it.
--Junchao Zhang
On Wed, Aug 21, 2024 at 8:57 AM Zou, Ling <lzou at anl.gov> wrote:
> Hi Junchao,
> Yeah, I have part of the log_view, for the same code, same version of
> PETSc (3.20), but two OS (Ventura vs. Sonoma).
> Note that PETSc function call numbers are exactly the same.
> I suspect that it’s just OS becomes slower, or maybe something related to
> the compiler.
> -Ling
> # of calls
> Time spent (Ventura)
> Time spent (Sonoma)
> MatMult MF
> 20463
> 3.718600E+00
> 4.467800E+00
> MatMult
> 20463
> 3.721000E+00
> 4.470500E+00
> MatFDColorApply
> 2062
> 4.507000E+00
> 5.394600E+00
> MatFDColorFunc
> 24744
> 4.472400E+00
> 5.356300E+00
> KSPSolve
> 2062
> 3.569700E+00
> 4.262400E+00
> SNESSolve
> 986
> 9.195900E+00
> 1.102000E+01
> SNESFunctionEval
> 23575
> 4.268600E+00
> 5.161100E+00
> SNESJacobianEval
> 2062
> 4.509300E+00
> 5.397500E+00
> *From: *Junchao Zhang <junchao.zhang at gmail.com>
> *Date: *Monday, August 19, 2024 at 10:04 PM
> *To: *Zou, Ling <lzou at anl.gov>
> *Cc: *petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject: *Re: [petsc-users] Would Mac OS version affect PETSc/C/C++
> performance?
> Do you have -log_view report so that we can know which petsc functions
> degraded? Or is it because compilers were different? --Junchao Zhang On
> Sun, Aug 18, 2024 at 6: 04 PM Zou, Ling via petsc-users <petsc-users@ mcs.
> anl. gov> wrote: Hi
> ZjQcmQRYFpfptBannerStart
> *This Message Is From an External Sender *
> This message came from outside your organization.
> ZjQcmQRYFpfptBannerEnd
> --Junchao Zhang
> On Sun, Aug 18, 2024 at 6:04 PM Zou, Ling via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hi all,
> After updating Mac OS from Ventura to Sonoma, I am seeing my PETSc code
> having slightly-larger-than 10% of performance degradation (only in terms
> of execution time).
> I track the number of major function calls, they are identical between the
> two OS (so PETSc is not the one to blame), but just slower.
> Is this something expected, any one also experienced it?
> -Ling
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240822/06e6583b/attachment.html>
