[petsc-users] Error during code compile with MATGETOWNERSHIPRANGE
TAY Wee Beng
zonexo at gmail.com
Thu Aug 22 08:45:45 CDT 2024
Hi Barry,
Do you mean that I change from:
call
MatSetValues(A_mat_uv,ione,II,ione,int_impl(k,5),impl_mat_A,INSERT_VALUES,ierr)
to
call
MatSetValues(A_mat_uv,[ione],II,[ione],[int_impl(k,5)],impl_mat_A,INSERT_VALUES,ierr)
I did it but the error is still there.
On 22/8/2024 9:40 pm, Barry Smith wrote:
> Fortran 90 type checking is very tight; The dimension of the array,
> or scalar passed as arguments must match the expected dimension (f77
> did not do this type checking). Thus the ione argument must be a 1-d
> array as well as the numerical values so do
>> */call
>> MatSetValues(A_mat_uv,[ione],II,[ione],[int_impl(k,5)],impl_mat_A,INSERT_VALUES,ierr)/*
> See Fortran at https://urldefense.us/v3/__https://petsc.org/main/changes/dev/__;!!G_uCfscf7eWS!YtzPtW9XslKdNpPZd4zGIwtB0bpm5C24PUmAaH-renGV54WI9JpWuh7yYG-oSS4g9_KOnSqCEFPSwHcba_c$
> I am trying to support the old-fashion F77 model, allowing
> miss-matches in the array dimensions while still doing proper type
> checking but it will take some time to simplify the API.
> Barry
>> On Aug 21, 2024, at 9:44 PM, TAY Wee Beng <zonexo at gmail.com> wrote:
>> Hi Barry,
>> I have declared them as integers in Fortran. Is that different from
>> PetscInt and how come it works in debug mode?
>> Anyway, I changed them and it solved the problem. However, I have a
>> similar problem in my boundary.F90:
>> */boundary.F90(6685): error #6285: There is no matching specific
>> subroutine for this generic subroutine call. [MATSETVALUES]
>> call
>> MatSetValues(A_mat_uv,ione,II,ione,int_impl(k,5),impl_mat_A,INSERT_VALUES,ierr)/*
>> I changed all to PetscInt and also PetscReal but I still got the error.
>> Why is this so now? Any solution?
>> Thanks!
>> On 22/8/2024 12:03 am, Barry Smith wrote:
>>> You must declare as
>>> */ PetscInt ksta_p,kend_p/*
>>> Perhaps they are declared as arrays?
>>>> On Aug 21, 2024, at 11:19 AM, TAY Wee Beng <zonexo at gmail.com> wrote:
>>>> Hi,
>>>> I am using the latest PETSc thru github. I compiled both the debug
>>>> and rel ver of PETSc w/o problem.
>>>> I then use it with my CFD code and the debug ver works.
>>>> However, I have problems with the rel ver:
>>>> */ftn -o global.o -c -O3 -g -ip -ipo -fPIC -save -w
>>>> -I/home/project/11003851/lib/petsc_210824_intel_rel/include global.F90
>>>> ifort: remark #10448: Intel(R) Fortran Compiler Classic (ifort) is
>>>> now deprecated and will be discontinued late 2024. Intel recommends
>>>> that customers transition now to using the LLVM-based Intel(R)
>>>> Fortran Compiler (ifx) for continued Windows* and Linux* support,
>>>> new language support, new language features, and optimizations. Use
>>>> '-diag-disable=10448' to disable this message.
>>>> global.F90(444): error #6285: There is no matching specific
>>>> subroutine for this generic subroutine call. [MATGETOWNERSHIPRANGE]
>>>> call MatGetOwnershipRange(A_mat,ksta_p,kend_p,ierr)
>>>> global.F90(720): error #6285: There is no matching specific
>>>> call MatGetOwnershipRange(A_mat_uv,ksta_m,kend_m,ierr)
>>>> global.F90(774): error #6285: There is no matching specific
>>>> call MatGetOwnershipRange(A_semi_x,ksta_mx,kend_mx,ierr)
>>>> global.F90(776): error #6285: There is no matching specific
>>>> call MatGetOwnershipRange(A_semi_y,ksta_my,kend_my,ierr)
>>>> global.F90(949): error #6285: There is no matching specific
>>>> global.F90(957): error #6285: There is no matching specific
>>>> compilation aborted for global.F90 (code 1)/*
>>>> May I know what's the problem?
>>>> Thank you very much.
>>>> Yours sincerely,
>>>> TAY Wee-Beng 郑伟明 (Zheng Weiming)
>> Yours sincerely,
Yours sincerely,
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240822/29c061e4/attachment-0001.html>
