[petsc-users] petscerror.h is potentially missing includes
meator
meator.dev at gmail.com
Wed Aug 21 13:15:59 CDT 2024
Hello. I have skimmed through PETSc's documentation to see whether PETSc
has any special policy for including header files, but I didn't find
anything, so I assume that standard C rules apply.
The problematic header file is <petscerror.h>. The following code
doesn't compile:
#include <petscerror.h>
int main() { return 0; }
It fails because <petscerror.h> expects `MPI_Comm` to be defined, but it
is (I assume) lacking appropriate includes which would define it. This
is unfortunate, because many linters targeting C/C++ sort header files
alphabetically. Since "petsc" is the common prefix for most PETSc header
files, `petscerror.h` was put first in my header list because it begins
with an "e".
I'm using PETSc version 3.21.3.
Thanks in advance
Type: application/pgp-keys
Desc: OpenPGP public key
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240821/cf58820f/attachment.bin>
Desc: OpenPGP digital signature
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240821/cf58820f/attachment.sig>
