[petsc-users] Strong scaling concerns for PCBDDC with Vector FEM
Matthew Knepley
knepley at gmail.com
Tue Aug 20 16:53:20 CDT 2024
On Tue, Aug 20, 2024 at 2:31 PM neil liu <liufield at gmail.com> wrote:
> Thanks a lot for this explanation, Matt. I will explore whether the matrix
> has the same size and spaisity.
I think it is much more likely that you just exhausted bandwidth on the
node.
Matt
> On Tue, Aug 20, 2024 at 1:45 PM Matthew Knepley <knepley at gmail.com> wrote:
>> On Tue, Aug 20, 2024 at 1:36 PM neil liu <liufield at gmail.com> wrote:
>>> Hi, Matt,
>>> I think the time listed here represents the maximum total time across
>>> different processors.
>>> Thanks a lot.
>>> 2 cpus
>>> 4 cpus 8 cpus
>>> Event Count Time (sec) Count
>>> Time (sec) Count Time (sec)
>>> Max Ratio Max Ratio Max
>>> Ratio Max Ratio Max Ratio Max Ratio
>>> VecMDot 530 1.0 7.8320e+01 1.0 530 1.0
>>> 4.3285e+01 1.1 530 1.0 3.0476e+01 1.1
>>> VecMAXPY 534 1.0 9.2954e+01 1.0 534 1.0
>>> 4.8378e+01 1.1 534 1.0 3.0798e+01 1.1
>>> MatMult 8055 1.0 2.4608e+02 1.0 8103 1.0
>>> 1.2663e+02 1.0 8367 1.0 8.2942e+01 1.1
>> For the number of calls listed.
>> 1) The number of MatMults goes up, so you should normalize for that, but
>> you still have about 1.6 speedup. However, this is
>> all multiplications. Are we sure they have the same size and sparsity?
>> 2) MAXPY is also 1.6
>> 3) MDot probably does not see the latency of one node, so again it is not
>> speeding up as you might want.
>> This looks like you are using a single node with 2, 4, and 8 procs. The
>> memory bandwidth is exhausted sometime before 8 procs
>> (maybe 6), so you cease to see speedup. You can check this by running
>> `make streams` on the node.
>> Thanks,
>> Matt
>>> On Tue, Aug 20, 2024 at 1:16 PM Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Tue, Aug 20, 2024 at 1:10 PM neil liu <liufield at gmail.com> wrote:
>>>>> Thanks a lot for your explanation, Stefano. Very helpful.
>>>>> Yes. I am using dmplex to read a tetrahdra mesh from gmsh. With
>>>>> parmetis, the scaling performance is improved a lot.
>>>>> I will read your paper about how to change the basis for Nedelec
>>>>> elements.
>>>>> cpu # time for 500 ksp steps (s) parallel efficiency
>>>>> 2 546
>>>>> 4 224 120%
>>>>> 8 170 80%
>>>>> This results are much better than previous attempt. Then I checked the
>>>>> time spent by several Petsc built-in functions for the ksp solver.
>>>>> Functions time(2 cpus) time(4 cpus) time(8 cpus)
>>>>> VecMDot 78.32 43.28 30.47
>>>>> VecMAXPY 92.95 48.37 30.798
>>>>> MatMult 246.08 126.63 82.94
>>>>> It seems from cpu 4 to cpu 8, the scaling is not as good as from cpu 2
>>>>> to cpu 4.
>>>>> Am I missing something?
>>>> Did you normalize by the number of calls?
>>>> Thanks,
>>>> Matt
>>>>> Thanks a lot,
>>>>> Xiaodong
>>>>> On Mon, Aug 19, 2024 at 4:15 AM Stefano Zampini <
>>>>> stefano.zampini at gmail.com> wrote:
>>>>>> It seems you are using DMPLEX to handle the mesh, correct?
>>>>>> If so, you should configure using --download-parmetis to have a
>>>>>> better domain decomposition since the default one just splits the cells in
>>>>>> chunks as they are ordered.
>>>>>> This results in a large number of primal dofs on average (191, from
>>>>>> the output of ksp_view)
>>>>>> Primal dofs : 176 204 191
>>>>>> that slows down the solver setup.
>>>>>> Again, you should not use approximate local solvers with BDDC unless
>>>>>> you know what you are doing.
>>>>>> The theory for approximate solvers for BDDC is small and only for SPD
>>>>>> problems.
>>>>>> Looking at the output of log_view, coarse problem setup (PCBDDCCSet),
>>>>>> and primal functions setup (PCBDDCCorr) costs 35 + 63 seconds, respectively.
>>>>>> Also, the 500 application of the GAMG preconditioner for the Neumann
>>>>>> solver (PCBDDCNeuS) takes 129 seconds out of the 400 seconds of the total
>>>>>> solve time.
>>>>>> PCBDDCTopo 1 1.0 3.1563e-01 1.0 1.11e+06 3.4 1.6e+03
>>>>>> 3.9e+04 3.8e+01 0 0 1 0 2 0 0 1 0 2 19
>>>>>> PCBDDCLKSP 2 1.0 2.0423e+00 1.7 9.31e+08 1.2 0.0e+00
>>>>>> 0.0e+00 2.0e+00 0 0 0 0 0 0 0 0 0 0 3378
>>>>>> PCBDDCLWor 1 1.0 3.9178e-02 13.4 0.00e+00 0.0 0.0e+00
>>>>>> 0.0e+00 1.0e+00 0 0 0 0 0 0 0 0 0 0 0
>>>>>> PCBDDCCorr 1 1.0 6.3981e+01 2.2 8.16e+10 1.6 0.0e+00
>>>>>> 0.0e+00 0.0e+00 11 11 0 0 0 11 11 0 0 0 8900
>>>>>> PCBDDCCSet 1 1.0 3.5453e+01 4564.9 1.06e+05 1.7 1.2e+03
>>>>>> 5.3e+03 5.0e+01 2 0 1 0 3 2 0 1 0 3 0
>>>>>> PCBDDCCKSP 1 1.0 6.3266e-01 1.3 0.00e+00 0.0 3.3e+02
>>>>>> 1.1e+02 2.2e+01 0 0 0 0 1 0 0 0 0 1 0
>>>>>> PCBDDCScal 1 1.0 6.8274e-03 1.3 1.11e+06 3.4 5.6e+01
>>>>>> 3.2e+05 0.0e+00 0 0 0 0 0 0 0 0 0 0 894
>>>>>> PCBDDCDirS 1000 1.0 6.0420e+00 3.5 6.64e+09 5.4 0.0e+00
>>>>>> 0.0e+00 0.0e+00 1 0 0 0 0 1 0 0 0 0 2995
>>>>>> PCBDDCNeuS 500 1.0 1.2901e+02 2.1 8.28e+10 1.2 0.0e+00
>>>>>> 0.0e+00 0.0e+00 22 12 0 0 0 22 12 0 0 0 4828
>>>>>> PCBDDCCoaS 500 1.0 5.8757e-01 1.8 1.09e+09 1.0 2.8e+04
>>>>>> 7.4e+02 5.0e+02 0 0 17 0 28 0 0 17 0 31 14901
>>>>>> Finally, if I look at the residual history, I see a sharp decrease
>>>>>> and a very long plateau. This indicates a bad coarse space; as I said
>>>>>> before, there's no hope of finding a suitable coarse space without first
>>>>>> changing the basis of the Nedelec elements, which is done automatically if
>>>>>> you prescribe the discrete gradient operator (see the paper I have linked
>>>>>> to in my previous communication).
>>>>>> Il giorno dom 18 ago 2024 alle ore 00:37 neil liu <liufield at gmail.com>
>>>>>> ha scritto:
>>>>>>> Hi, Stefano,
>>>>>>> Please see the attached for the information with 4 and 8 CPUs for
>>>>>>> the complex matrix.
>>>>>>> I am solving Maxwell equations (Attahced) using 2nd-order Nedelec
>>>>>>> elements (two dofs each edge, and two dofs each face).
>>>>>>> The computational domain consists of different mediums, e.g.,
>>>>>>> vacuum and substrate (different permitivity).
>>>>>>> The PML is used to truncate the computational domain, absorbing the
>>>>>>> outgoing wave and introducing complex numbers for the matrix.
>>>>>>> Thanks a lot for your suggestions. I will try MUMPS.
>>>>>>> For now, I just want to fiddle with Petsc's built-in features to
>>>>>>> know more about it.
>>>>>>> Yes. 5000 is larger. Smaller value. e.g., 30, converges very slowly.
>>>>>>> Thanks a lot.
>>>>>>> Have a good weekend.
>>>>>>> On Sat, Aug 17, 2024 at 9:23 AM Stefano Zampini <
>>>>>>>> Please include the output of -log_view -ksp_view -ksp_monitor to
>>>>>>>> understand what's happening.
>>>>>>>> Can you please share the equations you are solving so we can
>>>>>>>> provide suggestions on the solver configuration?
>>>>>>>> As I said, solving for Nedelec-type discretizations is challenging,
>>>>>>>> and not for off-the-shelf, black box solvers
>>>>>>>> Below are some comments:
>>>>>>>> - You use a redundant SVD approach for the coarse solve, which
>>>>>>>> can be inefficient if your coarse space grows. You can use a parallel
>>>>>>>> direct solver like MUMPS (reconfigure with --download-mumps and use
>>>>>>>> -pc_bddc_coarse_pc_type lu -pc_bddc_coarse_pc_factor_mat_solver_type mumps)
>>>>>>>> - Why use ILU for the Dirichlet problem and GAMG for the
>>>>>>>> Neumann problem? With 8 processes and 300K total dofs, you will have around
>>>>>>>> 40K dofs per process, which is ok for a direct solver like MUMPS
>>>>>>>> (-pc_bddc_dirichlet_pc_factor_mat_solver_type mumps, same for Neumann).
>>>>>>>> With Nedelec dofs and the sparsity pattern they induce, I believe you can
>>>>>>>> push to 80K dofs per process with good performance.
>>>>>>>> - Why 5000 of restart for GMRES? It is highly inefficient to
>>>>>>>> re-orthogonalize such a large set of vectors.
>>>>>>>> Il giorno ven 16 ago 2024 alle ore 00:04 neil liu <
>>>>>>>> liufield at gmail.com> ha scritto:
>>>>>>>>> Dear Petsc developers,
>>>>>>>>> Thanks for your previous help. Now, the PCBDDC can converge to
>>>>>>>>> 1e-8 with,
>>>>>>>>> petsc-3.21.1/petsc/arch-linux-c-opt/bin/mpirun -n 8 ./app -pc_type
>>>>>>>>> bddc -pc_bddc_coarse_redundant_pc_type svd -ksp_error_if_not_converged
>>>>>>>>> -mat_type is -ksp_monitor -ksp_rtol 1e-8 -ksp_gmres_restart 5000 -ksp_view
>>>>>>>>> -pc_bddc_use_local_mat_graph 0 -pc_bddc_dirichlet_pc_type ilu
>>>>>>>>> -pc_bddc_neumann_pc_type gamg -pc_bddc_neumann_pc_gamg_esteig_ksp_max_it 10
>>>>>>>>> -ksp_converged_reason -pc_bddc_neumann_approximate -ksp_max_it 500 -log_view
>>>>>>>>> Then I used 2 cases for strong scaling test. One case only
>>>>>>>>> involves real numbers (tetra #: 49,152; dof #: 324, 224 ) for matrix and
>>>>>>>>> rhs. The 2nd case involves complex numbers (tetra #: 95,336; dof #:
>>>>>>>>> 611,432) due to PML.
>>>>>>>>> Case 1:
>>>>>>>>> cpu # Time for 500 ksp steps (s) Parallel
>>>>>>>>> efficiency PCsetup time(s)
>>>>>>>>> 2 234.7
>>>>>>>>> 3.12
>>>>>>>>> 4 126.6
>>>>>>>>> 0.92 1.62
>>>>>>>>> 8 84.97
>>>>>>>>> 0.69 1.26
>>>>>>>>> However for Case 2,
>>>>>>>>> 2 584.5
>>>>>>>>> 8.61
>>>>>>>>> 4 376.8
>>>>>>>>> 0.77 6.56
>>>>>>>>> 8 459.6
>>>>>>>>> 0.31 66.47
>>>>>>>>> For these 2 cases, I checked the time for PCsetup as an example.
>>>>>>>>> It seems 8 cpus for case 2 used too much time on PCsetup.
>>>>>>>>> Do you have any ideas about what is going on here?
>>>>>>>>> Thanks,
>>>>>>>>> Xiaodong
>>>>>>>> Stefano
>>>>>> Stefano
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!c1-7PTlMFjRSGEtUBfqX0W9JQed5UTJTHCsmwhm4whuZoTMIll340dHxiKyGvIedaFLp4VcuBIrnBKMFP6GD$
>>>> <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!c1-7PTlMFjRSGEtUBfqX0W9JQed5UTJTHCsmwhm4whuZoTMIll340dHxiKyGvIedaFLp4VcuBIrnBMwGiak0$ >
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!c1-7PTlMFjRSGEtUBfqX0W9JQed5UTJTHCsmwhm4whuZoTMIll340dHxiKyGvIedaFLp4VcuBIrnBKMFP6GD$ <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!c1-7PTlMFjRSGEtUBfqX0W9JQed5UTJTHCsmwhm4whuZoTMIll340dHxiKyGvIedaFLp4VcuBIrnBMwGiak0$ >
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240820/f8909e1c/attachment-0001.html>
