[petsc-users] Strong scaling concerns for PCBDDC with Vector FEM
neil liu
liufield at gmail.com
Tue Aug 20 12:01:22 CDT 2024
Thanks a lot for your explanation, Stefano. Very helpful.
Yes. I am using dmplex to read a tetrahdra mesh from gmsh. With parmetis,
the scaling performance is improved a lot.
I will read your paper about how to change the basis for Nedelec elements.
cpu # time for 500 ksp steps (s) parallel efficiency
2 546
4 224 120%
8 170 80%
This results are much better than previous attempt. Then I checked the time
spent by several Petsc built-in functions for the ksp solver.
Functions time(2 cpus) time(4 cpus) time(8 cpus)
VecMDot 78.32 43.28 30.47
VecMAXPY 92.95 48.37 30.798
MatMult 246.08 126.63 82.94
It seems from cpu 4 to cpu 8, the scaling is not as good as from cpu 2 to
cpu 4.
Am I missing something?
Thanks a lot,
Xiaodong
On Mon, Aug 19, 2024 at 4:15 AM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> It seems you are using DMPLEX to handle the mesh, correct?
> If so, you should configure using --download-parmetis to have a better
> domain decomposition since the default one just splits the cells in chunks
> as they are ordered.
> This results in a large number of primal dofs on average (191, from the
> output of ksp_view)
> Primal dofs : 176 204 191
> that slows down the solver setup.
> Again, you should not use approximate local solvers with BDDC unless you
> know what you are doing.
> The theory for approximate solvers for BDDC is small and only for SPD
> problems.
> Looking at the output of log_view, coarse problem setup (PCBDDCCSet), and
> primal functions setup (PCBDDCCorr) costs 35 + 63 seconds, respectively.
> Also, the 500 application of the GAMG preconditioner for the Neumann
> solver (PCBDDCNeuS) takes 129 seconds out of the 400 seconds of the total
> solve time.
> PCBDDCTopo 1 1.0 3.1563e-01 1.0 1.11e+06 3.4 1.6e+03 3.9e+04
> 3.8e+01 0 0 1 0 2 0 0 1 0 2 19
> PCBDDCLKSP 2 1.0 2.0423e+00 1.7 9.31e+08 1.2 0.0e+00 0.0e+00
> 2.0e+00 0 0 0 0 0 0 0 0 0 0 3378
> PCBDDCLWor 1 1.0 3.9178e-02 13.4 0.00e+00 0.0 0.0e+00 0.0e+00
> 1.0e+00 0 0 0 0 0 0 0 0 0 0 0
> PCBDDCCorr 1 1.0 6.3981e+01 2.2 8.16e+10 1.6 0.0e+00 0.0e+00
> 0.0e+00 11 11 0 0 0 11 11 0 0 0 8900
> PCBDDCCSet 1 1.0 3.5453e+01 4564.9 1.06e+05 1.7 1.2e+03
> 5.3e+03 5.0e+01 2 0 1 0 3 2 0 1 0 3 0
> PCBDDCCKSP 1 1.0 6.3266e-01 1.3 0.00e+00 0.0 3.3e+02 1.1e+02
> 2.2e+01 0 0 0 0 1 0 0 0 0 1 0
> PCBDDCScal 1 1.0 6.8274e-03 1.3 1.11e+06 3.4 5.6e+01 3.2e+05
> 0.0e+00 0 0 0 0 0 0 0 0 0 0 894
> PCBDDCDirS 1000 1.0 6.0420e+00 3.5 6.64e+09 5.4 0.0e+00 0.0e+00
> 0.0e+00 1 0 0 0 0 1 0 0 0 0 2995
> PCBDDCNeuS 500 1.0 1.2901e+02 2.1 8.28e+10 1.2 0.0e+00 0.0e+00
> 0.0e+00 22 12 0 0 0 22 12 0 0 0 4828
> PCBDDCCoaS 500 1.0 5.8757e-01 1.8 1.09e+09 1.0 2.8e+04 7.4e+02
> 5.0e+02 0 0 17 0 28 0 0 17 0 31 14901
> Finally, if I look at the residual history, I see a sharp decrease and a
> very long plateau. This indicates a bad coarse space; as I said before,
> there's no hope of finding a suitable coarse space without first changing
> the basis of the Nedelec elements, which is done automatically if you
> prescribe the discrete gradient operator (see the paper I have linked to in
> my previous communication).
> Il giorno dom 18 ago 2024 alle ore 00:37 neil liu <liufield at gmail.com> ha
> scritto:
>> Hi, Stefano,
>> Please see the attached for the information with 4 and 8 CPUs for the
>> complex matrix.
>> I am solving Maxwell equations (Attahced) using 2nd-order Nedelec
>> elements (two dofs each edge, and two dofs each face).
>> The computational domain consists of different mediums, e.g., vacuum and
>> substrate (different permitivity).
>> The PML is used to truncate the computational domain, absorbing the
>> outgoing wave and introducing complex numbers for the matrix.
>> Thanks a lot for your suggestions. I will try MUMPS.
>> For now, I just want to fiddle with Petsc's built-in features to know
>> more about it.
>> Yes. 5000 is larger. Smaller value. e.g., 30, converges very slowly.
>> Thanks a lot.
>> Have a good weekend.
>> On Sat, Aug 17, 2024 at 9:23 AM Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>>> Please include the output of -log_view -ksp_view -ksp_monitor to
>>> understand what's happening.
>>> Can you please share the equations you are solving so we can provide
>>> suggestions on the solver configuration?
>>> As I said, solving for Nedelec-type discretizations is challenging, and
>>> not for off-the-shelf, black box solvers
>>> Below are some comments:
>>> - You use a redundant SVD approach for the coarse solve, which can
>>> be inefficient if your coarse space grows. You can use a parallel direct
>>> solver like MUMPS (reconfigure with --download-mumps and use
>>> -pc_bddc_coarse_pc_type lu -pc_bddc_coarse_pc_factor_mat_solver_type mumps)
>>> - Why use ILU for the Dirichlet problem and GAMG for the Neumann
>>> problem? With 8 processes and 300K total dofs, you will have around 40K
>>> dofs per process, which is ok for a direct solver like MUMPS
>>> (-pc_bddc_dirichlet_pc_factor_mat_solver_type mumps, same for Neumann).
>>> With Nedelec dofs and the sparsity pattern they induce, I believe you can
>>> push to 80K dofs per process with good performance.
>>> - Why 5000 of restart for GMRES? It is highly inefficient to
>>> re-orthogonalize such a large set of vectors.
>>> Il giorno ven 16 ago 2024 alle ore 00:04 neil liu <liufield at gmail.com>
>>> ha scritto:
>>>> Dear Petsc developers,
>>>> Thanks for your previous help. Now, the PCBDDC can converge to 1e-8
>>>> with,
>>>> petsc-3.21.1/petsc/arch-linux-c-opt/bin/mpirun -n 8 ./app -pc_type bddc
>>>> -pc_bddc_coarse_redundant_pc_type svd -ksp_error_if_not_converged
>>>> -mat_type is -ksp_monitor -ksp_rtol 1e-8 -ksp_gmres_restart 5000 -ksp_view
>>>> -pc_bddc_use_local_mat_graph 0 -pc_bddc_dirichlet_pc_type ilu
>>>> -pc_bddc_neumann_pc_type gamg -pc_bddc_neumann_pc_gamg_esteig_ksp_max_it 10
>>>> -ksp_converged_reason -pc_bddc_neumann_approximate -ksp_max_it 500 -log_view
>>>> Then I used 2 cases for strong scaling test. One case only involves
>>>> real numbers (tetra #: 49,152; dof #: 324, 224 ) for matrix and rhs. The
>>>> 2nd case involves complex numbers (tetra #: 95,336; dof #: 611,432) due
>>>> to PML.
>>>> Case 1:
>>>> cpu # Time for 500 ksp steps (s) Parallel efficiency
>>>> PCsetup time(s)
>>>> 2 234.7
>>>> 3.12
>>>> 4 126.6
>>>> 0.92 1.62
>>>> 8 84.97
>>>> 0.69 1.26
>>>> However for Case 2,
>>>> PCsetup time(s)
>>>> 2 584.5
>>>> 8.61
>>>> 4 376.8 0.77
>>>> 6.56
>>>> 8 459.6 0.31
>>>> 66.47
>>>> For these 2 cases, I checked the time for PCsetup as an example. It
>>>> seems 8 cpus for case 2 used too much time on PCsetup.
>>>> Do you have any ideas about what is going on here?
>>>> Thanks,
>>>> Xiaodong
>>> Stefano
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240820/bc85790d/attachment.html>
