[petsc-users] Question about the memory usage for BDDC preconditioner.
neil liu
liufield at gmail.com
Wed Aug 14 21:08:44 CDT 2024
Thanks a lot, Stefano.
Yes. I am using 2nd-order Nedelec elements. -pc_*bddc_use_lo*cal_mat_graph
0 can make the code run. I am testing more cpu #.
I am testing my code using,
petsc-3.21.1/petsc/arch-linux-c-opt/bin/mpirun -n 4 ./app -pc_type bddc
-pc_bddc_coarse_redundant_pc_type svd -pc_bddc_use_vertices
-ksp_error_if_not_converged -mat_type is -ksp_monitor -ksp_rtol 1e-8
-ksp_gmres_restart 2000 -ksp_view -malloc_view -pc_bddc_use_local_mat_graph
0 -ksp_converged_reason -pc_bddc_neumann_pc_type gamg
-pc_bddc_neumann_pc_gamg_esteig_ksp_max_it 10 -ksp_converged_reason
-pc_bddc_neumann_approximate -pc_bddc_dirichlet_pc_type gamg
-pc_bddc_dirichlet_pc_gamg_esteig_ksp_max_it 10 -ksp_converged_reason
-pc_bddc_dirichlet_approximate
The residual dropped to 6e-5 very fast and then continued to reduce very
slowly. Do you have any suggestions to improve this ?
Will it be necessary to change the basis for BDDC in order to
accelerate the convergence ? In addition, I tried
-pc_bddc_use_deluxe_scaling, but it showed some errors. It seems deluxe
scaling obviously requires a much larger size (*Global size overflow
3051678564*) than my problem.
Xiaodong
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Overflow in integer operation:
https://urldefense.us/v3/__https://petsc.org/release/faq/*64-bit-indices__;Iw!!G_uCfscf7eWS!ZVyzxJb4s9N1kzsS2BV7raG-kJIn8X6skBNtfsvA8aHyjWPm8oYGfzk83j1n0PFstGE6nDCHpOIpMvkLFZcexA$
[0]PETSC ERROR: Global size overflow 3051678564. You may consider
./configure PETSc with --with-64-bit-indices for the case you are running
[0]PETSC ERROR: WARNING! There are unused option(s) set! Could be the
program crashed before usage or a spelling mistake, etc!
[0]PETSC ERROR: Option left: name:-ksp_converged_reason (no value)
source: command line
[0]PETSC ERROR: Option left: name:-pc_bddc_coarse_redundant_pc_type
value: svd source: command line
name:-pc_bddc_neumann_pc_gamg_esteig_ksp_max_it value: 10 source: command
line
[0]PETSC ERROR: Option left: name:-pc_bddc_neumann_pc_type value: gamg
[0]PETSC ERROR: See https://urldefense.us/v3/__https://petsc.org/release/faq/__;!!G_uCfscf7eWS!ZVyzxJb4s9N1kzsS2BV7raG-kJIn8X6skBNtfsvA8aHyjWPm8oYGfzk83j1n0PFstGE6nDCHpOIpMvlAB6PtAg$ for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.21.1, unknown
[0]PETSC ERROR: Configure options --with-cc=gcc --with-fc=gfortran
--with-cxx=g++ --download-fblaslapack --download-mpich
--with-scalar-type=complex --download-triangle --with-debugging=no
[0]PETSC ERROR: #1 PetscSplitOwnership() at
/Documents/petsc-3.21.1/petsc/src/sys/utils/psplit.c:86
[0]PETSC ERROR: #2 PetscLayoutSetUp() at
/Documents/petsc-3.21.1/petsc/src/vec/is/utils/pmap.c:244
[0]PETSC ERROR: #3 PetscLayoutCreateFromSizes() at
/Documents/petsc-3.21.1/petsc/src/vec/is/utils/pmap.c:107
[0]PETSC ERROR: #4 ISGeneralSetIndices_General() at
/Documents/petsc-3.21.1/petsc/src/vec/is/is/impls/general/general.c:569
[0]PETSC ERROR: #5 ISGeneralSetIndices() at
/Documents/petsc-3.21.1/petsc/src/vec/is/is/impls/general/general.c:559
[0]PETSC ERROR: #6 ISCreateGeneral() at
/Documents/petsc-3.21.1/petsc/src/vec/is/is/impls/general/general.c:530
[0]PETSC ERROR: #7 ISRenumber() at
/Documents/petsc-3.21.1/petsc/src/vec/is/is/interface/index.c:198
[0]PETSC ERROR: #8 PCBDDCSubSchursSetUp() at
/Documents/petsc-3.21.1/petsc/src/ksp/pc/impls/bddc/bddcschurs.c:646
[0]PETSC ERROR: #9 PCBDDCSetUpSubSchurs() at
/Documents/petsc-3.21.1/petsc/src/ksp/pc/impls/bddc/bddcprivate.c:9348
[0]PETSC ERROR: #10 PCSetUp_BDDC() at
/Documents/petsc-3.21.1/petsc/src/ksp/pc/impls/bddc/bddc.c:1564
[0]PETSC ERROR: #11 PCSetUp() at
/Documents/petsc-3.21.1/petsc/src/ksp/pc/interface/precon.c:1079
[0]PETSC ERROR: #12 KSPSetUp() at
/Documents/petsc-3.21.1/petsc/src/ksp/ksp/interface/itfunc.c:415
[0]PETSC ERROR: #13 KSPSolve_Private() at
Documents/petsc-3.21.1/petsc/src/ksp/ksp/interface/itfunc.c:831
[0]PETSC ERROR: #14 KSPSolve() at
/Documents/petsc-3.21.1/petsc/src/ksp/ksp/interface/itfunc.c:1078
On Wed, Aug 14, 2024 at 11:54 AM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> Ok, the problem is that the default algorithm for detecting the connected
> components of the interface finds a lot of disconnected dofs.
> What discretization is this? Nedelec elements? Can you try using -pc_
> *bddc_use_lo*cal_mat_graph 0?
> Also, you are using -pc_bddc_monolithic, but you only have one field. That
> flag aggregates different fields, but you only have one.
> Note that with Nedelec elements, you need a special change of basis for
> BDDC to work, see e.g. https://urldefense.us/v3/__https://www.osti.gov/servlets/purl/1377770__;!!G_uCfscf7eWS!ZVyzxJb4s9N1kzsS2BV7raG-kJIn8X6skBNtfsvA8aHyjWPm8oYGfzk83j1n0PFstGE6nDCHpOIpMvlI_QH81A$
> Il giorno mer 14 ago 2024 alle ore 05:15 neil liu <liufield at gmail.com> ha
> scritto:
>> Hi, Stefano,
>> Please see the attached for the smaller case(successful with BDDC).
>> and the Error_largerMesh shows the error with the large mesh using petsc
>> debug mode.
>> Thanks a lot,
>> Xiaodong
>> On Tue, Aug 13, 2024 at 5:47 PM Stefano Zampini <
>> stefano.zampini at gmail.com> wrote:
>>> can you run the same options and add "-ksp_view -pc_bddc_check_level 1"
>>> for the smaller case? Also, can you send the full stack trace of the
>>> out-of-memory error using a debug version of PETSc?
>>> A note aside: you should not need pc_bddc_use_vertices (which is on by
>>> default)
>>> Il giorno mar 13 ago 2024 alle ore 23:17 neil liu <liufield at gmail.com>
>>> ha scritto:
>>>> Dear Petsc developers,
>>>> I am testing PCBDDC for my vector based FEM solver(complex system). It
>>>> can work well on a coarse mesh(tetrahedra cell #: 6,108; dof # : 39,596).
>>>> Then I tried a finer mesh (tetrahedra cell #: 32,036; dof # : 206,362). It
>>>> seems ASM can work well with
>>>> petsc-3.21.1/petsc/arch-linux-c-opt/bin/mpirun -n 4 ./app -pc_type asm
>>>> -ksp_converged_reason -ksp_monitor -ksp_gmres_restart 100 -ksp_rtol 1e-4
>>>> -pc_asm_overalp 4 -sub_pc_type ilu -malloc_view
>>>> while PCBDDC eats up the memory (61 GB) when I tried
>>>> -pc_bddc_coarse_redundant_pc_type ilu -pc_bddc_use_vertices
>>>> -ksp_gmres_restart 30 -ksp_view -malloc_view -pc_bddc_monolithic
>>>> -pc_bddc_neumann_pc_type ilu -pc_bddc_dirichlet_pc_type ilu
>>>> The following errors with BDDC came out. The memory usage for PCBDDC
>>>> (different from PCASM) is also listed (I am assuming the unit is Bytes,
>>>> right?). *Although the BDDC requires more memory, it still seems
>>>> normal, right? *
>>>> [0]PETSC ERROR: Out of memory. This could be due to allocating
>>>> [0]PETSC ERROR: too large an object or bleeding by not properly
>>>> [0]PETSC ERROR: destroying unneeded objects.
>>>> [0] Maximum memory PetscMalloc()ed 30829727808 maximum size of entire
>>>> process 16899194880
>>>> [0] Memory usage sorted by function
>>>> *[0] 1 240 PCBDDCGraphCreate()*
>>>> *[0] 1 3551136 PCBDDCGraphInit()*
>>>> *[0] 2045 32720 PCBDDCGraphSetUp()*
>>>> *[0] 2 8345696 PCBDDCSetLocalAdjacencyGraph_BDDC()*
>>>> *[0] 1 784 PCCreate()*
>>>> *[0] 1 1216 PCCreate_BDDC()*
>>>> Thanks for your help.
>>>> Xiaodong
>>> Stefano
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240814/94ebca4a/attachment-0001.html>
