[petsc-users] Question about the memory usage for BDDC preconditioner.
neil liu liufield at gmail.com
Tue Aug 13 22:15:13 CDT 2024
Hi, Stefano,
Please see the attached for the smaller case(successful with BDDC).
and the Error_largerMesh shows the error with the large mesh using petsc
debug mode.
Thanks a lot,
Xiaodong
On Tue, Aug 13, 2024 at 5:47 PM Stefano Zampini <stefano.zampini at gmail.com>
wrote:
> can you run the same options and add "-ksp_view -pc_bddc_check_level 1"
> for the smaller case? Also, can you send the full stack trace of the
> out-of-memory error using a debug version of PETSc?
> A note aside: you should not need pc_bddc_use_vertices (which is on by
> default)
> Il giorno mar 13 ago 2024 alle ore 23:17 neil liu <liufield at gmail.com> ha
> scritto:
>> Dear Petsc developers,
>> I am testing PCBDDC for my vector based FEM solver(complex system). It
>> can work well on a coarse mesh(tetrahedra cell #: 6,108; dof # : 39,596).
>> Then I tried a finer mesh (tetrahedra cell #: 32,036; dof # : 206,362). It
>> seems ASM can work well with
>> petsc-3.21.1/petsc/arch-linux-c-opt/bin/mpirun -n 4 ./app -pc_type asm
>> -ksp_converged_reason -ksp_monitor  -ksp_gmres_restart 100 -ksp_rtol 1e-4
>> -pc_asm_overalp 4 -sub_pc_type ilu -malloc_view
>> while  PCBDDC eats up the memory (61 GB) when I tried
>> petsc-3.21.1/petsc/arch-linux-c-opt/bin/mpirun -n 4 ./app -pc_type bddc
>> -pc_bddc_coarse_redundant_pc_type ilu  -pc_bddc_use_vertices
>> -ksp_error_if_not_converged -mat_type is -ksp_monitor -ksp_rtol 1e-8
>> -ksp_gmres_restart 30 -ksp_view -malloc_view -pc_bddc_monolithic
>> -pc_bddc_neumann_pc_type ilu -pc_bddc_dirichlet_pc_type ilu
>> The following errors with BDDC came out. The memory usage for PCBDDC
>> (different from PCASM) is also listed (I am assuming the unit is Bytes,
>> right?). *Although the BDDC requires more memory, it still seems normal,
>> right? *
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Out of memory. This could be due to allocating
>> [0]PETSC ERROR: too large an object or bleeding by not properly
>> [0]PETSC ERROR: destroying unneeded objects.
>> [0] Maximum memory PetscMalloc()ed 30829727808 maximum size of entire
>> process 16899194880
>> [0] Memory usage sorted by function
>> *[0] 1 240 PCBDDCGraphCreate()*
>> *[0] 1 3551136 PCBDDCGraphInit()*
>> *[0] 2045 32720 PCBDDCGraphSetUp()*
>> *[0] 2 8345696 PCBDDCSetLocalAdjacencyGraph_BDDC()*
>> *[0] 1 784 PCCreate()*
>> *[0] 1 1216 PCCreate_BDDC()*
>> Thanks for your help.
>> Xiaodong
> Stefano
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240813/48df33f7/attachment-0001.html>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240813/48df33f7/attachment-0002.obj>
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240813/48df33f7/attachment-0003.obj>
