[petsc-users] How to combine different element types into a single DMPlex?
Eric Chamberland Eric.Chamberland at giref.ulaval.ca
Thu Aug 1 07:23:28 CDT 2024
Hi Matthew,
we have our own format that uses MPI I/O for the initial read, then we
would like to do almost exactly what we do in ex47.c
(https://urldefense.us/v3/__https://petsc.org/main/src/dm/impls/plex/tests/ex47.c.html__;!!G_uCfscf7eWS!cgLnoLq-w8YlD_y4ZrBQbY1i_SgBSKmVRFIOZU9rULyu9jowettkaC7Srlg-sjuHlrXIjItOOY-dgiXMDyfGE3fljVcPVgrTfu5bKTR_$ ) excepted
the very beginning of the program that will read (MPI I/O) from the
disk.  Then, always in parallel:
1- Populate a DMPlex with multiple element types (with a variant of
DMPlexBuildFromCellListParallel ? do you have an example of this?)
2- Call partitioning (DMPlexDistribute)
3- Compute overlap (DMPlexDistributeOverlap)
4- Also compute the corresponding mapping between original element
numbers and partitonned+overlap elements ( DMPlexNaturalToGlobalBegin/End)
The main point here here is overlap computation.  And the big challenge
is that we must always rely on the fact that never, ever, any node read
all the mesh: all nodes have only a small part of it at the beginning
then we want parallel partitioning and overlapping computation...
It is now working fine for a mesh with a single type of element, but if
we can modify ex47.c with an example of a mixed element types that will
achieve what we would like to do!
Eric
On 2024-07-31 22:09, Matthew Knepley wrote:
> On Wed, Jul 31, 2024 at 4:16 PM Eric Chamberland
> <Eric.Chamberland at giref.ulaval.ca> wrote:
>     Hi Vaclav,
>     Okay, I am coming back with this question after some time... ;)
>     I am just wondering if it is now possible to call
>     DMPlexBuildFromCellListParallel or something else, to build a mesh
>     that combine different element types into a single DMPlex (in
>     parallel of course) ?
> 1) Meshes with different cell types are fully functional, and some
> applications have been using them for a while now.
> 2) The Firedrake I/O methods support these hybrid meshes.
> 3) You can, for example, read in a GMsh or ExodusII file with
> different cell types.
> However, there is no direct interface like
> DMPlexBuildFromCellListParallel(). If you plan on creating meshes by
> hand, I can build that for you.
> No one so far has wanted that. Rather they want to read in a mesh in
> some format, or alter a base mesh by inserting other cell types.
> So, what is the motivating use case?
>   Thanks,
>      Matt
>     Thanks,
>     Eric
>     On 2021-09-23 11:30, Hapla Vaclav wrote:
>>     Note there will soon be a generalization of
>>     DMPlexBuildFromCellListParallel() around, as a side product of
>>     our current collaborative efforts with Firedrake guys. It will
>>     take a PetscSection instead of relying on the blocksize [which is
>>     indeed always constant for the given dataset]. Stay tuned.
>>     https://urldefense.us/v3/__https://gitlab.com/petsc/petsc/-/merge_requests/4350__;!!G_uCfscf7eWS!cgLnoLq-w8YlD_y4ZrBQbY1i_SgBSKmVRFIOZU9rULyu9jowettkaC7Srlg-sjuHlrXIjItOOY-dgiXMDyfGE3fljVcPVgrTfvLIunXK$
>>     Thanks,
>>     Vaclav
>>>     On 23 Sep 2021, at 16:53, Eric Chamberland
>>>     Hi,
>>>     oh, that's a great news!
>>>     In our case we have our home-made file-format, invariant to the
>>>     number of processes (thanks to MPI_File_set_view), that uses
>>>     collective, asynchronous MPI I/O native calls for unstructured
>>>     hybrid meshes and fields .
>>>     So our needs are not for reading meshes but only to fill an
>>>     hybrid DMPlex with DMPlexBuildFromCellListParallel (or something
>>>     else to come?)... to exploit petsc partitioners and parallel
>>>     overlap computation...
>>>     Thanks for the follow-up! :)
>>>     Eric
>>>     On 2021-09-22 7:20 a.m., Matthew Knepley wrote:
>>>>     On Wed, Sep 22, 2021 at 3:04 AM Karin&NiKo
>>>>     <niko.karin at gmail.com> wrote:
>>>>         Dear Matthew,
>>>>         This is great news!
>>>>         For my part, I would be mostly interested in the parallel
>>>>         input interface. Sorry for that...
>>>>         Indeed, in our application, we already have a parallel mesh
>>>>         data structure that supports hybrid meshes with parallel
>>>>         I/O and distribution (based on the MED format). We would
>>>>         like to use a DMPlex to make parallel mesh adaptation.
>>>>          As a matter of fact, all our meshes are in the MED format.
>>>>         We could also contribute to extend the interface of DMPlex
>>>>         with MED (if you consider it could be usefull).
>>>>     An MED interface does exist. I stopped using it for two reasons:
>>>>       1) The code was not portable and the build was failing on
>>>>     different architectures. I had to manually fix it.
>>>>       2) The boundary markers did not provide global information,
>>>>     so that parallel reading was much harder.
>>>>     Feel free to update my MED reader to a better design.
>>>>       Thanks,
>>>>          Matt
>>>>         Best regards,
>>>>         Nicolas
>>>>         Le mar. 21 sept. 2021 à 21:56, Matthew Knepley
>>>>         <knepley at gmail.com> a écrit :
>>>>             On Tue, Sep 21, 2021 at 10:31 AM Karin&NiKo
>>>>                 Dear Eric, dear Matthew,
>>>>                 I share Eric's desire to be able to manipulate
>>>>                 meshes composed of different types of elements in a
>>>>                 PETSc's DMPlex.
>>>>                 Since this discussion, is there anything new on
>>>>                 this feature for the DMPlex object or am I missing
>>>>                 something?
>>>>             Thanks for finding this!
>>>>             Okay, I did a rewrite of the Plex internals this
>>>>             summer. It should now be possible to interpolate a mesh
>>>>             with any
>>>>             number of cell types, partition it, redistribute it,
>>>>             and many other manipulations.
>>>>             You can read in some formats that support
>>>>             hybrid meshes. If you let me know how you plan to read
>>>>             it in, we can make it work.
>>>>             Right now, I don't want to make input interfaces that
>>>>             no one will ever use. We have a project, joint with
>>>>             Firedrake, to finalize
>>>>             parallel I/O. This will make parallel reading and
>>>>             writing for checkpointing possible, supporting
>>>>             topology, geometry, fields and
>>>>             layouts, for many meshes in one HDF5 file. I think we
>>>>             will finish in November.
>>>>               Thanks,
>>>>                  Matt
>>>>                 Thanks,
>>>>                 Nicolas
>>>>                 Le mer. 21 juil. 2021 à 04:25, Eric Chamberland
>>>>                 <Eric.Chamberland at giref.ulaval.ca> a écrit :
>>>>                     Hi,
>>>>                     On 2021-07-14 3:14 p.m., Matthew Knepley wrote:
>>>>>                     On Wed, Jul 14, 2021 at 1:25 PM Eric
>>>>>                     Chamberland <Eric.Chamberland at giref.ulaval.ca>
>>>>>                     wrote:
>>>>>                         Hi,
>>>>>                         while playing with
>>>>>                         DMPlexBuildFromCellListParallel, I noticed
>>>>>                         we have to
>>>>>                         specify "numCorners" which is a fixed
>>>>>                         value, then gives a fixed number
>>>>>                         of nodes for a series of elements.
>>>>>                         How can I then add, for example, triangles
>>>>>                         and quadrangles into a DMPlex?
>>>>>                     You can't with that function. It would be much
>>>>>                     mich more complicated if you could, and I am
>>>>>                     not sure
>>>>>                     it is worth it for that function. The reason
>>>>>                     is that you would need index information to
>>>>>                     offset into the
>>>>>                     connectivity list, and that would need to be
>>>>>                     replicated to some extent so that all
>>>>>                     processes know what
>>>>>                     the others are doing. Possible, but complicated.
>>>>>                     Maybe I can help suggest something for what
>>>>>                     you are trying to do?
>>>>                     Yes: we are trying to partition our parallel
>>>>                     mesh with PETSc functions. The mesh has been
>>>>                     read in parallel so each process owns a part of
>>>>                     it, but we have to manage mixed elements types.
>>>>                     When we directly use ParMETIS_V3_PartMeshKway,
>>>>                     we give two arrays to describe the elements
>>>>                     which allows mixed elements.
>>>>                     So, how would I read my mixed mesh in parallel
>>>>                     and give it to PETSc DMPlex so I can use a
>>>>                     PetscPartitioner with DMPlexDistribute ?
>>>>                     A second goal we have is to use PETSc to
>>>>                     compute the overlap, which is something I can't
>>>>                     find in PARMetis (and any other partitionning
>>>>                     library?)
>>>>                     Thanks,
>>>>                     Eric
>>>>>                       Thanks,
>>>>>                     Matt
>>>>>                         Thanks,
>>>>>                         Eric
>>>>>                         Eric Chamberland, ing., M. Ing
>>>>>                         Professionnel de recherche
>>>>>                         GIREF/Université Laval
>>>>>                         (418) 656-2131 poste 41 22 42
>>>>>                     What most experimenters take for granted
>>>>>                     before they begin their experiments is
>>>>>                     infinitely more interesting than any results
>>>>>                     to which their experiments lead.
>>>>>                     -- Norbert Wiener
>>>>>                     https://urldefense.us/v3/__https://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cgLnoLq-w8YlD_y4ZrBQbY1i_SgBSKmVRFIOZU9rULyu9jowettkaC7Srlg-sjuHlrXIjItOOY-dgiXMDyfGE3fljVcPVgrTfsLvKmAp$
>>>>>                     <https://urldefense.us/v3/__http://www.cse.buffalo.edu/*knepley/__;fg!!G_uCfscf7eWS!cgLnoLq-w8YlD_y4ZrBQbY1i_SgBSKmVRFIOZU9rULyu9jowettkaC7Srlg-sjuHlrXIjItOOY-dgiXMDyfGE3fljVcPVgrTfmYFl_DF$ >
>>>>             What most experimenters take for granted before they
>>>>             begin their experiments is infinitely more interesting
>>>>             than any results to which their experiments lead.
>>>>             -- Norbert Wiener
>>>>     What most experimenters take for granted before they begin
>>>>     their experiments is infinitely more interesting than any
>>>>     -- Norbert Wiener
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240801/39c62585/attachment-0001.html>
