[petsc-users] Configure error while building PETSc with CUDA/MVAPICH2-GDR
    Sreeram R Venkat
    srvenkat at utexas.edu
    Wed Apr 17 08:26:47 CDT 2024
Yes, I saw this paper
https://urldefense.us/v3/__https://www.sciencedirect.com/science/article/abs/pii/S016781912100079X__;!!G_uCfscf7eWS!dHsBib5l9Muy07HNhTdWzjZYUUlhkMkHrO7blcUjZQbwvChOEe0pDb5zyW-3qjEF78R3JHlcfjthtoxJY5VolUpbQw$
that mentioned it, and I heard in Barry's talk at SIAM PP this year about
the need for stream-aware MPI, so I was wondering if NCCL would be used in
PETSc to do GPU-GPU communication.
On Wed, Apr 17, 2024, 7:58 AM Junchao Zhang <junchao.zhang at gmail.com> wrote:
> On Wed, Apr 17, 2024 at 7:51 AM Sreeram R Venkat <srvenkat at utexas.edu>
> wrote:
>> Do you know if there are plans for NCCL support in PETSc?
> What is your need?  Do you mean using NCCL for the MPI communication?
>> On Tue, Apr 16, 2024, 10:41 PM Junchao Zhang <junchao.zhang at gmail.com>
>> wrote:
>>> Glad to hear you found a way.   Did you use Frontera at TACC?  If yes, I
>>> could have a try.
>>> --Junchao Zhang
>>> On Tue, Apr 16, 2024 at 8:35 PM Sreeram R Venkat <srvenkat at utexas.edu>
>>> wrote:
>>>> I finally figured out a way to make it work. I had to build PETSc and
>>>> my application using the (non GPU-aware) Intel MPI. Then, before running, I
>>>> switch to the MVAPICH2-GDR. I'm not sure why that works, but it's the only
>>>> way I've
>>>> ZjQcmQRYFpfptBannerStart
>>>> This Message Is From an External Sender
>>>> This message came from outside your organization.
>>>> ZjQcmQRYFpfptBannerEnd
>>>> I'm not sure why that works, but it's the only way I've found to
>>>> compile and run successfully without throwing any errors about not having a
>>>> GPU-aware MPI.
>>>> On Fri, Dec 8, 2023 at 5:30 PM Mark Adams <mfadams at lbl.gov> wrote:
>>>>> You may need to set some env variables. This can be system specific so
>>>>> you might want to look at docs or ask TACC how to run with GPU-aware MPI.
>>>>> Mark
>>>>> On Fri, Dec 8, 2023 at 5:17 PM Sreeram R Venkat <srvenkat at utexas.edu>
>>>>> wrote:
>>>>>> Actually, when I compile my program with this build of PETSc and run,
>>>>>> I still get the error:
>>>>>> PETSC ERROR: PETSc is configured with GPU support, but your MPI is
>>>>>> not GPU-aware. For better performance, please use a GPU-aware MPI.
>>>>>> I have the mvapich2-gdr module loaded and MV2_USE_CUDA=1.
>>>>>> Is there anything else I need to do?
>>>>>> Thanks,
>>>>>> Sreeram
>>>>>> On Fri, Dec 8, 2023 at 3:29 PM Sreeram R Venkat <srvenkat at utexas.edu>
>>>>>> wrote:
>>>>>>> Thank you, changing to CUDA 11.4 fixed the issue. The mvapich2-gdr
>>>>>>> module didn't require CUDA 11.4 as a dependency, so I was using 12.0
>>>>>>> On Fri, Dec 8, 2023 at 1:15 PM Satish Balay <balay at mcs.anl.gov>
>>>>>>> wrote:
>>>>>>>> Executing: mpicc -show
>>>>>>>> stdout: icc -I/opt/apps/cuda/11.4/include
>>>>>>>> -I/opt/apps/cuda/11.4/include -lcuda -L/opt/apps/cuda/11.4/lib64/stubs
>>>>>>>> -L/opt/apps/cuda/11.4/lib64 -lcudart -lrt
>>>>>>>> -Wl,-rpath,/opt/apps/cuda/11.4/lib64 -Wl,-rpath,XORIGIN/placeholder
>>>>>>>> -Wl,--build-id -L/opt/apps/cuda/11.4/lib64/ -lm
>>>>>>>> -I/opt/apps/intel19/mvapich2-gdr/2.3.7/include
>>>>>>>> -L/opt/apps/intel19/mvapich2-gdr/2.3.7/lib64 -Wl,-rpath
>>>>>>>> -Wl,/opt/apps/intel19/mvapich2-gdr/2.3.7/lib64 -Wl,--enable-new-dtags -lmpi
>>>>>>>>     Checking for program /opt/apps/cuda/12.0/bin/nvcc...found
>>>>>>>> Looks like you are trying to mix in 2 different cuda versions in
>>>>>>>> this build.
>>>>>>>> Perhaps you need to use cuda-11.4 - with this install of mvapich..
>>>>>>>> Satish
>>>>>>>> On Fri, 8 Dec 2023, Matthew Knepley wrote:
>>>>>>>> > On Fri, Dec 8, 2023 at 1:54 PM Sreeram R Venkat <
>>>>>>>> srvenkat at utexas.edu> wrote:
>>>>>>>> > > I am trying to build PETSc with CUDA using the CUDA-Aware
>>>>>>>> MVAPICH2-GDR.
>>>>>>>> > > Here is my configure command:
>>>>>>>> > > ./configure PETSC_ARCH=linux-c-debug-mvapich2-gdr
>>>>>>>> --download-hypre
>>>>>>>> > >  --with-cuda=true --cuda-dir=$TACC_CUDA_DIR --with-hdf5=true
>>>>>>>> > > --with-hdf5-dir=$TACC_PHDF5_DIR --download-elemental
>>>>>>>> --download-metis
>>>>>>>> > > --download-parmetis --with-cc=mpicc --with-cxx=mpicxx
>>>>>>>> --with-fc=mpif90
>>>>>>>> > > which errors with:
>>>>>>>> > >           UNABLE to CONFIGURE with GIVEN OPTIONS (see
>>>>>>>> configure.log for
>>>>>>>> > > details):
>>>>>>>> > >   CUDA compile failed with arch flags " -ccbin mpic++ -std=c++14
>>>>>>>> > > -Xcompiler -fPIC
>>>>>>>> > >   -Xcompiler -fvisibility=hidden -g -lineinfo -gencode
>>>>>>>> > > arch=compute_80,code=sm_80"
>>>>>>>> > >   generated from "--with-cuda-arch=80"
>>>>>>>> > > The same configure command works when I use the Intel MPI and I
>>>>>>>> can build
>>>>>>>> > > with CUDA. The full config.log file is attached. Please let me
>>>>>>>> know if you
>>>>>>>> > > need any other information. I appreciate your help with this.
>>>>>>>> > The proximate error is
>>>>>>>> > Executing: nvcc -c -o
>>>>>>>> /tmp/petsc-kn3f29gl/config.packages.cuda/conftest.o
>>>>>>>> > -I/tmp/petsc-kn3f29gl/config.setCompilers
>>>>>>>> > -I/tmp/petsc-kn3f29gl/config.types
>>>>>>>> > -I/tmp/petsc-kn3f29gl/config.packages.cuda  -ccbin mpic++
>>>>>>>> -std=c++14
>>>>>>>> > -Xcompiler -fPIC -Xcompiler -fvisibility=hidden -g -lineinfo
>>>>>>>> -gencode
>>>>>>>> > conftest.cu
>>>>>>>> <https://urldefense.us/v3/__http://conftest.cu__;!!G_uCfscf7eWS!duKUz7pE9N0adJ-FOW7PLZ_1cSZvYlnqh7J0TIcZN0v8RLplcWxh1YE8Vis29K0cuw_zAvjdK-H9H2JYYuUUKRXxlA$>
>>>>>>>> > stdout:
>>>>>>>> > /opt/apps/cuda/11.4/include/crt/sm_80_rt.hpp(141): error: more
>>>>>>>> than one
>>>>>>>> > instance of overloaded function
>>>>>>>> "__nv_associate_access_property_impl" has
>>>>>>>> > "C" linkage
>>>>>>>> > 1 error detected in the compilation of
>>>>>>>> > "/tmp/petsc-kn3f29gl/config.packages.cuda/conftest.cu
>>>>>>>> > Possible ERROR while running compiler: exit code 1
>>>>>>>> > stderr:
>>>>>>>> than one
>>>>>>>> > "C" linkage
>>>>>>>> > This looks like screwed up headers to me, but I will let someone
>>>>>>>> that
>>>>>>>> > understands CUDA compilation reply.
>>>>>>>> >   Thanks,
>>>>>>>> >      Matt
>>>>>>>> > Thanks,
>>>>>>>> > > Sreeram
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240417/ebb1175a/attachment.html>
