[petsc-users] MatCreateTranspose
Pierre Jolivet pierre at joliv.et
Fri Apr 12 04:16:18 CDT 2024
> On 12 Apr 2024, at 11:10 AM, Carl-Johan Thore <carljohanthore at gmail.com> wrote:
> Pierre, I see that you've already done a merge request for this. Thanks!
> I have tested this and it works nicely in my application
I guess your matrix is symmetric in pattern?
Because otherwise, I don’t think this should work.
But if it’s OK for your use case, I could simply add a PetscCheck() that the input Mat is symmetric and then get this integrated (better to have something partially working than nothing at all, I guess).
Please let me know.
Pierre
> /Carl-Johan
> On Wed, Apr 10, 2024 at 8:24 AM Carl-Johan Thore <carljohanthore at gmail.com <mailto:carljohanthore at gmail.com>> wrote:
>> On Tue, Apr 9, 2024 at 5:31 PM Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>>>> On 9 Apr 2024, at 4:19 PM, Carl-Johan Thore <carljohanthore at gmail.com <mailto:carljohanthore at gmail.com>> wrote:
>>>> This Message Is From an External Sender
>>>> This message came from outside your organization.
>>>> Thanks for the suggestion. I don't have a factored matrix (and can't really use direct linear solvers) so MatSolveTranspose doesn't seem to be an option.
>>>> I should have mentioned that I've also tried KSPSolveTranspose but that doesn't work with pcredistribute
>>> I’m not a frequent PCREDISTRIBUTE user, but it looks like https://urldefense.us/v3/__https://petsc.org/release/src/ksp/pc/impls/redistribute/redistribute.c.html*line332__;Iw!!G_uCfscf7eWS!dzQtfplyy0liDIzLvwZPEQ15gmxeoXxZBqfgkYyHOUdkUhP-wvoKWG58yEPisaaRzqydtExDOol1d4MSyysHYQ$  could be copy/paste’d into PCApplyTranspose_Redistribute() by just changing a MatMult() to MatMultTranspose() and KSPSolve() to KSPSolveTranspose().
>>> Would you be willing to contribute (and test) this?
>>> Then, KSPSolveTranspose() — which should be the function you call — will work.
>>> Thanks,
>>> Pierre
>> Thanks, that sounds promising. Yes, I'll try to make a contribution
>> /Carl-Johan
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240412/ff0f6228/attachment-0001.html>
