[petsc-users] Exposing further detail in -log_view for Hypre withe PETSc
Khurana, Parv p.khurana22 at imperial.ac.uk
Wed Apr 10 08:09:53 CDT 2024
Hi Mark,
I have had a look at these, and I could only find these ones that looked relevant:
-pc_hypre_boomeramg_print_statistics: Print statistics (None)
  -pc_hypre_boomeramg_print_debug: Print debug information (None)
-pc_hypre_boomeramg_print_statistics prints information about the V-cycle (number of levels, Dofs per level etc.) It also gave this information (which is something I can potentially work with?)
Proc = 0    Level = 0    Coarsen Time = 0.022089
Proc = 0    Level = 0    Build Interp Time = 0.138844
Proc = 0    Level = 0    Build Coarse Operator Time = 0.354488
Proc = 0    Level = 1    Coarsen Time = 0.009334
Proc = 0    Level = 1    Build Interp Time = 0.074119
Proc = 0    Level = 1    Build Coarse Operator Time = 0.097702
Proc = 0    Level = 2    Coarsen Time = 0.004301
Proc = 0    Level = 2    Build Interp Time = 0.035835
Proc = 0    Level = 2    Build Coarse Operator Time = 0.030501
Proc = 0    Level = 3    Coarsen Time = 0.001876
Proc = 0    Level = 3    Build Interp Time = 0.014711
Proc = 0    Level = 3    Build Coarse Operator Time = 0.008681
Proc = 0    Level = 4    Coarsen Time = 0.000557
Proc = 0    Level = 4    Build Interp Time = 0.004307
Proc = 0    Level = 4    Build Coarse Operator Time = 0.002373
Proc = 0    Level = 5    Coarsen Time = 0.000268
Proc = 0    Level = 5    Build Interp Time = 0.001061
Proc = 0    Level = 5    Build Coarse Operator Time = 0.000589
Proc = 0    Level = 6    Coarsen Time = 0.000149
Proc = 0    Level = 6    Build Interp Time = 0.000339
Proc = 0    Level = 6    Build Coarse Operator Time = 0.000206
Proc = 0    Level = 7    Coarsen Time = 0.000090
Proc = 0    Level = 7    Build Interp Time = 0.000148
Proc = 0    Level = 7    Build Coarse Operator Time = 0.000085
Proc = 0    Level = 8    Coarsen Time = 0.000054
Proc = 0    Level = 8    Build Interp Time = 0.000100
Proc = 0    Level = 8    Build Coarse Operator Time = 0.000053
I have not tried -pc_hypre_boomeramg_print_debug yet.
Think I can get the total coarsen time by summing up the time from all the levels here. I am still trying to understand how to get the time spent to solve the problem at the coarsest level.
Best
Parv
Sent: Wednesday, April 10, 2024 2:01 PM
To: Khurana, Parv <p.khurana22 at imperial.ac.uk>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Exposing further detail in -log_view for Hypre withe PETSc
This email from mfadams at lbl.gov<mailto:mfadams at lbl.gov> originates from outside Imperial. Do not click on links and attachments unless you recognise the sender. If you trust the sender, add them to your safe senders list<https://urldefense.us/v3/__https://spam.ic.ac.uk/SpamConsole/Senders.aspx__;!!G_uCfscf7eWS!ed9RkXQqDh1kRdnHw6WLZnxuX_1FqD8owPJ9aEVg03JkpWQewQVck8IP7DBq-GvoauWVZ3mYePX6Myc8UdEXTsMz4PvWKVOl$ > to disable email stamping for this address.
I believe there is an option to get hypre to print its performance data.
Run with -help and grep on "pc_hypre" and look for something that looks like a logging or view parameter.
On Wed, Apr 10, 2024 at 7:49 AM Khurana, Parv <p.khurana22 at imperial.ac.uk<mailto:p.khurana22 at imperial.ac.uk>> wrote:
Hello PETSc users community, Thank you in advance for your help as always. I am using BoomerAMG from Hypre via PETSc as a part of preconditioner in my software (Nektar++). I am trying to understand the time profiling information that is printed
ZjQcmQRYFpfptBannerStart
This Message Is From an External Sender
This message came from outside your organization.
ZjQcmQRYFpfptBannerEnd
I am using BoomerAMG from Hypre via PETSc as a part of preconditioner in my software (Nektar++). I am trying to understand the time profiling information that is printed using the -log_view option.
I want to understand how much time is spent in the smoothening step vs the time to solve on the coarsest grid I reach. The output that I get from -log_view (pasted below) gives me information of the KSPSolve and MatMult, but I think I need more granular time information to see a further breakdown of time spent within my routines. I would like to hear if anyone has any recommendations on obtaining this information?
Best
Parv Khurana
PETSc database options used for solve:
-ksp_monitor # (source: file)
-ksp_type preonly # (source: file)
-log_view # (source: file)
-pc_hypre_boomeramg_coarsen_type hmis # (source: file)
-pc_hypre_boomeramg_grid_sweeps_all 2 # (source: file)
-pc_hypre_boomeramg_interp_type ext+i # (source: file)
-pc_hypre_boomeramg_max_iter 1 # (source: file)
-pc_hypre_boomeramg_P_max 2 # (source: file)
-pc_hypre_boomeramg_print_debug 1 # (source: file)
-pc_hypre_boomeramg_print_statistics 1 # (source: file)
-pc_hypre_boomeramg_relax_type_all sor/jacobi # (source: file)
-pc_hypre_boomeramg_strong_threshold 0.7 # (source: file)
-pc_hypre_boomeramg_truncfactor 0.3 # (source: file)
-pc_hypre_type boomeramg # (source: file)
-pc_type hypre # (source: file)
PETSc log_view output:
Event                Count      Time (sec)     Flop                              --- Global ---  --- Stage ----  Total
                   Max Ratio  Max     Ratio   Max  Ratio  Mess   AvgLen  Reduct  %T %F %M %L %R  %T %F %M %L %R Mflop/s
--- Event Stage 0: Main Stage
BuildTwoSided          1 1.0 9.6900e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatMult               14 1.0 1.6315e-01 1.0 1.65e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0 86  0  0  0   0 86  0  0  0  1011
MatConvert             1 1.0 4.3092e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyBegin       3 1.0 3.1680e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatAssemblyEnd         3 1.0 9.4178e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatGetRowIJ            2 1.0 1.1630e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatSetPreallCOO        1 1.0 3.2132e-01 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
MatSetValuesCOO        1 1.0 2.9956e-02 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecNorm               28 1.0 1.3981e-02 1.0 2.10e+07 1.0 0.0e+00 0.0e+00 0.0e+00  0 11  0  0  0   0 11  0  0  0  1499
VecSet                13 1.0 6.5185e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAYPX               14 1.0 7.1511e-03 1.0 5.24e+06 1.0 0.0e+00 0.0e+00 0.0e+00  0  3  0  0  0   0  3  0  0  0   733
VecAssemblyBegin      14 1.0 1.3998e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecAssemblyEnd        14 1.0 4.2560e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterBegin       14 1.0 8.2761e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
VecScatterEnd         14 1.0 4.4665e-05 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetGraph             1 1.0 6.5993e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFSetUp                1 1.0 7.9212e-03 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFPack                14 1.0 5.8690e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
SFUnpack              14 1.0 4.3370e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSetUp               1 1.0 2.4910e-06 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
KSPSolve              14 1.0 2.1922e+00 1.0 1.91e+08 1.0 0.0e+00 0.0e+00 0.0e+00  0 100  0  0  0   0 100  0  0  0    87
PCSetUp                1 1.0 1.3165e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
PCApply               14 1.0 1.9990e+00 1.0 0.00e+00 0.0 0.0e+00 0.0e+00 0.0e+00  0  0  0  0  0   0  0  0  0  0     0
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240410/a678072f/attachment-0001.html>
