[petsc-users] Problem with NVIDIA compiler and OpenACC
Barry Smith bsmith at petsc.dev
Fri Apr 5 13:43:28 CDT 2024
   I see what you are talking about in the blas checks. However those checks "don't really matter" in that configure still succeeds.
   Do you have a problem later with libnvJitLink.so <https://urldefense.us/v3/__http://libnvjitlink.so/__;!!G_uCfscf7eWS!Z6nfaGuXVLfVmi9EWFNhytjn-PHZA5vGVu1QdEZRgc8LaJigVHrccbBrA_nCIceeBq6hsOhfFwvrrTStrtuPdTA$ > ? When you build PETSc (send make.log) or when you run tests, make check? Or when you try to run your code?
   Barry
> On Apr 5, 2024, at 2:14 PM, Frank Bramkamp <bramkamp at nsc.liu.se> wrote:
> Hi Barry,
> Here I send you the configure.log file for the libnvJitLink problem.
> At the top of the configure.log file it seems to find libnvJitLink.so.12
> But in the test for BlasLapack, it mentions
> stdout:  /tmp/petsc-h7tpd5_s/config.packages.BlasLapack/conftest: error while loading shared libraries: libnvJitLink.so.12: cannot open shared object file: No such file or directory
> Is seems that for the BlasLapack test you include the “stubs" directory. In “stubs”, we only have libnvJitLink.so
> but not libnvJitLink.so.12  The libnvJitLink.so.12 we have in a different directory (libs64), where is was also found before.
> But maybe in the BlasLapack test, you only search for the libnvJitLink.so.12 in the stubs directory.
> Here I am not sure, if there should be a  libnvJitLink.so.12 in stubs as well or not.
> That means, it is not so clear if you should check in different directories, or if we should add another link from libnvJitLink.so in stubs to libnvJitLink.so.12.  But if other people also do not have
> libnvJitLink.so.12 in the stubs directory by default, that would be still a problem. But I also do not know if the stubs directory is the problem.
> Thanks, Frank
> <configure.log>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240405/1949cfd6/attachment.html>
