[petsc-users] Problem with NVIDIA compiler and OpenACC
Frank Bramkamp
bramkamp at nsc.liu.se
Thu Apr 4 09:33:00 CDT 2024
Thanks for the reply,
Do you know if you actively include the libnvc library ?!
Or is this somehow automatically included ?!
Greetings, Frank
> On 4 Apr 2024, at 15:56, Satish Balay <balay at mcs.anl.gov> wrote:
> On Thu, 4 Apr 2024, Frank Bramkamp wrote:
>> Dear PETSC Team,
>> I found the following problem:
>> I compile petsc 3.20.5 with Nvidia compiler 23.7.
>> I use a pretty standard configuration, including
>> --with-cc=mpicc --with-cxx=mpicxx --with-fc=mpifort COPTFLAGS="-O2 -g" CXXOPTFLAGS="-O2 -g" FOPTFLAGS="-O2 -g" --with-debugging=0 --with-log=1 --download-fblaslapack --with-cuda=0
>> I exclude cuda, since I was not sure if the problem was cuda related.
> Can you try using (to exclude cuda): --with-cudac=0
>> The problem is now, if I have s simple fortran program where I link the petsc library, but I actually do not use petsc in that program
>> (Just for testing). I want to use OpenACC directives in my program, e.g. !$acc parallel loop .
>> The problem is now, as soon I link with the petsc library, the openacc commands do not work anymore.
>> It seems that openacc is not initialised and hence it cannot find a GPU.
>> The problem seems that you link with -lnvc.
>> In “petscvariables” => PETSC_WITH_EXTERNAL_LIB you include “-lnvc”.
>> If I take this out, then openacc works. With “-lnvc” something gets messed up.
>> The problem is also discussed here:
>> https://urldefense.us/v3/__https://forums.developer.nvidia.com/t/failed-cuda-device-detection-when-explicitly-linking-libnvc/203225/1__;!!G_uCfscf7eWS!dlXNyKBzSbximQ13OXxwO506OF71yRM_H5KEnarqXE75D6Vg-ePZr2u6SJ5V3YpRETatvb9pMOUVmpyN0-19SFlbug$ <https://urldefense.us/v3/__https://forums.developer.nvidia.com/t/failed-cuda-device-detection-when-explicitly-linking-libnvc/203225/1__;!!G_uCfscf7eWS!dlXNyKBzSbximQ13OXxwO506OF71yRM_H5KEnarqXE75D6Vg-ePZr2u6SJ5V3YpRETatvb9pMOUVmpyN0-19SFlbug$><https://urldefense.us/v3/__https://forums.developer.nvidia.com/t/failed-cuda-device-detection-when-explicitly-linking-libnvc/203225/1__;!!G_uCfscf7eWS!dlXNyKBzSbximQ13OXxwO506OF71yRM_H5KEnarqXE75D6Vg-ePZr2u6SJ5V3YpRETatvb9pMOUVmpyN0-19SFlbug$ <https://urldefense.us/v3/__https://forums.developer.nvidia.com/t/failed-cuda-device-detection-when-explicitly-linking-libnvc/203225/1__;!!G_uCfscf7eWS!dlXNyKBzSbximQ13OXxwO506OF71yRM_H5KEnarqXE75D6Vg-ePZr2u6SJ5V3YpRETatvb9pMOUVmpyN0-19SFlbug$> >
>> My understanding is that libnvc is more a runtime library that does not need to be included by the linker.
>> Not sure if there is a specific reason to include libnvc (I am not so familiar what this library does).
>> If I take out -lnvc from “petscvariables”, then my program with openacc works as expected. I did not try any more realistic program that includes petsc.
>> 2)
>> When compiling petsc with cuda support, I also found that in the petsc library the library libnvJitLink.so.12
>> Is not found. On my system this library is in $CUDA_ROOT/lib64
>> I am not sure where this library is on your system ?!
> Hm - good if you can send configure.log for this. configure attempts '$CC -v' to determine the link libraries to get c/c++/fortran compatibility libraries. But it can grab other libraries that the compilers are using internally here.
> To avoid this - you can explicitly list these libraries to configure. For ex: for gcc/g++/gfortran
> ./configure CC=gcc CXX=g++ FC=gfortran LIBS="-lgfortran -lstdc++"
> Satish
>> Thanks a lot, Frank Bramkamp
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20240404/c6eaf970/attachment-0001.html>
