[petsc-users] Copying PETSc Objects Across MPI Communicators
Damyn Chipman
damynchipman at u.boisestate.edu
Mon Oct 30 11:42:42 CDT 2023
Sounds good, thanks.
I’ve also been looking into Elemental, but the documentation seems outdated and I can’t find good examples on how to use it. I have the LLNL fork installed.
-Damyn
> On Oct 28, 2023, at 8:56 AM, Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Oct 27, 2023 at 3:54 PM Damyn Chipman <damynchipman at u.boisestate.edu <mailto:damynchipman at u.boisestate.edu>> wrote:
>> Yeah, I’ll make an issue and use a modified version of this test routine.
>> Does anything change if I will be using MATSCALAPACK matrices instead of the built in MATDENSE?
> No, that is likely worse.
>> Like I said, I will be computing Schur complements and need to use a parallel and dense matrix format.
> I do not understand the communication pattern, but it is possible that Elemental would be slightly faster since it has some cool built-in communication operations, however it might be more programming.
> Thanks,
> Matt
>> -Damyn
>>> On Oct 26, 2023, at 10:01 AM, Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>> On Wed, Oct 25, 2023 at 11:55 PM Damyn Chipman <damynchipman at u.boisestate.edu <mailto:damynchipman at u.boisestate.edu>> wrote:
>>>> Great thanks, that seemed to work well. This is something my algorithm will do fairly often (“elevating” a node’s communicator to a communicator that includes siblings). The matrices formed are dense but low rank. With MatCreateSubMatrix, it appears I do a lot of copying from one Mat to another. Is there a way to do it with array copying or pointer movement instead of copying entries?
>>> We could make a fast path for dense that avoids MatSetValues(). Can you make an issue for this? The number one thing that would make this faster is to contribute a small test. Then we could run it continually when putting in the fast path to make sure we are preserving correctness.
>>> Thanks,
>>> Matt
>>>> -Damyn
>>>>> On Oct 24, 2023, at 9:51 PM, Jed Brown <jed at jedbrown.org <mailto:jed at jedbrown.org>> wrote:
>>>>> You can place it in a parallel Mat (that has rows or columns on only one rank or a subset of ranks) and then MatCreateSubMatrix with all new rows/columns on a different rank or subset of ranks.
>>>>> That said, you usually have a function that assembles the matrix and you can just call that on the new communicator.
>>>>> Damyn Chipman <damynchipman at u.boisestate.edu <mailto:damynchipman at u.boisestate.edu>> writes:
>>>>>> Hi PETSc developers,
>>>>>> In short, my question is this: Does PETSc provide a way to move or copy an object (say a Mat) from one communicator to another?
>>>>>> The more detailed scenario is this: I’m working on a linear algebra solver on quadtree meshes (i.e., p4est). I use communicator subsets in order to facilitate communication between siblings or nearby neighbors. When performing linear algebra across siblings (a group of 4), I need to copy a node’s data (i.e., a Mat object) from a sibling’s communicator to the communicator that includes the four siblings. From what I can tell, I can only copy a PETSc object onto the same communicator.
>>>>>> My current approach will be to copy the raw data from the Mat on one communicator to a new Mat on the new communicator, but I wanted to see if there is a more “elegant” approach within PETSc.
>>>>>> Thanks in advance,
>>>>>> Damyn Chipman
>>>>>> Boise State University
>>>>>> PhD Candidate
>>>>>> Computational Sciences and Engineering
>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>> -- Norbert Wiener
>>> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231030/516c73a4/attachment-0001.html>
