[petsc-users] OpenMP doesn't work anymore with PETSc building rules
Qiyue Lu
qiyuelu1 at gmail.com
Wed Oct 25 11:06:14 CDT 2023
Thanks for your reply, using this configurations:
*--with-cc=mpicc --with-cxx=mpicxx --with-fc=mpif90
--download-f2cblaslapack=1 --with-cudac=nvcc --with-cuda=1 --with-openmp=1
--with-threadsafety=1*
However, I got an error like:
*nvcc fatal : Unknown option '-fopenmp'*
Previously, when I don't have --with-openmp for the configuration, the
PETSc make system can build my *.cu code using nvcc and g++, of course,
OpenMP doesn't work. Now with this --with-openmp option, it cannot even
build. The interesting thing is, I got this error even after removing the
*-fopenmp* from *CXXFLAGS* contents:
CXXFLAGS=-std=c++17
LDFLAGS=
CXXPPFLAGS=-I/u/qiyuelu1/cuda/cuda-samples/Common
include ${PETSC_DIR}/lib/petsc/conf/variables
include ${PETSC_DIR}/lib/petsc/conf/rules
Qiyue Lu
On Wed, Oct 25, 2023 at 10:54 AM Satish Balay <balay at mcs.anl.gov> wrote:
> On Wed, 25 Oct 2023, Qiyue Lu wrote:
> > Hello,
> > I have an in-house code enabled OpenMP and it works. Now I am trying to
> > incorporate PETSc as the linear solver and build together using the
> > building rules in $PETSC_HOME/lib/petsc/conf/rules. However, I found the
> > OpenMP part doesn't work anymore.
> If you are looking at building only your sources with openmp - using petsc
> formatted makefile [using petsc build rules],
> you can specify it via CFLAGS - either in makefile - or on command line.
> For ex: [this example is using src/ksp/ksp/tutorials/makefile - with the
> corresponding make fules]
> [balay at pj01 tutorials]$ make ex2
> mpicc -fPIC -Wall -Wwrite-strings -Wno-unknown-pragmas
> -Wno-lto-type-mismatch -Wno-stringop-overflow -fstack-protector
> -fvisibility=hidden -g3 -O0 -I/home/balay/petsc/include
> -I/home/balay/petsc/arch-linux-c-debug/include -Wl,-export-dynamic
> ex2.c -Wl,-rpath,/home/balay/petsc/arch-linux-c-debug/lib
> -L/home/balay/petsc/arch-linux-c-debug/lib
> -Wl,-rpath,/software/mpich-4.1.1/lib -L/software/mpich-4.1.1/lib
> -Wl,-rpath,/usr/lib/gcc/x86_64-redhat-linux/13
> -L/usr/lib/gcc/x86_64-redhat-linux/13 -lpetsc -llapack -lblas -lm -lX11
> -lmpifort -lmpi -lgfortran -lm -lgfortran -lm -lgcc_s -lquadmath -lstdc++
> -lquadmath -o ex2
> [balay at pj01 tutorials]$ make clean
> [balay at pj01 tutorials]$ make ex2 CFLAGS=-fopenmp
> -fvisibility=hidden -g3 -O0 -fopenmp -I/home/balay/petsc/include
> -lquadmath -o ex2
> Satish
> > Should I re-configure the petsc installation with --with-openmp=1
> option? I
> > wonder are the building rules affected by this missing option?
> > Thanks,
> > Qiyue Lu
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231025/c8ea6c43/attachment-0001.html>
