[petsc-users] use MATSEQAIJMKL in 64-bit indices
Di Miao miaodi1987 at gmail.com
Fri Oct 20 15:19:27 CDT 2023
I found that when compiled with '--with-64-bit-indices=1' option, the
following three definitions in petscconf.h will be removed:
#define PETSC_HAVE_MKL_SPARSE 1
#define PETSC_HAVE_MKL_SPARSE_OPTIMIZE 1
#define PETSC_HAVE_MKL_SPARSE_SP2M_FEATURE 1
I believe mkl can also use 64-bit indices (libmkl_intel_ilp64). I tried to
add ' --with-mkl_sparse=1 --with-mkl_sparse_optimize=1' into configuration
but does not succeed.
Would I know if it is possible to use MATSEQAIJMKL matrix type in 64-bit
mode?
Di
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231020/b90bc87d/attachment.html>
