[petsc-users] Coordinate format internal reordering
Thu Oct 19 13:41:43 CDT 2023
On Thu, Oct 19, 2023 at 1:46 PM Enrico <degregori at dkrz.de> wrote:
> Sorry but I don't want another partition, Petsc internally is changing
> the partition. I would like to have the same partition that I have in
> the application. Is the example not clear?
"Petsc internally is changing the partition" This is not correct. PETSc does
not prescribe partitions. I refer to the documentation for the creation of
Vec:
  https://petsc.org/main/manualpages/Vec/VecCreateMPI/
Here the user sets the local and global sizes. Since data is contiguous,
these
completely define the vector, and are under user control.
     Matt
> On 19/10/2023 19:43, Matthew Knepley wrote:
> > On Thu, Oct 19, 2023 at 1:00 PM Enrico <degregori at dkrz.de
> > <mailto:degregori at dkrz.de>> wrote:
> >     Here is a very very simple reproducer of my problem. It is a fortran
> >     program and it has to run with 2 processes.
> > You seem to be saying that you start with one partition of your data,
> > but you would like
> > another partition. For this, you have to initially communicate. For this
> > I would use VecScatter.
> > However, since most data is generated, I would consider not generating
> > my data in that initial
> > distribution.
> > There are many examples in the repository. In the discretization of a
> > PDE, we first divide the domain,
> > then number up each piece, then assemble the linear algebra objects.
> >    Thanks,
> >        Matt
> >     The output is:
> >        process             0 : xx_v(            1 ) =
>  0.000000000000000
> >        process             0 : xx_v(            2 ) =
>  1.000000000000000
> >        process             0 : xx_v(            3 ) =
>  2.000000000000000
> >        process             1 : xx_v(            1 ) =
>  3.000000000000000
> >        process             1 : xx_v(            2 ) =
>  4.000000000000000
> >        process             1 : xx_v(            3 ) =
>  5.000000000000000
> >     and I would like to have:
>  2.000000000000000
>  3.000000000000000
>  4.000000000000000
>  0.000000000000000
>  1.000000000000000
>  5.000000000000000
> >     How can I do that?
> >     program main
> >     #include <petsc/finclude/petscksp.h>
> >           use petscksp
> >           implicit none
> >           PetscErrorCode ierr
> >           PetscInt  :: Psize = 6
> >           integer  :: Lsize
> >           PetscInt  :: work_size
> >           PetscInt  :: work_rank
> >           Vec :: b
> >           integer, allocatable, dimension(:) :: glb_index
> >           double precision, allocatable, dimension(:) :: array
> >           PetscScalar, pointer :: xx_v(:)
> >           integer :: i
> >           PetscCount :: csize
> >           CALL PetscInitialize(ierr)
> >           Lsize = 3
> >           csize = Lsize
> >           allocate(glb_index(0:Lsize-1), array(0:Lsize-1))
> >           CALL MPI_Comm_size(PETSC_COMM_WORLD, work_size, ierr);
> >           CALL MPI_Comm_rank(PETSC_COMM_WORLD, work_rank, ierr);
> >           if (work_rank == 0) then
> >             glb_index(0) = 2
> >             glb_index(1) = 3
> >             glb_index(2) = 4
> >             array(0) = 2
> >             array(1) = 3
> >             array(2) = 4
> >           else if (work_rank == 1) then
> >             glb_index(0) = 0
> >             glb_index(1) = 1
> >             glb_index(2) = 5
> >             array(0) = 0
> >             array(1) = 1
> >             array(2) = 5
> >           end if
> >           ! Create and fill rhs vector
> >           CALL VecCreate(PETSC_COMM_WORLD, b, ierr);
> >           CALL VecSetSizes(b, Lsize, Psize, ierr);
> >           CALL VecSetType(b, VECMPI, ierr);
> >           CALL VecSetPreallocationCOO(b, csize, glb_index, ierr)
> >           CALL VecSetValuesCOO(b, array, INSERT_VALUES, ierr)
> >           CALL VecGetArrayReadF90(b, xx_v, ierr)
> >           do i=1,Lsize
> >             write(*,*) 'process ', work_rank, ': xx_v(',i,') = ', xx_v(i)
> >           end do
> >           CALL VecRestoreArrayReadF90(b, xx_v, ierr)
> >           deallocate(glb_index, array)
> >           CALL VecDestroy(b,ierr)
> >           CALL PetscFinalize(ierr)
> >     end program main
> >     On 19/10/2023 17:36, Matthew Knepley wrote:
> >      > On Thu, Oct 19, 2023 at 11:33 AM Enrico <degregori at dkrz.de
> >      > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>> wrote:
> >      >     The layout is not poor, just the global indices are not
> >     contiguous,this
> >      >     has nothing to do with the local memory layout which is
> extremely
> >      >     optimized for different architectures. I can not change the
> >     layout
> >      >     anyway because it's a climate model with a million lines of
> code.
> >      >     I don't understand why Petsc is doing all this MPI
> >     communication under
> >      >     the hood.
> >      > I don't think we are communicating under the hood.
> >      >     I mean, it is changing the layout of the application and doing
> >      >     a lot of communication.
> >      > We do not create the layout. The user creates the data layout
> >     when they
> >      > create a vector or matrix.
> >      >     Is there no way to force the same layout and
> >      >     provide info about how to do the halo exchange? In this way I
> >     can have
> >      >     the same memory layout and there is no communication when I
> >     fill or
> >      >     fetch the vectors and the matrix.
> >      > Yes, you tell the vector/matrix your data layout when you create
> it.
> >      >    Thanks,
> >      >        Matt
> >      >     Cheers,
> >      >     Enrico
> >      >     On 19/10/2023 17:21, Matthew Knepley wrote:
> >      >      > On Thu, Oct 19, 2023 at 10:51 AM Enrico <degregori at dkrz.de
> >     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>> wrote:
> >      >      >     In the application the storage is contiguous but the
> >     global
> >      >     indexing is
> >      >      >     not. I would like to use AO as a translation layer but
> >     I don't
> >      >      >     understand it.
> >      >      > Why would you choose to index differently from your
> storage?
> >      >      >     My case is actually simple even if it is in a large
> >      >     application, I have
> >      >      >     Mat A, Vec b and Vec x
> >      >      >     After calling KSPSolve, I use VecGetArrayReadF90 to
> get a
> >      >     pointer to
> >      >      >     the
> >      >      >     data and they are in the wrong ordering, so for
> >     example the first
> >      >      >     element of the solution array on process 0 belongs to
> >     process
> >      >     1 in the
> >      >      >     application.
> >      >      > Again, this seems to be a poor choice of layout. What we
> >      >     typically do is
> >      >      > to partition
> >      >      > the data into chunks owned by each process first.
> >      >      >     Is it at this point that I should use the AO
> translation
> >      >     layer? This
> >      >      >     would be quite bad, it means to build Mat A and Vec b
> >     there
> >      >     is MPI
> >      >      >     communication and also to get the data of Vec x back
> >     in the
> >      >     application.
> >      >      > If you want to store data that process i updates on
> process j,
> >      >     this will
> >      >      > need communication.
> >      >      >     Anyway, I've tried to use
> >     AOPetscToApplicationPermuteReal on the
> >      >      >     solution array but it doesn't work as I would like. Is
> >     this
> >      >     function
> >      >      >     suppose to do MPI communication between processes and
> >     fetch
> >      >     the values
> >      >      >     of the application ordering?
> >      >      > There is no communication here. That function call just
> >     changes one
> >      >      > integer into another.
> >      >      > If you want to update values on another process, we
> >     recommend using
> >      >      > VecScatter() or
> >      >      > MatSetValues(), both of which take global indices and do
> >      >     communication
> >      >      > if necessary.
> >      >      >    Thanks,
> >      >      >      Matt
> >      >      >     Cheers,
> >      >      >     Enrico
> >      >      >     On 19/10/2023 15:25, Matthew Knepley wrote:
> >      >      >      > On Thu, Oct 19, 2023 at 8:57 AM Enrico
> >     <degregori at dkrz.de <mailto:degregori at dkrz.de>
> >     <mailto:degregori at dkrz.de> <mailto:degregori at dkrz.de
> >     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>>> wrote:
> >      >      >      >     Maybe I wasn't clear enough. I would like to
> >      >     completely get
> >      >      >     rid of
> >      >      >      >     Petsc
> >      >      >      >     ordering because I don't want extra
> >      >      >     processes to
> >      >      >      >     construct the vector and the matrix (since I
> >     have to fill
> >      >      >     them every
> >      >      >      >     time step because I'm just using the linear
> solver
> >      >     with a Mat
> >      >      >     and a Vec
> >      >      >      >     data structure). I don't understand how I can
> >     do that.
> >      >      >      > Any program you write to do linear algebra will have
> >      >     contiguous
> >      >      >     storage
> >      >      >      > because it
> >      >      >      > is so much faster. Contiguous indexing makes sense
> for
> >      >     contiguous
> >      >      >      > storage. If you
> >      >      >      > want to use non-contiguous indexing for contiguous
> >      >     storage, you
> >      >      >     would
> >      >      >      > need some
> >      >      >      > translation layer. The AO is such a translation,
> >     but you
> >      >     could do
> >      >      >     this
> >      >      >      > any way you want.
> >      >      >      >    Thanks,
> >      >      >      >       Matt
> >      >      >      >     My initial idea was to create another global
> index
> >      >     ordering
> >      >      >     within my
> >      >      >      >     application to use only for the Petsc interface
> >     but then I
> >      >      >     think that
> >      >      >      >     the ghost cells are wrong.
> >      >      >      >     On 19/10/2023 14:50, Matthew Knepley wrote:
> >      >      >      >      > On Thu, Oct 19, 2023 at 6:51 AM Enrico
> >     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>>>> wrote:
> >      >      >      >      >     Hello,
> >      >      >      >      >     if I create an application ordering using
> >      >      >     AOCreateBasic, should I
> >      >      >      >      >     provide the same array for const PetscInt
> >      >     myapp[] and
> >      >      >     const
> >      >      >      >     PetscInt
> >      >      >      >      >     mypetsc[] in order to get the same
> >     ordering of the
> >      >      >     application
> >      >      >      >      >     within PETSC?
> >      >      >      >      > Are you asking if the identity permutation
> >     can be
> >      >     constructed
> >      >      >      >     using the
> >      >      >      >      > same array twice? Yes.
> >      >      >      >      >     And once I define the ordering so that
> >     the local
> >      >      >     vector and
> >      >      >      >     matrix are
> >      >      >      >      >     defined in PETSC as in my application,
> >     how can
> >      >     I use it to
> >      >      >      >     create the
> >      >      >      >      >     actual vector and matrix?
> >      >      >      >      > The vectors and matrices do not change. The
> >     AO is a
> >      >      >     permutation.
> >      >      >      >     You can
> >      >      >      >      > use it to permute
> >      >      >      >      > a vector into another order, or to convert
> >     on index to
> >      >      >     another.
> >      >      >      >      >    Thanks,
> >      >      >      >      >        Matt
> >      >      >      >      >     Thanks in advance for the help.
> >      >      >      >      >     Cheers,
> >      >      >      >      >     Enrico
> >      >      >      >      >     On 18/10/2023 13:39, Matthew Knepley
> wrote:
> >      >      >      >      >      > On Wed, Oct 18, 2023 at 5:55 AM Enrico
> >     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>>>>> wrote:
> >      >      >      >      >      >     Hello,
> >      >      >      >      >      >     I'm trying to use Petsc to solve
> >     a linear
> >      >      >     system in an
> >      >      >      >      >     application. I'm
> >      >      >      >      >      >     using the coordinate format to
> >     define the
> >      >      >     matrix and the
> >      >      >      >      >     vector (it
> >      >      >      >      >      >     should work better on GPU but at
> >     the moment
> >      >      >     every test
> >      >      >      >     is on
> >      >      >      >      >     CPU).
> >      >      >      >      >      >     After
> >      >      >      >      >      >     the call to VecSetValuesCOO, I've
> >      >     noticed that the
> >      >      >      >     vector is
> >      >      >      >      >     storing
> >      >      >      >      >      >     the
> >      >      >      >      >      >     data in a different way from my
> >      >     application. For
> >      >      >      >     example with two
> >      >      >      >      >      >     processes in the application
> >      >      >      >      >      >     process 0 owns cells 2, 3, 4
> >      >      >      >      >      >     process 1 owns cells 0, 1, 5
> >      >      >      >      >      >     But in the vector data structure
> >     of Petsc
> >      >      >      >      >      >     process 0 owns cells 0, 1, 2
> >      >      >      >      >      >     process 1 owns cells 3, 4, 5
> >      >      >      >      >      >     This is in principle not a big
> issue,
> >      >     but after
> >      >      >      >     solving the
> >      >      >      >      >     linear
> >      >      >      >      >      >     system I get the solution vector
> >     x and I
> >      >     want
> >      >      >     to get the
> >      >      >      >      >     values in the
> >      >      >      >      >      >     correct processes. Is there a way
> >     to get
> >      >     vector
> >      >      >     values
> >      >      >      >     from other
> >      >      >      >      >      >     processes or to get a mapping so
> >     that I
> >      >     can do
> >      >      >     it myself?
> >      >      >      >      >      > By definition, PETSc vectors and
> >     matrices own
> >      >      >     contiguous row
> >      >      >      >      >     blocks. If
> >      >      >      >      >      > you want to have another,
> >      >      >      >      >      > global ordering, we support that with
> >     https://petsc.org/main/manualpages/AO/
> >     <https://petsc.org/main/manualpages/AO/>
> >     <https://petsc.org/main/manualpages/AO/>>
> >     <https://petsc.org/main/manualpages/AO/>>>
> >     <https://petsc.org/main/manualpages/AO/>>>>
> >     <https://petsc.org/main/manualpages/AO/>>>>>
> >     <https://petsc.org/main/manualpages/AO/>>>>>>
> >      >      >      >      >      >    Thanks,
> >      >      >      >      >      >       Matt
> >      >      >      >      >      >     Cheers,
> >      >      >      >      >      >     Enrico Degregori
> >      >      >      >      >      > What most experimenters take for
> >     granted before
> >      >      >     they begin
> >      >      >      >     their
> >      >      >      >      >      > experiments is infinitely more
> >     interesting
> >      >     than any
> >      >      >      >     results to which
> >      >      >      >      >      > their experiments lead.
> >      >      >      >      >      > -- Norbert Wiener
> >      >      >      >      >      > https://www.cse.buffalo.edu/~knepley/
> >     <https://www.cse.buffalo.edu/~knepley/>
> >     <https://www.cse.buffalo.edu/~knepley/>>
> >     <https://www.cse.buffalo.edu/~knepley/>>>
> >     <https://www.cse.buffalo.edu/~knepley/>>>>
> >     <https://www.cse.buffalo.edu/~knepley/>>>>>
> >      >      >      >      >     <http://www.cse.buffalo.edu/~knepley/
> >     <http://www.cse.buffalo.edu/~knepley/>
> >     <http://www.cse.buffalo.edu/~knepley/>>
> >     <http://www.cse.buffalo.edu/~knepley/>>>
> >     <http://www.cse.buffalo.edu/~knepley/>>>>
> >     <http://www.cse.buffalo.edu/~knepley/>>>>>>
> >      >      >      >      > What most experimenters take for granted
> before
> >      >     they begin
> >      >      >     their
> >      >      >      >      > experiments is infinitely more interesting
> >     than any
> >      >      >     results to which
> >      >      >      >      > -- Norbert Wiener
> >      >      >      > What most experimenters take for granted before
> >     they begin
> >      >     their
> >      >      >      > experiments is infinitely more interesting than any
> >      >     results to which
> >      >      >      > -- Norbert Wiener
> >      >      > What most experimenters take for granted before they begin
> >     their
> >     results to which
> >      >      > -- Norbert Wiener
> >      > What most experimenters take for granted before they begin their
> >      > experiments is infinitely more interesting than any results to
> which
> >      > -- Norbert Wiener
> > experiments is infinitely more interesting than any results to which
> > -- Norbert Wiener
> > https://www.cse.buffalo.edu/~knepley/ <
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231019/aab6103c/attachment-0001.html>
