[petsc-users] Coordinate format internal reordering
Enrico degregori at dkrz.de
Thu Oct 19 12:00:44 CDT 2023
Here is a very very simple reproducer of my problem. It is a fortran
program and it has to run with 2 processes.
The output is:
  process             0 : xx_v(            1 ) =     0.000000000000000
  process             0 : xx_v(            2 ) =     1.000000000000000
  process             0 : xx_v(            3 ) =     2.000000000000000
  process             1 : xx_v(            1 ) =     3.000000000000000
  process             1 : xx_v(            2 ) =     4.000000000000000
  process             1 : xx_v(            3 ) =     5.000000000000000
and I would like to have:
  process             0 : xx_v(            1 ) =     2.000000000000000
  process             0 : xx_v(            2 ) =     3.000000000000000
  process             0 : xx_v(            3 ) =     4.000000000000000
  process             1 : xx_v(            1 ) =     0.000000000000000
  process             1 : xx_v(            2 ) =     1.000000000000000
How can I do that?
program main
#include <petsc/finclude/petscksp.h>
     use petscksp
     implicit none
     PetscErrorCode ierr
     PetscInt  :: Psize = 6
     integer  :: Lsize
     PetscInt  :: work_size
     PetscInt  :: work_rank
     Vec :: b
     integer, allocatable, dimension(:) :: glb_index
     double precision, allocatable, dimension(:) :: array
     PetscScalar, pointer :: xx_v(:)
     integer :: i
     PetscCount :: csize
     CALL PetscInitialize(ierr)
     Lsize = 3
     csize = Lsize
     allocate(glb_index(0:Lsize-1), array(0:Lsize-1))
     CALL MPI_Comm_size(PETSC_COMM_WORLD, work_size, ierr);
     CALL MPI_Comm_rank(PETSC_COMM_WORLD, work_rank, ierr);
     if (work_rank == 0) then
       glb_index(0) = 2
       glb_index(1) = 3
       glb_index(2) = 4
       array(0) = 2
       array(1) = 3
       array(2) = 4
     else if (work_rank == 1) then
       glb_index(0) = 0
       glb_index(1) = 1
       glb_index(2) = 5
       array(0) = 0
       array(1) = 1
       array(2) = 5
     end if
     ! Create and fill rhs vector
     CALL VecCreate(PETSC_COMM_WORLD, b, ierr);
     CALL VecSetSizes(b, Lsize, Psize, ierr);
     CALL VecSetType(b, VECMPI, ierr);
     CALL VecSetPreallocationCOO(b, csize, glb_index, ierr)
     CALL VecSetValuesCOO(b, array, INSERT_VALUES, ierr)
     CALL VecGetArrayReadF90(b, xx_v, ierr)
     do i=1,Lsize
       write(*,*) 'process ', work_rank, ': xx_v(',i,') = ', xx_v(i)
     end do
     CALL VecRestoreArrayReadF90(b, xx_v, ierr)
     deallocate(glb_index, array)
     CALL VecDestroy(b,ierr)
     CALL PetscFinalize(ierr)
end program main
On 19/10/2023 17:36, Matthew Knepley wrote:
> On Thu, Oct 19, 2023 at 11:33 AM Enrico <degregori at dkrz.de
> <mailto:degregori at dkrz.de>> wrote:
>     The layout is not poor, just the global indices are not contiguous,this
>     has nothing to do with the local memory layout which is extremely
>     optimized for different architectures. I can not change the layout
>     anyway because it's a climate model with a million lines of code.
>     I don't understand why Petsc is doing all this MPI communication under
>     the hood.
> I don't think we are communicating under the hood.
>     I mean, it is changing the layout of the application and doing
>     a lot of communication.
> We do not create the layout. The user creates the data layout when they
> create a vector or matrix.
>     Is there no way to force the same layout and
>     provide info about how to do the halo exchange? In this way I can have
>     the same memory layout and there is no communication when I fill or
>     fetch the vectors and the matrix.
> Yes, you tell the vector/matrix your data layout when you create it.
>    Thanks,
>        Matt
>     Cheers,
>     Enrico
>     On 19/10/2023 17:21, Matthew Knepley wrote:
>      > On Thu, Oct 19, 2023 at 10:51 AM Enrico <degregori at dkrz.de
>      > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>> wrote:
>      >     In the application the storage is contiguous but the global
>     indexing is
>      >     not. I would like to use AO as a translation layer but I don't
>      >     understand it.
>      > Why would you choose to index differently from your storage?
>      >     My case is actually simple even if it is in a large
>     application, I have
>      >     Mat A, Vec b and Vec x
>      >     After calling KSPSolve, I use VecGetArrayReadF90 to get a
>     pointer to
>      >     the
>      >     data and they are in the wrong ordering, so for example the first
>      >     element of the solution array on process 0 belongs to process
>     1 in the
>      >     application.
>      > Again, this seems to be a poor choice of layout. What we
>     typically do is
>      > to partition
>      > the data into chunks owned by each process first.
>      >     Is it at this point that I should use the AO translation
>     layer? This
>      >     would be quite bad, it means to build Mat A and Vec b there
>     is MPI
>      >     communication and also to get the data of Vec x back in the
>     application.
>      > If you want to store data that process i updates on process j,
>     this will
>      > need communication.
>      >     Anyway, I've tried to use AOPetscToApplicationPermuteReal on the
>      >     solution array but it doesn't work as I would like. Is this
>     function
>      >     suppose to do MPI communication between processes and fetch
>     the values
>      >     of the application ordering?
>      > There is no communication here. That function call just changes one
>      > integer into another.
>      > If you want to update values on another process, we recommend using
>      > VecScatter() or
>      > MatSetValues(), both of which take global indices and do
>     communication
>      > if necessary.
>      >    Thanks,
>      >      Matt
>      >     Cheers,
>      >     Enrico
>      >     On 19/10/2023 15:25, Matthew Knepley wrote:
>      >      > On Thu, Oct 19, 2023 at 8:57 AM Enrico <degregori at dkrz.de
>      >      > <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>
>     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>> wrote:
>      >      >     Maybe I wasn't clear enough. I would like to
>     completely get
>      >     rid of
>      >      >     Petsc
>      >      >     ordering because I don't want extra communication between
>      >     processes to
>      >      >     construct the vector and the matrix (since I have to fill
>      >     them every
>      >      >     time step because I'm just using the linear solver
>     with a Mat
>      >     and a Vec
>      >      >     data structure). I don't understand how I can do that.
>      >      > Any program you write to do linear algebra will have
>     contiguous
>      >     storage
>      >      > because it
>      >      > is so much faster. Contiguous indexing makes sense for
>     contiguous
>      >      > storage. If you
>      >      > want to use non-contiguous indexing for contiguous
>     storage, you
>      >     would
>      >      > need some
>      >      > translation layer. The AO is such a translation, but you
>     could do
>      >     this
>      >      > any way you want.
>      >      >    Thanks,
>      >      >       Matt
>      >      >     My initial idea was to create another global index
>     ordering
>      >     within my
>      >      >     application to use only for the Petsc interface but then I
>      >     think that
>      >      >     the ghost cells are wrong.
>      >      >     On 19/10/2023 14:50, Matthew Knepley wrote:
>      >      >      > On Thu, Oct 19, 2023 at 6:51 AM Enrico
>     <degregori at dkrz.de <mailto:degregori at dkrz.de>
>      >      >      > <mailto:degregori at dkrz.de
>     <mailto:degregori at dkrz.de> <mailto:degregori at dkrz.de
>     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>>> wrote:
>      >      >      >     Hello,
>      >      >      >     if I create an application ordering using
>      >     AOCreateBasic, should I
>      >      >      >     provide the same array for const PetscInt
>     myapp[] and
>      >     const
>      >      >     PetscInt
>      >      >      >     mypetsc[] in order to get the same ordering of the
>      >     application
>      >      >      >     within PETSC?
>      >      >      > Are you asking if the identity permutation can be
>     constructed
>      >      >     using the
>      >      >      > same array twice? Yes.
>      >      >      >     And once I define the ordering so that the local
>      >     vector and
>      >      >     matrix are
>      >      >      >     defined in PETSC as in my application, how can
>     I use it to
>      >      >     create the
>      >      >      >     actual vector and matrix?
>      >      >      > The vectors and matrices do not change. The AO is a
>      >     permutation.
>      >      >     You can
>      >      >      > use it to permute
>      >      >      > a vector into another order, or to convert on index to
>      >     another.
>      >      >      >    Thanks,
>      >      >      >        Matt
>      >      >      >     Thanks in advance for the help.
>      >      >      >     Cheers,
>      >      >      >     Enrico
>      >      >      >     On 18/10/2023 13:39, Matthew Knepley wrote:
>      >      >      >      > On Wed, Oct 18, 2023 at 5:55 AM Enrico
>      >      >      >      > <mailto:degregori at dkrz.de
>     <mailto:degregori at dkrz.de <mailto:degregori at dkrz.de>>>>>> wrote:
>      >      >      >      >     Hello,
>      >      >      >      >     I'm trying to use Petsc to solve a linear
>      >     system in an
>      >      >      >     application. I'm
>      >      >      >      >     using the coordinate format to define the
>      >     matrix and the
>      >      >      >     vector (it
>      >      >      >      >     should work better on GPU but at the moment
>      >     every test
>      >      >     is on
>      >      >      >     CPU).
>      >      >      >      >     After
>      >      >      >      >     the call to VecSetValuesCOO, I've
>     noticed that the
>      >      >     vector is
>      >      >      >     storing
>      >      >      >      >     the
>      >      >      >      >     data in a different way from my
>     application. For
>      >      >     example with two
>      >      >      >      >     processes in the application
>      >      >      >      >     process 0 owns cells 2, 3, 4
>      >      >      >      >     process 1 owns cells 0, 1, 5
>      >      >      >      >     But in the vector data structure of Petsc
>      >      >      >      >     process 0 owns cells 0, 1, 2
>      >      >      >      >     process 1 owns cells 3, 4, 5
>      >      >      >      >     This is in principle not a big issue,
>     but after
>      >      >     solving the
>      >      >      >     linear
>      >      >      >      >     system I get the solution vector x and I
>     want
>      >     to get the
>      >      >      >     values in the
>      >      >      >      >     correct processes. Is there a way to get
>     vector
>      >     values
>      >      >     from other
>      >      >      >      >     processes or to get a mapping so that I
>     can do
>      >     it myself?
>      >      >      >      > By definition, PETSc vectors and matrices own
>      >     contiguous row
>      >      >      >     blocks. If
>      >      >      >      > you want to have another,
>      >      >      >      > global ordering, we support that with
>      >      >      >      > https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>
>     <https://petsc.org/main/manualpages/AO/>>
>      >      >     <https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>>>
>      >      >      >     <https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>>>>
>      >      >      >      > <https://petsc.org/main/manualpages/AO/
>     <https://petsc.org/main/manualpages/AO/>>>>>
>      >      >      >      >    Thanks,
>      >      >      >      >       Matt
>      >      >      >      >     Cheers,
>      >      >      >      >     Enrico Degregori
>      >      >      >      > What most experimenters take for granted before
>      >     they begin
>      >      >     their
>      >      >      >      > experiments is infinitely more interesting
>     than any
>      >      >     results to which
>      >      >      >      > their experiments lead.
>      >      >      >      > -- Norbert Wiener
>      >      >      >      > https://www.cse.buffalo.edu/~knepley/
>     <https://www.cse.buffalo.edu/~knepley/>
>     <https://www.cse.buffalo.edu/~knepley/>>
>      >      >     <https://www.cse.buffalo.edu/~knepley/
>     <https://www.cse.buffalo.edu/~knepley/>>>
>      >      >      >     <https://www.cse.buffalo.edu/~knepley/
>     <https://www.cse.buffalo.edu/~knepley/>>>>
>      >      >      >     <http://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/~knepley/>
>     <http://www.cse.buffalo.edu/~knepley/>>
>     <http://www.cse.buffalo.edu/~knepley/>>>
>     <http://www.cse.buffalo.edu/~knepley/>>>>>
>     they begin
>      >     their
>      >      >      > experiments is infinitely more interesting than any
>      >     results to which
>      >      > What most experimenters take for granted before they begin
>     their
>     results to which
>      >      > -- Norbert Wiener
>      > What most experimenters take for granted before they begin their
>      > experiments is infinitely more interesting than any results to which
>      > -- Norbert Wiener
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
