[petsc-users] Error when installing PETSc
Gong Yujie yc17470 at connect.um.edu.mo
Wed Oct 18 05:06:38 CDT 2023
Dear PETSc developers,
I got an error message when installing PETSc with a clang compiler. Could you please help me find the problem? The configure.log is attached.
Best Regards,
Yujie
Here is the detail of the error:
                      Configuring PETSc to compile on your system
***** WARNING: Using default optimization C flags -g -O3
You might consider manually setting optimal optimization flags for your system with
COPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples
***** WARNING: Using default Cxx optimization flags -g -O3
CXXOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples
***** WARNING: Using default FORTRAN optimization flags -O
FOPTFLAGS="optimization flags" see config/examples/arch-*-opt.py for examples
Trying to download https://download.open-mpi.org/release/open-mpi/v4.1/openmpi-4.1.0.tar.gz for
Running configure on OPENMPI; this may take several minutes
Running make on OPENMPI; this may take several minutes
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Error running make; make install on OPENMPI
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231018/0b70fb4a/attachment-0001.html>
Desc: configure.log
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231018/0b70fb4a/attachment-0001.obj>
