[petsc-users] Parallel DMPlex
erdemguer
erdemguer at proton.me
Fri Oct 13 06:26:39 CDT 2023
Hi, unfortunately it's me again.
I have some weird troubles with creating matrix with DMPlex. Actually I might not need to create matrix explicitly, but SNESSolve crashes at there too. So, I updated the code you provided. When I tried to use DMCreateMatrix() at first, I got an error "Unknown discretization type for field 0" at first I applied DMSetLocalSection() and this error is gone. But this time when I run the code with multiple processors, sometimes I got an output like:
Before Distribution Rank: 0, cStart: 0, cEndInterior: 27, cEnd: 27
Before Distribution Rank: 1, cStart: 0, cEndInterior: 0, cEnd: 0
[1] ghost cell 14
[1] ghost cell 15
[1] ghost cell 16
[1] ghost cell 17
[1] ghost cell 18
[1] ghost cell 19
[1] ghost cell 20
[1] ghost cell 21
[1] ghost cell 22
After Distribution Rank: 1, cStart: 0, cEndInterior: 14, cEnd: 23
[0] ghost cell 13
[0] ghost cell 14
[0] ghost cell 15
[0] ghost cell 16
[0] ghost cell 17
[0] ghost cell 18
[0] ghost cell 19
[0] ghost cell 20
[0] ghost cell 21
[0] ghost cell 22
[0] ghost cell 23
After Distribution Rank: 0, cStart: 0, cEndInterior: 13, cEnd: 24
Fatal error in internal_Waitall: Unknown error class, error stack:
internal_Waitall(82)......................: MPI_Waitall(count=1, array_of_requests=0xaaaaf5f72264, array_of_statuses=0x1) failed
MPIR_Waitall(1099)........................:
MPIR_Waitall_impl(1011)...................:
MPIR_Waitall_state(976)...................:
MPIDI_CH3i_Progress_wait(187).............: an error occurred while handling an event returned by MPIDI_CH3I_Sock_Wait()
MPIDI_CH3I_Progress_handle_sock_event(411):
ReadMoreData(744).........................: ch3|sock|immedread 0xffff8851c5c0 0xaaaaf5e81cd0 0xaaaaf5e8a880MPIDI_CH3I_Sock_readv(2553)...............: the supplied buffer contains invalid memory (set=0,sock=1,errno=14:Bad address)
Sometimes the error message isn't appearing but for example I'm trying to print size of the matrix but it isn't working.
If necessary, my Configure options --download-mpich --download-hwloc --download-pastix --download-hypre --download-ml --download-ctetgen --download-triangle --download-exodusii --download-netcdf --download-zlib --download-pnetcdf --download-ptscotch --download-hdf5 --with-cc=clang-16 --with-cxx=clang++-16 COPTFLAGS="-g -O2" CXXOPTFLAGS="-g -O2" FOPTFLAGS="-g -O2" --with-debugging=1
Version: Petsc Release Version 3.20.0
Thank you,
Guer
Sent with [Proton Mail](https://proton.me/) secure email.
------- Original Message -------
On Thursday, October 12th, 2023 at 12:59 AM, erdemguer <erdemguer at proton.me> wrote:
> Thank you! That's exactly what I need.
> On Wednesday, October 11th, 2023 at 4:17 PM, Matthew Knepley <knepley at gmail.com> wrote:
>> On Wed, Oct 11, 2023 at 4:42 AM erdemguer <erdemguer at proton.me> wrote:
>>> Hi again,
>> I see the problem. FV ghosts mean extra boundary cells added in FV methods using DMPlexCreateGhostCells() in order to impose boundary conditions. They are not the "ghost" cells for overlapping parallel decompositions. I have changed your code to give you what you want. It is attached.
>> Thanks,
>> Matt
>>> Here is my code:
>>> #include <petsc.h>
>>> static char help[] = "dmplex";
>>> int main(int argc, char **argv)
>>> PetscCall(PetscInitialize(&argc, &argv, NULL, help));
>>> DM dm, dm_dist;
>>> PetscSection section;
>>> PetscInt cStart, cEndInterior, cEnd, rank;
>>> PetscInt nc[3] = {3, 3, 3};
>>> PetscReal upper[3] = {1, 1, 1};
>>> PetscCallMPI(MPI_Comm_rank(PETSC_COMM_WORLD, &rank));
>>> DMPlexCreateBoxMesh(PETSC_COMM_WORLD, 3, PETSC_FALSE, nc, NULL, upper, NULL, PETSC_TRUE, &dm);
>>> DMViewFromOptions(dm, NULL, "-dm1_view");
>>> PetscCall(DMSetFromOptions(dm));
>>> DMViewFromOptions(dm, NULL, "-dm2_view");
>>> PetscCall(DMPlexGetDepthStratum(dm, 3, &cStart, &cEnd));
>>> DMPlexComputeCellTypes(dm);
>>> PetscCall(DMPlexGetCellTypeStratum(dm, DM_POLYTOPE_INTERIOR_GHOST, &cEndInterior, NULL));
>>> PetscPrintf(PETSC_COMM_SELF, "Before Distribution Rank: %d, cStart: %d, cEndInterior: %d, cEnd: %d\n", rank, cStart,
>>> cEndInterior, cEnd);
>>> PetscInt nField = 1, nDof = 3, field = 0;
>>> PetscCall(PetscSectionCreate(PETSC_COMM_WORLD, §ion));
>>> PetscSectionSetNumFields(section, nField);
>>> PetscCall(PetscSectionSetChart(section, cStart, cEnd));
>>> for (PetscInt p = cStart; p < cEnd; p++)
>>> PetscCall(PetscSectionSetFieldDof(section, p, field, nDof));
>>> PetscCall(PetscSectionSetDof(section, p, nDof));
>>> PetscCall(PetscSectionSetUp(section));
>>> DMSetLocalSection(dm, section);
>>> DMViewFromOptions(dm, NULL, "-dm3_view");
>>> DMSetAdjacency(dm, field, PETSC_TRUE, PETSC_TRUE);
>>> DMViewFromOptions(dm, NULL, "-dm4_view");
>>> PetscCall(DMPlexDistribute(dm, 1, NULL, &dm_dist));
>>> if (dm_dist)
>>> DMDestroy(&dm);
>>> dm = dm_dist;
>>> DMViewFromOptions(dm, NULL, "-dm5_view");
>>> PetscCall(DMPlexGetCellTypeStratum(dm, DM_POLYTOPE_FV_GHOST, &cEndInterior, NULL));
>>> PetscPrintf(PETSC_COMM_SELF, "After Distribution Rank: %d, cStart: %d, cEndInterior: %d, cEnd: %d\n", rank, cStart,
>>> DMDestroy(&dm);
>>> PetscCall(PetscFinalize());}
>>> This codes output is currently (on 2 processors) is:
>>> Before Distribution Rank: 1, cStart: 0, cEndInterior: -1, cEnd: 14
>>> Before Distribution Rank: 0, cStart: 0, cEndInterior: -1, cEnd: 13
>>> After Distribution Rank: 0, cStart: 0, cEndInterior: -1, cEnd: 27After Distribution Rank: 1, cStart: 0, cEndInterior: -1, cEnd: 24
>>> DMView outputs:
>>> dm1_view (after creation):
>>> DM Object: 2 MPI processes
>>> type: plex
>>> DM_0x84000004_0 in 3 dimensions:
>>> Number of 0-cells per rank: 64 0
>>> Number of 1-cells per rank: 144 0
>>> Number of 2-cells per rank: 108 0
>>> Number of 3-cells per rank: 27 0
>>> Labels:
>>> marker: 1 strata with value/size (1 (218))
>>> Face Sets: 6 strata with value/size (6 (9), 5 (9), 3 (9), 4 (9), 1 (9), 2 (9))
>>> depth: 4 strata with value/size (0 (64), 1 (144), 2 (108), 3 (27)) celltype: 4 strata with value/size (7 (27), 0 (64), 4 (108), 1 (144))
>>> dm2_view (after setfromoptions):
>>> type: plex
>>> Number of 0-cells per rank: 40 46
>>> Number of 1-cells per rank: 83 95
>>> Number of 2-cells per rank: 57 64
>>> Number of 3-cells per rank: 13 14
>>> Labels:
>>> depth: 4 strata with value/size (0 (40), 1 (83), 2 (57), 3 (13))
>>> marker: 1 strata with value/size (1 (109))
>>> Face Sets: 5 strata with value/size (1 (6), 2 (1), 3 (7), 5 (5), 6 (4)) celltype: 4 strata with value/size (0 (40), 1 (83), 4 (57), 7 (13))
>>> dm3_view (after setting local section):
>>> type: plex
>>> Labels:
>>> Field Field_0: adjacency FEM
>>> dm4_view (after setting adjacency):
>>> type: plex
>>> Labels:
>>> Field Field_0: adjacency FVM++
>>> dm5_view (after distribution):
>>> DM Object: Parallel Mesh 2 MPI processes
>>> type: plex
>>> Parallel Mesh in 3 dimensions:
>>> Number of 0-cells per rank: 64 60
>>> Number of 1-cells per rank: 144 133
>>> Number of 2-cells per rank: 108 98
>>> Number of 3-cells per rank: 27 24
>>> Labels:
>>> Face Sets: 6 strata with value/size (1 (9), 2 (9), 3 (9), 4 (9), 5 (9), 6 (9))
>>> celltype: 4 strata with value/size (0 (64), 1 (144), 4 (108), 7 (27))
>>> Thanks,
>>> Guer.
>>> On Wednesday, October 11th, 2023 at 3:33 AM, Matthew Knepley <knepley at gmail.com> wrote:
>>>> On Tue, Oct 10, 2023 at 7:01 PM erdemguer <erdemguer at proton.me> wrote:
>>>>> Hi,
>>>>> Sorry for my late response. I tried with your suggestions and I think I made a progress. But I still got issues. Let me explain my latest mesh routine:
>>>>> - DMPlexCreateBoxMesh
>>>>> - DMSetFromOptions
>>>>> - PetscSectionCreate
>>>>> - PetscSectionSetNumFields
>>>>> - PetscSectionSetFieldDof
>>>>> - PetscSectionSetDof
>>>>> - PetscSectionSetUp
>>>>> - DMSetLocalSection
>>>>> - DMSetAdjacency
>>>>> - DMPlexDistribute
>>>>> It's still not working but it's promising, if I call DMPlexGetDepthStratum for cells, I can see that after distribution processors have more cells.
>>>> Please send the output of DMPlexView() for each incarnation of the mesh. What I do is put
>>>> with a different string after each call.
>>>>> But I couldn't figure out how to decide where the ghost/processor boundary cells start.
>>>> Please send the actual code because the above is not specific enough. For example, you will not have
>>>> "ghost cells" unless you partition with overlap. This is because by default cells are the partitioned quantity,
>>>> so each process gets a unique set.
>>>> Thanks,
>>>> Matt
>>>>> In older mails I saw there is a function DMPlexGetHybridBounds but I think that function is deprecated. I tried to use, DMPlexGetCellTypeStratumas in ts/tutorials/ex11_sa.c but I'm getting -1 as cEndInterior before and after distribution. I tried it for DM_POLYTOPE_FV_GHOST, DM_POLYTOPE_INTERIOR_GHOST polytope types. I also tried calling DMPlexComputeCellTypes before DMPlexGetCellTypeStratum but nothing changed. I think I can calculate the ghost cell indices using cStart/cEnd before & after distribution but I think there is a better way I'm currently missing.
>>>>> Thanks again,
>>>>> Guer.
>>>>> On Thursday, September 28th, 2023 at 10:42 PM, Matthew Knepley <knepley at gmail.com> wrote:
>>>>>> On Thu, Sep 28, 2023 at 3:38 PM erdemguer via petsc-users <petsc-users at mcs.anl.gov> wrote:
>>>>>>> Hi,
>>>>>>> I am currently using DMPlex in my code. It runs serially at the moment, but I'm interested in adding parallel options. Here is my workflow:
>>>>>>> Create a DMPlex mesh from GMSH.
>>>>>>> Reorder it with DMPlexPermute.
>>>>>>> Create necessary pre-processing arrays related to the mesh/problem.
>>>>>>> Create field(s) with multi-dofs.
>>>>>>> Create residual vectors.
>>>>>>> Define a function to calculate the residual for each cell and, use SNES.
>>>>>>> As you can see, I'm not using FV or FE structures (most examples do). Now, I'm trying to implement this in parallel using a similar approach. However, I'm struggling to understand how to create corresponding vectors and how to obtain index sets for each processor. Is there a tutorial or paper that covers this topic?
>>>>>> The intention was that there is enough information in the manual to do this.
>>>>>> Using PetscFE/PetscFV is not required. However, I strongly encourage you to use PetscSection. Without this, it would be incredibly hard to do what you want. Once the DM has a Section, it can do things like automatically create vectors and matrices for you. It can redistribute them, subset them, etc. The Section describes how dofs are assigned to pieces of the mesh (mesh points). This is in the manual, and there are a few examples that do it by hand.
>>>>>> So I suggest changing your code to use PetscSection, and then letting us know if things still do not work.
>>>>>> Thanks,
>>>>>> Matt
>>>>>>> Thank you.
>>>>>>> Guer.
>>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>>> -- Norbert Wiener
>>>>>> [https://www.cse.buffalo.edu/~knepley/](http://www.cse.buffalo.edu/~knepley/)
>>>> -- Norbert Wiener
>> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231013/58852418/attachment-0001.html>
An embedded and charset-unspecified text was scrubbed...
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231013/58852418/attachment-0001.c>
