[petsc-users] SLEPc/NEP for shell matrice T(lambda) and T'(lambda)
Kenneth C Hall
kenneth.c.hall at duke.edu
Thu Oct 12 13:59:34 CDT 2023
Jose,
Thanks very much for this. I will give it a try and let you know how it works.
Best regards,
Kenneth
Date: Thursday, October 12, 2023 at 2:12 PM
To: Kenneth C Hall <kenneth.c.hall at duke.edu>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] SLEPc/NEP for shell matrice T(lambda) and T'(lambda)
I am attaching your example modified with the context stuff.
With the PETSc branch that I indicated, now it works with NLEIGS, for instance:
$ ./test_nep -nep_nleigs_ksp_type gmres -nep_nleigs_pc_type none -rg_interval_endpoints 0.2,1.1 -nep_target 0.8 -nep_nev 5 -n 400 -nep_monitor -nep_view -nep_error_relative ::ascii_info_detail
And also other solvers such as SLP:
$ ./test_nep -nep_type slp -nep_slp_ksp_type gmres -nep_slp_pc_type none -nep_target 0.8 -nep_nev 5 -n 400 -nep_monitor -nep_error_relative ::ascii_info_detail
I will clean the example code an add it as a SLEPc example.
Jose
> El 11 oct 2023, a las 17:27, Kenneth C Hall <kenneth.c.hall at duke.edu> escribió:
> Jose,
> Thanks very much for your help with this. Greatly appreciated. I will look at the MR. Please let me know if you do get the Fortran example working.
> Thanks, and best regards,
> Kenneth
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231012/0b3ca979/attachment.html>
