[petsc-users] Compilation failure of PETSc with "The procedure name of the INTERFACE block conflicts with a name in the encompassing scoping unit"
Wed Oct 11 06:07:25 CDT 2023
On Wed, Oct 11, 2023 at 4:22 AM Richter, Roland <Roland.Richter at empa.ch>
wrote:
> Hei,
> following my last question I managed to configure PETSc with Intel MPI and
> Intel OneAPI using the following configure-line:
> *./configure --prefix=/media/storage/local_opt/petsc
> --with-scalar-type=complex --with-cc=mpiicc --with-cxx=mpiicpc
> --CPPFLAGS="-fPIC -march=native -mavx2" --CXXFLAGS="-fPIC -march=native
> -mavx2" --with-fc=mpiifort --with-pic=true --with-mpi=true
> --with-blaslapack-dir=/opt/intel/oneapi/mkl/latest/lib/intel64/
> --with-openmp=true --download-hdf5=yes --download-netcdf=yes
> --download-chaco=no --download-metis=yes --download-slepc=yes
> --download-suitesparse=yes --download-eigen=yes --download-parmetis=yes
> --download-ptscotch=yes --download-mumps=yes --download-scalapack=yes
> --download-superlu=yes --download-superlu_dist=yes --with-mkl_pardiso=1
> --with-boost=1 --with-boost-dir=/media/storage/local_opt/boost
> --download-opencascade=yes --with-fftw=1
> --with-fftw-dir=/media/storage/local_opt/fftw3 --download-kokkos=yes
> --with-mkl_sparse=1 --with-mkl_cpardiso=1 --with-mkl_sparse_optimize=1
> --download-muparser=yes --download-p4est=yes --download-sowing=yes
> --download-viennalcl=yes --with-zlib --force=1 --with-clean=1 --with-cuda=0*
> Now, however, compilation fails with the following error:
> /home/user/Downloads/git-files/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90(699):
> error #6623: The procedure name of the INTERFACE block conflicts with a
> name in the encompassing scoping unit.   [PCGASMCREATESUBDOMAINS2D]
>       subroutine PCGASMCreateSubdomains2D(a,b,c,d,e,f,g,h,i,j,z)
> /home/user/Downloads/git-files/petsc/include/../src/ksp/f90-mod/ftn-auto-interfaces/petscpc.h90(1199):
> name in the encompassing scoping unit.   [PCASMCREATESUBDOMAINS2D]
>       subroutine PCASMCreateSubdomains2D(a,b,c,d,e,f,g,h,i,z)
> I'm on the latest version of origin/main, but can't figure out how to fix
> that issue by myself. Therefore, I'd appreciate additional insight.
You have old build files in the tree. We changed the Fortran stubs to be
generated in the PETSC_ARCH tree so that you can build the stubs for
different branches in the same PETSc tree. You have old stubs in the src
tree. You can get rid of these using
  git clean -f -d -x
unless you have your own files in the source tree, in which case you need
to remove the ftn-auto-interfaces directories yourself.
     Matt
> Thanks!
> Regards,
> Roland Richter
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231011/43da6209/attachment.html>
