[petsc-users] FEM Implementation of NS with SUPG Stabilization
Wed Oct 11 06:02:42 CDT 2023
On Tue, Oct 10, 2023 at 9:34 PM Brandon Denton via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Good Evening,
> I am looking to implement a form of Navier-Stokes with SUPG Stabilization
> and shock capturing using PETSc's FEM infrastructure. In this
> implementation, I need access to the cell's shape function gradients and
> natural coordinate gradients for calculations within the point-wise
> residual calculations. How do I get these quantities at the quadrature
> points? The signatures for fo and f1 don't seem to contain this information.
Are you sure you need those? Darsh and I implemented SUPG without that. You
would need local second derivative information, which you can get using
-dm_ds_jet_degree 2. If you check in an example, I can go over it.
     Matt
> Thank you in advance for your time.
> Brandon
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231011/362e0aad/attachment.html>
