[petsc-users] Galerkin projection using petsc4py
Thanasis Boutsikakis thanasis.boutsikakis at corintis.com
Wed Oct 11 02:04:29 CDT 2023
Furthermore, I tried to perform the Galerkin projection in two steps by substituting
> A_prime = A.ptap(Phi)
With
AL = Phi.transposeMatMult(A)
A_prime = AL.matMult(Phi)
And running this with 3 procs, results to the false creation of a matrix AL that has 3 times bigger dimensions that it should (A is of size 100x100 and Phi of size 100x7):
MATRIX mpiaij AL [21x300]
Assembled
Partitioning for AL:
  Rank 0: Rows [0, 7)
  Rank 1: Rows [7, 14)
  Rank 2: Rows [14, 21)
And naturally, in another dimension incompatibility:
Traceback (most recent call last):
  File "/Users/boutsitron/petsc-experiments/mat_vec_multiplication2.py", line 85, in <module>
  File "petsc4py/PETSc/Mat.pyx", line 1492, in petsc4py.PETSc.Mat.matMult
petsc4py.PETSc.Error: error code 60
[2] MatMatMult() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:10053
[2] MatProduct_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9976
[2] MatProductSetFromOptions() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
[2] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:421
[2] Nonconforming object sizes
[2] Matrix dimensions of A and B are incompatible for MatProductType AB: A 21x300, B 100x7
Abort(1) on node 2 (rank 2 in comm 496): application called MPI_Abort(PYOP2_COMM_WORLD, 1) - process 2
[1] MatMatMult() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:10053
[1] MatProduct_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9976
[1] MatProductSetFromOptions() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
[1] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:421
[1] Nonconforming object sizes
[1] Matrix dimensions of A and B are incompatible for MatProductType AB: A 21x300, B 100x7
Abort(1) on node 1 (rank 1 in comm 496): application called MPI_Abort(PYOP2_COMM_WORLD, 1) - process 1
[0] MatMatMult() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:10053
[0] MatProduct_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9976
[0] MatProductSetFromOptions() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:541
[0] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:421
[0] Nonconforming object sizes
[0] Matrix dimensions of A and B are incompatible for MatProductType AB: A 21x300, B 100x7
Abort(1) on node 0 (rank 0 in comm 496): application called MPI_Abort(PYOP2_COMM_WORLD, 1) - process 0
> On 10 Oct 2023, at 23:33, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
> Hi all,
> Revisiting my code and the proposed solution from Pierre, I realized this works only in sequential. The reason is that PETSc partitions those matrices only row-wise, which leads to an error due to the mismatch between number of columns of A (non-partitioned) and the number of rows of Phi (partitioned).
> """Experimenting with PETSc mat-mat multiplication"""
> import time
> import numpy as np
> from colorama import Fore
> from firedrake import COMM_SELF, COMM_WORLD
> from firedrake.petsc import PETSc
> from mpi4py import MPI
> from numpy.testing import assert_array_almost_equal
> from utilities import Print
> nproc = COMM_WORLD.size
> rank = COMM_WORLD.rank
> def create_petsc_matrix(input_array, sparse=True):
>     """Create a PETSc matrix from an input_array
>     Args:
>         input_array (np array): Input array
>         partition_like (PETSc mat, optional): Petsc matrix. Defaults to None.
>         sparse (bool, optional): Toggle for sparese or dense. Defaults to True.
>     Returns:
>         PETSc mat: PETSc mpi matrix
>     # Check if input_array is 1D and reshape if necessary
>     assert len(input_array.shape) == 2, "Input array should be 2-dimensional"
>     global_rows, global_cols = input_array.shape
>     size = ((None, global_rows), (global_cols, global_cols))
>     # Create a sparse or dense matrix based on the 'sparse' argument
>     if sparse:
>         matrix = PETSc.Mat().createAIJ(size=size, comm=COMM_WORLD)
>     else:
>         matrix = PETSc.Mat().createDense(size=size, comm=COMM_WORLD)
>     matrix.setUp()
>     local_rows_start, local_rows_end = matrix.getOwnershipRange()
>     for counter, i in enumerate(range(local_rows_start, local_rows_end)):
>         # Calculate the correct row in the array for the current process
>         row_in_array = counter + local_rows_start
>         matrix.setValues(
>             i, range(global_cols), input_array[row_in_array, :], addv=False
>     # Assembly the matrix to compute the final structure
>     matrix.assemblyBegin()
>     matrix.assemblyEnd()
>     return matrix
> # EXP: Galerkin projection of an mpi PETSc matrix A with an mpi PETSc matrix Phi
> #  A' = Phi.T * A * Phi
> # [k x k] <- [k x m] x [m x m] x [m x k]
> m, k = 100, 7
> # Generate the random numpy matrices
> np.random.seed(0)  # sets the seed to 0
> A_np = np.random.randint(low=0, high=6, size=(m, m))
> Phi_np = np.random.randint(low=0, high=6, size=(m, k))
> # TEST: Galerking projection of numpy matrices A_np and Phi_np
> Aprime_np = Phi_np.T @ A_np @ Phi_np
> Print(f"MATRIX Aprime_np [{Aprime_np.shape[0]}x{Aprime_np.shape[1]}]")
> Print(f"{Aprime_np}")
> # Create A as an mpi matrix distributed on each process
> A = create_petsc_matrix(A_np, sparse=False)
> # Create Phi as an mpi matrix distributed on each process
> Phi = create_petsc_matrix(Phi_np, sparse=False)
> # Create an empty PETSc matrix object to store the result of the PtAP operation.
> # This will hold the result A' = Phi.T * A * Phi after the computation.
> A_prime = create_petsc_matrix(np.zeros((k, k)), sparse=False)
> # Perform the PtAP (Phi Transpose times A times Phi) operation.
> # In mathematical terms, this operation is A' = Phi.T * A * Phi.
> # A_prime will store the result of the operation.
> Here is the error
> MATRIX mpiaij A [100x100]
> Assembled
> Partitioning for A:
>   Rank 0: Rows [0, 34)
>   Rank 1: Rows [34, 67)
>   Rank 2: Rows [67, 100)
> MATRIX mpiaij Phi [100x7]
> Assembled
> Partitioning for Phi:
>   File "/Users/boutsitron/work/galerkin_projection.py", line 87, in <module>
>   File "petsc4py/PETSc/Mat.pyx", line 1525, in petsc4py.PETSc.Mat.ptap
> [0] MatPtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9896
> [0] MatProductSetFromOptions_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matproduct.c:435
> [0] MatProductSetFromOptions_MPIAIJ() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2372
> [0] MatProductSetFromOptions_MPIAIJ_PtAP() at /Users/boutsitron/firedrake/src/petsc/src/mat/impls/aij/mpi/mpimatmatmult.c:2266
> [0] Matrix local dimensions are incompatible, Acol (0, 100) != Prow (0,34)
> Any thoughts?
> Thanks,
> Thanos
>> On 5 Oct 2023, at 14:23, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>> This works Pierre. Amazing input, thanks a lot!
>>> On 5 Oct 2023, at 14:17, Pierre Jolivet <pierre at joliv.et> wrote:
>>> Not a petsc4py expert here, but you may to try instead:
>>> Thanks,
>>> Pierre
>>>> On 5 Oct 2023, at 2:02 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>>>> Thanks Pierre! So I tried this and got a segmentation fault. Is this supposed to work right off the bat or am I missing sth?
>>>> [0]PETSC ERROR: ------------------------------------------------------------------------
>>>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>>>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>>>> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
>>>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>>>> [0]PETSC ERROR: to get more information on the crash.
>>>> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
>>>> Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>>>> import time
>>>> import numpy as np
>>>> from utilities import (
>>>>     Print,
>>>>     create_petsc_matrix,
>>>>     print_matrix_partitioning,
>>>> m, k = 11, 7
>>>> Phi.PtAP(A, A_prime)
>>>>> On 5 Oct 2023, at 13:22, Pierre Jolivet <pierre at joliv.et> wrote:
>>>>> How about using ptap which will use MatPtAP?
>>>>> It will be more efficient (and it will help you bypass the issue).
>>>>> Thanks,
>>>>> Pierre
>>>>>> On 5 Oct 2023, at 1:18 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>>>>>> Sorry, forgot function create_petsc_matrix()
>>>>>> def create_petsc_matrix(input_array sparse=True):
>>>>>>     Args:
>>>>>>     Returns:
>>>>>>         PETSc mat: PETSc matrix
>>>>>>     if sparse:
>>>>>>     else:
>>>>>>     matrix.setUp()
>>>>>>         matrix.setValues(
>>>>>>     return matrix
>>>>>>> On 5 Oct 2023, at 13:09, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>>>>>>> Hi everyone,
>>>>>>> I am trying a Galerkin projection (see MFE below) and I cannot get the Phi.transposeMatMult(A, A1) work. The error is
>>>>>>>   File "petsc4py/PETSc/Mat.pyx", line 1514, in petsc4py.PETSc.Mat.transposeMatMult
>>>>>>> petsc4py.PETSc.Error: error code 56
>>>>>>> [0] MatTransposeMatMult() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:10135
>>>>>>> [0] MatProduct_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9989
>>>>>>> [0] No support for this operation for this object type
>>>>>>> [0] Call MatProductCreate() first
>>>>>>> Do you know if these exposed to petsc4py or maybe there is another way? I cannot get the MFE to work (neither in sequential nor in parallel)
>>>>>>> import time
>>>>>>> import numpy as np
>>>>>>>     Print,
>>>>>>> m, k = 11, 7
>>>>>>> A = create_petsc_matrix(A_np)
>>>>>>> Phi = create_petsc_matrix(Phi_np)
>>>>>>> A1 = create_petsc_matrix(np.zeros((k, m)))
>>>>>>> # Now A1 contains the result of Phi^T * A
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231011/ff123062/attachment-0001.html>
