[petsc-users] Configuration of PETSc with Intel OneAPI and Intel MPI fails
Richter, Roland
Roland.Richter at empa.ch
Wed Oct 11 01:44:48 CDT 2023
Hei,
Thank you very much for the answer! I looked it up, but petsc.org seems to
be a bit unstable here, quite often I can't reach petsc.org.
Roland Richter
-----Ursprüngliche Nachricht-----
Von: Satish Balay <balay at mcs.anl.gov>
Gesendet: mandag 9. oktober 2023 17:29
An: Barry Smith <bsmith at petsc.dev>
Cc: Richter, Roland <Roland.Richter at empa.ch>; petsc-users at mcs.anl.gov
Betreff: Re: [petsc-users] Configuration of PETSc with Intel OneAPI and
Intel MPI fails
Will note - OneAPI MPI usage is documented at
https://petsc.org/release/install/install/#mpi
Satish
On Mon, 9 Oct 2023, Barry Smith wrote:
> Instead of using the mpiicc -cc=icx style use -- with-cc=mpiicc (etc)
and
> export I_MPI_CC=icx
> export I_MPI_CXX=icpx
> export I_MPI_F90=ifx
> > On Oct 9, 2023, at 8:32 AM, Richter, Roland <Roland.Richter at empa.ch>
wrote:
> > Hei,
> > I'm currently trying to install PETSc on a server (Ubuntu 22.04) with
Intel MPI and Intel OneAPI. To combine both, I have to use f. ex. "mpiicc
-cc=icx" as C-compiler, as described by
https://stackoverflow.com/a/76362396. Therefore, I adapted the
configure-line as follow:
> > ./configure --prefix=/media/storage/local_opt/petsc
--with-scalar-type=complex --with-cc="mpiicc -cc=icx" --with-cxx="mpiicpc
-cxx=icpx" --CPPFLAGS="-fPIC -march=native -mavx2" --CXXFLAGS="-fPIC
-march=native -mavx2" --with-fc="mpiifort -fc=ifx" --with-pic=true
--with-mpi=true
--with-blaslapack-dir=/opt/intel/oneapi/mkl/latest/lib/intel64/
--with-openmp=true --download-hdf5=yes --download-netcdf=yes
--download-chaco=no --download-metis=yes --download-slepc=yes
--download-suitesparse=yes --download-eigen=yes --download-parmetis=yes
--download-ptscotch=yes --download-mumps=yes --download-scalapack=yes
--download-superlu=yes --download-superlu_dist=yes --with-mkl_pardiso=1
--with-boost=1 --with-boost-dir=/media/storage/local_opt/boost
--download-opencascade=yes --with-fftw=1
--with-fftw-dir=/media/storage/local_opt/fftw3 --download-kokkos=yes
--with-mkl_sparse=1 --with-mkl_cpardiso=1 --with-mkl_sparse_optimize=1
--download-muparser=no --download-p4est=yes --download-sowing=y
es --download-viennalcl=yes --with-zlib --force=1 --with-clean=1
--with-cuda=1
> > The configuration, however, fails with
> > The CMAKE_C_COMPILER:
> > mpiicc -cc=icx
> > is not a full path and was not found in the PATH
> > for all additional modules which use a cmake-based configuration
approach (such as OPENCASCADE). How could I solve that problem?
> > Thank you!
> > Regards,
> > Roland Richter
> > <configure.log>
Type: application/pkcs7-signature
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231011/ded76bb9/attachment.p7s>
