[petsc-users] Galerkin projection using petsc4py
Thanasis Boutsikakis
thanasis.boutsikakis at corintis.com
Thu Oct 5 07:23:20 CDT 2023
This works Pierre. Amazing input, thanks a lot!
> On 5 Oct 2023, at 14:17, Pierre Jolivet <pierre at joliv.et> wrote:
> Not a petsc4py expert here, but you may to try instead:
> A_prime = A.ptap(Phi)
> Thanks,
> Pierre
>> On 5 Oct 2023, at 2:02 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>> Thanks Pierre! So I tried this and got a segmentation fault. Is this supposed to work right off the bat or am I missing sth?
>> [0]PETSC ERROR: ------------------------------------------------------------------------
>> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
>> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
>> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
>> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
>> [0]PETSC ERROR: to get more information on the crash.
>> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
>> Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
>> """Experimenting with PETSc mat-mat multiplication"""
>> import time
>> import numpy as np
>> from colorama import Fore
>> from firedrake import COMM_SELF, COMM_WORLD
>> from firedrake.petsc import PETSc
>> from mpi4py import MPI
>> from numpy.testing import assert_array_almost_equal
>> from utilities import (
>> Print,
>> create_petsc_matrix,
>> print_matrix_partitioning,
>> nproc = COMM_WORLD.size
>> rank = COMM_WORLD.rank
>> # EXP: Galerkin projection of an mpi PETSc matrix A with an mpi PETSc matrix Phi
>> # A' = Phi.T * A * Phi
>> # [k x k] <- [k x m] x [m x m] x [m x k]
>> m, k = 11, 7
>> # Generate the random numpy matrices
>> np.random.seed(0) # sets the seed to 0
>> A_np = np.random.randint(low=0, high=6, size=(m, m))
>> Phi_np = np.random.randint(low=0, high=6, size=(m, k))
>> # TEST: Galerking projection of numpy matrices A_np and Phi_np
>> Aprime_np = Phi_np.T @ A_np @ Phi_np
>> Print(f"MATRIX Aprime_np [{Aprime_np.shape[0]}x{Aprime_np.shape[1]}]")
>> Print(f"{Aprime_np}")
>> # Create A as an mpi matrix distributed on each process
>> A = create_petsc_matrix(A_np, sparse=False)
>> # Create Phi as an mpi matrix distributed on each process
>> Phi = create_petsc_matrix(Phi_np, sparse=False)
>> # Create an empty PETSc matrix object to store the result of the PtAP operation.
>> # This will hold the result A' = Phi.T * A * Phi after the computation.
>> A_prime = create_petsc_matrix(np.zeros((k, k)), sparse=False)
>> # Perform the PtAP (Phi Transpose times A times Phi) operation.
>> # In mathematical terms, this operation is A' = Phi.T * A * Phi.
>> # A_prime will store the result of the operation.
>> Phi.PtAP(A, A_prime)
>>> On 5 Oct 2023, at 13:22, Pierre Jolivet <pierre at joliv.et> wrote:
>>> How about using ptap which will use MatPtAP?
>>> It will be more efficient (and it will help you bypass the issue).
>>> Thanks,
>>> Pierre
>>>> On 5 Oct 2023, at 1:18 PM, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>>>> Sorry, forgot function create_petsc_matrix()
>>>> def create_petsc_matrix(input_array sparse=True):
>>>> """Create a PETSc matrix from an input_array
>>>> Args:
>>>> input_array (np array): Input array
>>>> partition_like (PETSc mat, optional): Petsc matrix. Defaults to None.
>>>> sparse (bool, optional): Toggle for sparese or dense. Defaults to True.
>>>> Returns:
>>>> PETSc mat: PETSc matrix
>>>> # Check if input_array is 1D and reshape if necessary
>>>> assert len(input_array.shape) == 2, "Input array should be 2-dimensional"
>>>> global_rows, global_cols = input_array.shape
>>>> size = ((None, global_rows), (global_cols, global_cols))
>>>> # Create a sparse or dense matrix based on the 'sparse' argument
>>>> if sparse:
>>>> matrix = PETSc.Mat().createAIJ(size=size, comm=COMM_WORLD)
>>>> else:
>>>> matrix = PETSc.Mat().createDense(size=size, comm=COMM_WORLD)
>>>> matrix.setUp()
>>>> local_rows_start, local_rows_end = matrix.getOwnershipRange()
>>>> for counter, i in enumerate(range(local_rows_start, local_rows_end)):
>>>> # Calculate the correct row in the array for the current process
>>>> row_in_array = counter + local_rows_start
>>>> matrix.setValues(
>>>> i, range(global_cols), input_array[row_in_array, :], addv=False
>>>> # Assembly the matrix to compute the final structure
>>>> matrix.assemblyBegin()
>>>> matrix.assemblyEnd()
>>>> return matrix
>>>>> On 5 Oct 2023, at 13:09, Thanasis Boutsikakis <thanasis.boutsikakis at corintis.com> wrote:
>>>>> Hi everyone,
>>>>> I am trying a Galerkin projection (see MFE below) and I cannot get the Phi.transposeMatMult(A, A1) work. The error is
>>>>> File "petsc4py/PETSc/Mat.pyx", line 1514, in petsc4py.PETSc.Mat.transposeMatMult
>>>>> petsc4py.PETSc.Error: error code 56
>>>>> [0] MatTransposeMatMult() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:10135
>>>>> [0] MatProduct_Private() at /Users/boutsitron/firedrake/src/petsc/src/mat/interface/matrix.c:9989
>>>>> [0] No support for this operation for this object type
>>>>> [0] Call MatProductCreate() first
>>>>> Do you know if these exposed to petsc4py or maybe there is another way? I cannot get the MFE to work (neither in sequential nor in parallel)
>>>>> import time
>>>>> import numpy as np
>>>>> Print,
>>>>> m, k = 11, 7
>>>>> A = create_petsc_matrix(A_np)
>>>>> Phi = create_petsc_matrix(Phi_np)
>>>>> A1 = create_petsc_matrix(np.zeros((k, m)))
>>>>> # Now A1 contains the result of Phi^T * A
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231005/cc03dd8c/attachment-0001.html>
