[petsc-users] petsc build could not pass make check
Satish Balay
balay at mcs.anl.gov
Wed Nov 29 13:41:07 CST 2023
Do you have a ~/.petscrc file - with -log_view enabled?
Satish
On Wed, 29 Nov 2023, Di Miao via petsc-users wrote:
> Hi,
> I tried to compile PETSc with the following configuration:
> ./configure --with-debugging=0 COPTFLAGS='-O3' CXXOPTFLAGS='-O3' FOPTFLAGS='-O3' --with-clean=1 --with-make-exec=/SCRATCH/dimiao/test_space/installed/make/bin/make --with-cmake-exec=/SCRATCH/dimiao/test_space/cmake-3.27.9-linux-x86_64/bin/cmake --prefix=/SCRATCH/dimiao/test_space/installed/petsc_opt_mpi --with-mpi-dir=/SCRATCH/dimiao/test_space/installed/mpich PETSC_ARCH=petsc_opt_mpi --with-blaslapack-dir=/SCRATCH/dimiao/oneapi/mkl/latest --with-mkl_pardiso-dir=/SCRATCH/dimiao/oneapi/mkl/latest --with-x=0
> I got three errors:
> Possible error running C/C++ src/snes/tutorials/ex19 with 1 MPI process
> Possible error running C/C++ src/snes/tutorials/ex19 with 2 MPI processes
> Possible error running Fortran example src/snes/tutorials/ex5f with 1 MPI process
> Below each error messages are nothing PETSc's performance summary.
> I have attached make.log, configure.log and the message from make check(make_check.log). Could you please give me some guidance on how to fix this issue?
> Thank you,
> Di
