[petsc-users] MPI barrier issue using MatZeroRows
Barry Smith bsmith at petsc.dev
Wed Nov 29 13:31:51 CST 2023
> On Nov 29, 2023, at 2:11 PM, Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 29, 2023 at 1:55 PM Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
>> So the code logic is after the matrix is assembled, I iterate over all distributed patches in the domain to see which of the patch is abutting a Dirichlet boundary. Depending upon which patch abuts a physical and Dirichlet boundary, a processor will call this routine. However, that same processor is “owning” that DoF, which would be on its diagonal.
>> I think Barry already mentioned this is not going to work unless I use the flag to not communicate explicitly. However, that flag is not working as it should over here for some reason.
> Oh, I do not think that is right.
> Barry, when I look at the code, MPIU_Allreduce is always going to be called to fix up the nonzero_state. Am I wrong about that?
  No, you are correct. I missed that in my earlier look. Setting those flags reduce the number of MPI reductions but does not eliminate them completely.
  MatZeroRows is collective (as its manual page indicates) so you have to do the second thing I suggested. Inside your for loop construct an array containing all the local
rows being zeroed and then make a single call by all MPI processes to MatZeroRows().  Note this is a small change of just a handful of lines of code.
   Barry
>   Thanks,
>     Matt
>> I can always change the matrix coefficients for Dirichlet rows during MatSetValues. However, that would lengthen my code and I was trying to avoid that.
>> On Wed, Nov 29, 2023 at 10:02 AM Matthew Knepley <knepley at gmail.com <mailto:knepley at gmail.com>> wrote:
>>> On Wed, Nov 29, 2023 at 12:30 PM Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
>>>> Ok, I added both, but it still hangs. Here, is bt from all three tasks:
>>> It looks like two processes are calling AllReduce, but one is not. Are all procs not calling MatZeroRows?
>>>   Thanks,
>>>      Matt
>>>> Task 1:
>>>> amneetb at APSB-MacBook-Pro-16:~$ lldb  -p 44691
>>>> (lldb) process attach --pid 44691
>>>> Process 44691 stopped
>>>> * thread #1, queue = 'com.apple.main-thread', stop reason = signal SIGSTOP
>>>>     frame #0: 0x000000018a2d750c libsystem_kernel.dylib`__semwait_signal + 8
>>>> libsystem_kernel.dylib`:
>>>> ->  0x18a2d750c <+8>:  b.lo   0x18a2d752c               ; <+40>
>>>>     0x18a2d7510 <+12>: pacibsp
>>>>     0x18a2d7514 <+16>: stp    x29, x30, [sp, #-0x10]!
>>>>     0x18a2d7518 <+20>: mov    x29, sp
>>>> Target 0: (fo_acoustic_streaming_solver_2d) stopped.
>>>> Executable module set to "/Users/amneetb/Softwares/IBAMR-Git/objs-dbg/tests/IBTK/fo_acoustic_streaming_solver_2d".
>>>> Architecture set to: arm64-apple-macosx-.
>>>> (lldb) cont
>>>> Process 44691 resuming
>>>>     frame #0: 0x000000010ba40b60 libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_release + 752
>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_release:
>>>> ->  0x10ba40b60 <+752>: add    w8, w8, #0x1
>>>>     0x10ba40b64 <+756>: ldr    w9, [x22]
>>>>     0x10ba40b68 <+760>: cmp    w8, w9
>>>>     0x10ba40b6c <+764>: b.lt <http://b.lt/>   0x10ba40b4c               ; <+732>
>>>> (lldb) bt
>>>>   * frame #0: 0x000000010ba40b60 libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_release + 752
>>>>     frame #1: 0x000000010ba48528 libpmpi.12.dylib`MPIDI_POSIX_mpi_allreduce_release_gather + 1088
>>>>     frame #2: 0x000000010ba47964 libpmpi.12.dylib`MPIDI_Allreduce_intra_composition_gamma + 368
>>>>     frame #3: 0x000000010ba35e78 libpmpi.12.dylib`MPIR_Allreduce + 1588
>>>>     frame #4: 0x0000000103f587dc libmpi.12.dylib`MPI_Allreduce + 2280
>>>>     frame #5: 0x0000000106d67650 libpetsc.3.17.dylib`MatZeroRows_MPIAIJ(A=0x0000000105846470, N=1, rows=0x000000016dbfa9f4, diag=1, x=0x0000000000000000, b=0x0000000000000000) at mpiaij.c:827:3
>>>>     frame #6: 0x0000000106aadfac libpetsc.3.17.dylib`MatZeroRows(mat=0x0000000105846470, numRows=1, rows=0x000000016dbfa9f4, diag=1, x=0x0000000000000000, b=0x0000000000000000) at matrix.c:5935:3
>>>>     frame #7: 0x00000001023952d0 fo_acoustic_streaming_solver_2d`IBAMR::AcousticStreamingPETScMatUtilities::constructPatchLevelFOAcousticStreamingOp(mat=0x000000016dc04168, omega=1, sound_speed=1, rho_idx=3, mu_idx=2, lambda_idx=4, u_bc_coefs=0x000000016dc04398, data_time=NaN, num_dofs_per_proc=size=3, u_dof_index_idx=27, p_dof_index_idx=28, patch_level=Pointer<SAMRAI::hier::PatchLevel<2> > @ 0x000000016dbfcec0, mu_interp_type=VC_HARMONIC_INTERP) at AcousticStreamingPETScMatUtilities.cpp:799:36
>>>>     frame #8: 0x00000001023acb8c fo_acoustic_streaming_solver_2d`IBAMR::FOAcousticStreamingPETScLevelSolver::initializeSolverStateSpecialized(this=0x000000016dc04018, x=0x000000016dc05778, (null)=0x000000016dc05680) at FOAcousticStreamingPETScLevelSolver.cpp:149:5
>>>>     frame #9: 0x000000010254a2dc fo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016dc04018, x=0x000000016dc05778, b=0x000000016dc05680) at PETScLevelSolver.cpp:340:5
>>>>     frame #10: 0x0000000102202e5c fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016dc07450) at fo_acoustic_streaming_solver.cpp:400:22
>>>>     frame #11: 0x0000000189fbbf28 dyld`start + 2236
>>>> (lldb)
>>>> Task 2:
>>>> amneetb at APSB-MacBook-Pro-16:~$ lldb  -p 44692
>>>> (lldb) process attach --pid 44692
>>>> Process 44692 stopped
>>>> (lldb) cont
>>>> Process 44692 resuming
>>>>     frame #0: 0x000000010e5a022c libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 516
>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather:
>>>> ->  0x10e5a022c <+516>: ldr    x10, [x19, #0x4e8]
>>>>     0x10e5a0230 <+520>: cmp    x9, x10
>>>>     0x10e5a0234 <+524>: b.hs   0x10e5a0254               ; <+556>
>>>>     0x10e5a0238 <+528>: add    w8, w8, #0x1
>>>> (lldb) bt
>>>>   * frame #0: 0x000000010e5a022c libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 516
>>>>     frame #1: 0x000000010e59fd14 libpmpi.12.dylib`MPIDI_SHM_mpi_barrier + 224
>>>>     frame #2: 0x000000010e59fb60 libpmpi.12.dylib`MPIDI_Barrier_intra_composition_alpha + 44
>>>>     frame #3: 0x000000010e585490 libpmpi.12.dylib`MPIR_Barrier + 900
>>>>     frame #4: 0x0000000106ac5030 libmpi.12.dylib`MPI_Barrier + 684
>>>>     frame #5: 0x0000000108e62638 libpetsc.3.17.dylib`PetscCommDuplicate(comm_in=1140850688, comm_out=0x00000001408ae4b0, first_tag=0x00000001408ae4e4) at tagm.c:235:5
>>>>     frame #6: 0x0000000108e6a910 libpetsc.3.17.dylib`PetscHeaderCreate_Private(h=0x00000001408ae470, classid=1211228, class_name="KSP", descr="Krylov Method", mansec="KSP", comm=1140850688, destroy=(libpetsc.3.17.dylib`KSPDestroy at itfunc.c:1418), view=(libpetsc.3.17.dylib`KSPView at itcreate.c:113)) at inherit.c:62:3
>>>>     frame #7: 0x000000010aa28010 libpetsc.3.17.dylib`KSPCreate(comm=1140850688, inksp=0x000000016b0a4160) at itcreate.c:679:3
>>>>     frame #8: 0x00000001050aa2f4 fo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016b0a4018, x=0x000000016b0a5778, b=0x000000016b0a5680) at PETScLevelSolver.cpp:344:12
>>>>     frame #9: 0x0000000104d62e5c fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016b0a7450) at fo_acoustic_streaming_solver.cpp:400:22
>>>>     frame #10: 0x0000000189fbbf28 dyld`start + 2236
>>>> (lldb)
>>>> Task 3:
>>>> amneetb at APSB-MacBook-Pro-16:~$ lldb  -p 44693
>>>> (lldb) process attach --pid 44693
>>>> Process 44693 stopped
>>>> (lldb) cont
>>>> Process 44693 resuming
>>>>     frame #0: 0x000000010e59c68c libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_gather + 952
>>>> libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_gather:
>>>> ->  0x10e59c68c <+952>: ldr    w9, [x21]
>>>>     0x10e59c690 <+956>: cmp    w8, w9
>>>>     0x10e59c694 <+960>: b.lt <http://b.lt/>   0x10e59c670               ; <+924>
>>>>     0x10e59c698 <+964>: bl     0x10e59ce64               ; MPID_Progress_test
>>>> (lldb) bt
>>>>   * frame #0: 0x000000010e59c68c libpmpi.12.dylib`MPIDI_POSIX_mpi_release_gather_gather + 952
>>>>     frame #1: 0x000000010e5a44bc libpmpi.12.dylib`MPIDI_POSIX_mpi_allreduce_release_gather + 980
>>>>     frame #2: 0x000000010e5a3964 libpmpi.12.dylib`MPIDI_Allreduce_intra_composition_gamma + 368
>>>>     frame #3: 0x000000010e591e78 libpmpi.12.dylib`MPIR_Allreduce + 1588
>>>>     frame #4: 0x0000000106ab47dc libmpi.12.dylib`MPI_Allreduce + 2280
>>>>     frame #5: 0x00000001098c3650 libpetsc.3.17.dylib`MatZeroRows_MPIAIJ(A=0x0000000136862270, N=1, rows=0x000000016b09e9f4, diag=1, x=0x0000000000000000, b=0x0000000000000000) at mpiaij.c:827:3
>>>>     frame #6: 0x0000000109609fac libpetsc.3.17.dylib`MatZeroRows(mat=0x0000000136862270, numRows=1, rows=0x000000016b09e9f4, diag=1, x=0x0000000000000000, b=0x0000000000000000) at matrix.c:5935:3
>>>>     frame #7: 0x0000000104ef12d0 fo_acoustic_streaming_solver_2d`IBAMR::AcousticStreamingPETScMatUtilities::constructPatchLevelFOAcousticStreamingOp(mat=0x000000016b0a8168, omega=1, sound_speed=1, rho_idx=3, mu_idx=2, lambda_idx=4, u_bc_coefs=0x000000016b0a8398, data_time=NaN, num_dofs_per_proc=size=3, u_dof_index_idx=27, p_dof_index_idx=28, patch_level=Pointer<SAMRAI::hier::PatchLevel<2> > @ 0x000000016b0a0ec0, mu_interp_type=VC_HARMONIC_INTERP) at AcousticStreamingPETScMatUtilities.cpp:799:36
>>>>     frame #8: 0x0000000104f08b8c fo_acoustic_streaming_solver_2d`IBAMR::FOAcousticStreamingPETScLevelSolver::initializeSolverStateSpecialized(this=0x000000016b0a8018, x=0x000000016b0a9778, (null)=0x000000016b0a9680) at FOAcousticStreamingPETScLevelSolver.cpp:149:5
>>>>     frame #9: 0x00000001050a62dc fo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016b0a8018, x=0x000000016b0a9778, b=0x000000016b0a9680) at PETScLevelSolver.cpp:340:5
>>>>     frame #10: 0x0000000104d5ee5c fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016b0ab450) at fo_acoustic_streaming_solver.cpp:400:22
>>>> (lldb)
>>>> On Wed, Nov 29, 2023 at 7:22 AM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>>> On Nov 29, 2023, at 1:16 AM, Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
>>>>>> BTW, I think you meant using MatSetOption(mat, MAT_NO_OFF_PROC_ZERO_ROWS, PETSC_TRUE)
>>>>> Yes
>>>>>>  instead ofMatSetOption(mat, MAT_NO_OFF_PROC_ENTRIES, PETSC_TRUE) ??
>>>>>   Please try setting both flags.
>>>>>>  However, that also did not help to overcome the MPI Barrier issue.
>>>>>   If there is still a problem please trap all the MPI processes when they hang in the debugger and send the output from using bt on all of them. This way
>>>>> we can see the different places the different MPI processes are stuck at.
>>>>>> On Tue, Nov 28, 2023 at 9:57 PM Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
>>>>>>> I added that option but the code still gets stuck at the same call MatZeroRows with 3 processors.
>>>>>>> On Tue, Nov 28, 2023 at 7:23 PM Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
>>>>>>>> On Tue, Nov 28, 2023 at 6:42 PM Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>>>>>>>   for (int comp = 0; comp < 2; ++comp)
>>>>>>>>>                     for (Box<NDIM>::Iterator bc(bc_coef_box); bc; bc++)
>>>>>>>>>                         if (IBTK::abs_equal_eps(b, 0.0))
>>>>>>>>>                             const double diag_value = a;
>>>>>>>>>                             ierr = MatZeroRows(mat, 1, &u_dof_index, diag_value, NULL, NULL);
>>>>>>>>>                             IBTK_CHKERRQ(ierr);
>>>>>>>>> In general, this code will not work because each process calls MatZeroRows a different number of times, so it cannot match up with all the processes.
>>>>>>>>> If u_dof_index is always local to the current process, you can call MatSetOption(mat, MAT_NO_OFF_PROC_ENTRIES,PETSC_TRUE) above the for loop and
>>>>>>>>> the MatZeroRows will not synchronize across the MPI processes (since it does not need to and you told it that).
>>>>>>>> Yes, u_dof_index is going to be local and I put a check on it a few lines before calling MatZeroRows.
>>>>>>>> Can MatSetOption() be called after the matrix has been assembled?
>>>>>>>>> If the u_dof_index will not always be local, then you need, on each process, to list all the u_dof_index for each process in an array and then call MatZeroRows()
>>>>>>>>> once after the loop so it can exchange the needed information with the other MPI processes to get the row indices to the right place.
>>>>>>>>> Barry
>>>>>>>>>> On Nov 28, 2023, at 6:44 PM, Amneet Bhalla <mail2amneet at gmail.com <mailto:mail2amneet at gmail.com>> wrote:
>>>>>>>>>> Hi Folks,
>>>>>>>>>> I am using MatZeroRows() to set Dirichlet boundary conditions. This works fine for the serial run and the solver produces correct results (verified through analytical solution). However, when I run the case in parallel, the simulation gets stuck at MatZeroRows(). My understanding is that this function needs to be called after the MatAssemblyBegin{End}() has been called, and should be called by all processors. Here is that bit of the code which calls MatZeroRows() after the matrix has been assembled
>>>>>>>>>> https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L724-L801
>>>>>>>>>> I ran the parallel code (on 3 processors) in the debugger (-start_in_debugger). Below is the call stack from the processor that gets stuck
>>>>>>>>>> amneetb at APSB-MBP-16:~$ lldb  -p 4307
>>>>>>>>>> (lldb) process attach --pid 4307
>>>>>>>>>> Process 4307 stopped
>>>>>>>>>> (lldb) cont
>>>>>>>>>> Process 4307 resuming
>>>>>>>>>>     frame #0: 0x0000000109d281b8 libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 400
>>>>>>>>>> ->  0x109d281b8 <+400>: ldr    w9, [x24]
>>>>>>>>>>     0x109d281bc <+404>: cmp    w8, w9
>>>>>>>>>>     0x109d281c0 <+408>: b.lt <http://b.lt/>   0x109d281a0               ; <+376>
>>>>>>>>>>     0x109d281c4 <+412>: bl     0x109d28e64               ; MPID_Progress_test
>>>>>>>>>> (lldb) bt
>>>>>>>>>>   * frame #0: 0x0000000109d281b8 libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 400
>>>>>>>>>>     frame #1: 0x0000000109d27d14 libpmpi.12.dylib`MPIDI_SHM_mpi_barrier + 224
>>>>>>>>>>     frame #2: 0x0000000109d27b60 libpmpi.12.dylib`MPIDI_Barrier_intra_composition_alpha + 44
>>>>>>>>>>     frame #3: 0x0000000109d0d490 libpmpi.12.dylib`MPIR_Barrier + 900
>>>>>>>>>>     frame #4: 0x000000010224d030 libmpi.12.dylib`MPI_Barrier + 684
>>>>>>>>>>     frame #5: 0x00000001045ea638 libpetsc.3.17.dylib`PetscCommDuplicate(comm_in=-2080374782, comm_out=0x000000010300bcb0, first_tag=0x000000010300bce4) at tagm.c:235:5
>>>>>>>>>>     frame #6: 0x00000001045f2910 libpetsc.3.17.dylib`PetscHeaderCreate_Private(h=0x000000010300bc70, classid=1211227, class_name="PetscSF", descr="Star Forest", mansec="PetscSF", comm=-2080374782, destroy=(libpetsc.3.17.dylib`PetscSFDestroy at sf.c:224), view=(libpetsc.3.17.dylib`PetscSFView at sf.c:841)) at inherit.c:62:3
>>>>>>>>>>     frame #7: 0x00000001049cf820 libpetsc.3.17.dylib`PetscSFCreate(comm=-2080374782, sf=0x000000016f911a50) at sf.c:62:3
>>>>>>>>>>     frame #8: 0x0000000104cd3024 libpetsc.3.17.dylib`MatZeroRowsMapLocal_Private(A=0x00000001170c1270, N=1, rows=0x000000016f912cb4, nr=0x000000016f911df8, olrows=0x000000016f911e00) at zerorows.c:36:5
>>>>>>>>>>     frame #9: 0x000000010504ea50 libpetsc.3.17.dylib`MatZeroRows_MPIAIJ(A=0x00000001170c1270, N=1, rows=0x000000016f912cb4, diag=1, x=0x0000000000000000, b=0x0000000000000000) at mpiaij.c:768:3
> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
> -- Norbert Wiener
> https://www.cse.buffalo.edu/~knepley/ <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231129/a7a41ae8/attachment-0001.html>
