[petsc-users] MPI barrier issue using MatZeroRows
Amneet Bhalla
mail2amneet at gmail.com
Tue Nov 28 23:57:35 CST 2023
I added that option but the code still gets stuck at the same call
MatZeroRows with 3 processors.
On Tue, Nov 28, 2023 at 7:23 PM Amneet Bhalla <mail2amneet at gmail.com> wrote:
> On Tue, Nov 28, 2023 at 6:42 PM Barry Smith <bsmith at petsc.dev> wrote:
>> for (int comp = 0; comp < 2; ++comp)
>> for (Box<NDIM>::Iterator bc(bc_coef_box); bc; bc++)
>> if (IBTK::abs_equal_eps(b, 0.0))
>> const double diag_value = a;
>> ierr = MatZeroRows(mat, 1, &u_dof_index,
>> diag_value, NULL, NULL);
>> IBTK_CHKERRQ(ierr);
>> In general, this code will not work because each process calls
>> MatZeroRows a different number of times, so it cannot match up with all the
>> processes.
>> If u_dof_index is always local to the current process, you can call
>> MatSetOption(mat, MAT_NO_OFF_PROC_ENTRIES,PETSC_TRUE) above the for loop
>> and
>> the MatZeroRows will not synchronize across the MPI processes (since it
>> does not need to and you told it that).
> Yes, u_dof_index is going to be local and I put a check on it a few lines
> before calling MatZeroRows.
> Can MatSetOption() be called after the matrix has been assembled?
>> If the u_dof_index will not always be local, then you need, on each
>> process, to list all the u_dof_index for each process in an array and then
>> call MatZeroRows()
>> once after the loop so it can exchange the needed information with the
>> other MPI processes to get the row indices to the right place.
>> Barry
>> On Nov 28, 2023, at 6:44 PM, Amneet Bhalla <mail2amneet at gmail.com> wrote:
>> Hi Folks,
>> I am using MatZeroRows() to set Dirichlet boundary conditions. This works
>> fine for the serial run and the solver produces correct results (verified
>> through analytical solution). However, when I run the case in parallel, the
>> simulation gets stuck at MatZeroRows(). My understanding is that this
>> function needs to be called after the MatAssemblyBegin{End}() has been
>> called, and should be called by all processors. Here is that bit of the
>> code which calls MatZeroRows() after the matrix has been assembled
>> https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L724-L801
>> I ran the parallel code (on 3 processors) in the debugger
>> (-start_in_debugger). Below is the call stack from the processor that gets
>> stuck
>> amneetb at APSB-MBP-16:~$ lldb -p 4307
>> (lldb) process attach --pid 4307
>> Process 4307 stopped
>> * thread #1, queue = 'com.apple.main-thread', stop reason = signal
>> SIGSTOP
>> frame #0: 0x000000018a2d750c libsystem_kernel.dylib`__semwait_signal
>> + 8
>> libsystem_kernel.dylib`:
>> -> 0x18a2d750c <+8>: b.lo 0x18a2d752c ; <+40>
>> 0x18a2d7510 <+12>: pacibsp
>> 0x18a2d7514 <+16>: stp x29, x30, [sp, #-0x10]!
>> 0x18a2d7518 <+20>: mov x29, sp
>> Target 0: (fo_acoustic_streaming_solver_2d) stopped.
>> Executable module set to
>> "/Users/amneetb/Softwares/IBAMR-Git/objs-dbg/tests/IBTK/fo_acoustic_streaming_solver_2d".
>> Architecture set to: arm64-apple-macosx-.
>> (lldb) cont
>> Process 4307 resuming
>> SIGSTOP
>> frame #0: 0x0000000109d281b8
>> libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 400
>> libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather:
>> -> 0x109d281b8 <+400>: ldr w9, [x24]
>> 0x109d281bc <+404>: cmp w8, w9
>> 0x109d281c0 <+408>: b.lt 0x109d281a0 ; <+376>
>> 0x109d281c4 <+412>: bl 0x109d28e64 ;
>> MPID_Progress_test
>> (lldb) bt
>> SIGSTOP
>> * frame #0: 0x0000000109d281b8
>> frame #1: 0x0000000109d27d14 libpmpi.12.dylib`MPIDI_SHM_mpi_barrier
>> + 224
>> frame #2: 0x0000000109d27b60
>> libpmpi.12.dylib`MPIDI_Barrier_intra_composition_alpha + 44
>> frame #3: 0x0000000109d0d490 libpmpi.12.dylib`MPIR_Barrier + 900
>> frame #4: 0x000000010224d030 libmpi.12.dylib`MPI_Barrier + 684
>> frame #5: 0x00000001045ea638
>> libpetsc.3.17.dylib`PetscCommDuplicate(comm_in=-2080374782,
>> comm_out=0x000000010300bcb0, first_tag=0x000000010300bce4) at tagm.c:235:
>> 5
>> frame #6: 0x00000001045f2910
>> libpetsc.3.17.dylib`PetscHeaderCreate_Private(h=0x000000010300bc70,
>> classid=1211227, class_name="PetscSF", descr="Star Forest",
>> mansec="PetscSF", comm=-2080374782,
>> destroy=(libpetsc.3.17.dylib`PetscSFDestroy at sf.c:224),
>> view=(libpetsc.3.17.dylib`PetscSFView at sf.c:841)) at inherit.c:62:3
>> frame #7: 0x00000001049cf820
>> libpetsc.3.17.dylib`PetscSFCreate(comm=-2080374782, sf=0x000000016f911a50)
>> at sf.c:62:3
>> frame #8: 0x0000000104cd3024
>> libpetsc.3.17.dylib`MatZeroRowsMapLocal_Private(A=0x00000001170c1270, N=1,
>> rows=0x000000016f912cb4, nr=0x000000016f911df8, olrows=0x000000016f911e00)
>> at zerorows.c:36:5
>> frame #9: 0x000000010504ea50
>> libpetsc.3.17.dylib`MatZeroRows_MPIAIJ(A=0x00000001170c1270, N=1,
>> rows=0x000000016f912cb4, diag=1, x=0x0000000000000000,
>> b=0x0000000000000000) at mpiaij.c:768:3
>> frame #10: 0x0000000104d95fac
>> libpetsc.3.17.dylib`MatZeroRows(mat=0x00000001170c1270, numRows=1,
>> b=0x0000000000000000) at matrix.c:5935:3
>> frame #11: 0x000000010067d320
>> fo_acoustic_streaming_solver_2d`IBAMR::AcousticStreamingPETScMatUtilities::constructPatchLevelFOAcousticStreamingOp(mat=0x000000016f91c178,
>> omega=1, sound_speed=1, rho_idx=3, mu_idx=2, lambda_idx=4,
>> u_bc_coefs=0x000000016f91c3a8, data_time=NaN, num_dofs_per_proc=size=3,
>> u_dof_index_idx=27, p_dof_index_idx=28,
>> patch_level=Pointer<SAMRAI::hier::PatchLevel<2> > @ 0x000000016f914ed0,
>> mu_interp_type=VC_HARMONIC_INTERP) at
>> AcousticStreamingPETScMatUtilities.cpp:794:36
>> frame #12: 0x0000000100694bdc
>> fo_acoustic_streaming_solver_2d`IBAMR::FOAcousticStreamingPETScLevelSolver::initializeSolverStateSpecialized(this=0x000000016f91c028,
>> x=0x000000016f91d788, (null)=0x000000016f91d690) at
>> FOAcousticStreamingPETScLevelSolver.cpp:149:5
>> frame #13: 0x000000010083232c
>> fo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016f91c028,
>> x=0x000000016f91d788, b=0x000000016f91d690) at PETScLevelSolver.cpp:340:5
>> frame #14: 0x00000001004eb230
>> fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016f91f460) at
>> fo_acoustic_streaming_solver.cpp:400:22
>> frame #15: 0x0000000189fbbf28 dyld`start + 2236
>> Any suggestions on how to avoid this barrier? Here are all MAT options I
>> am using (in the debug mode), if that is helpful:
>> https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L453-L458
>> Thanks,
>> --Amneet
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231128/3dba7383/attachment-0001.html>
