[petsc-users] MPI barrier issue using MatZeroRows
Amneet Bhalla
mail2amneet at gmail.com
Tue Nov 28 17:44:07 CST 2023
Hi Folks,
I am using MatZeroRows() to set Dirichlet boundary conditions. This works
fine for the serial run and the solver produces correct results (verified
through analytical solution). However, when I run the case in parallel, the
simulation gets stuck at MatZeroRows(). My understanding is that this
function needs to be called after the MatAssemblyBegin{End}() has been
called, and should be called by all processors. Here is that bit of the
code which calls MatZeroRows() after the matrix has been assembled
https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L724-L801
I ran the parallel code (on 3 processors) in the debugger
(-start_in_debugger). Below is the call stack from the processor that gets
stuck
amneetb at APSB-MBP-16:~$ lldb -p 4307
(lldb) process attach --pid 4307
Process 4307 stopped
* thread #1, queue = 'com.apple.main-thread', stop reason = signal SIGSTOP
frame #0: 0x000000018a2d750c libsystem_kernel.dylib`__semwait_signal + 8
libsystem_kernel.dylib`:
-> 0x18a2d750c <+8>: b.lo 0x18a2d752c ; <+40>
0x18a2d7510 <+12>: pacibsp
0x18a2d7514 <+16>: stp x29, x30, [sp, #-0x10]!
0x18a2d7518 <+20>: mov x29, sp
Target 0: (fo_acoustic_streaming_solver_2d) stopped.
Executable module set to
"/Users/amneetb/Softwares/IBAMR-Git/objs-dbg/tests/IBTK/fo_acoustic_streaming_solver_2d".
Architecture set to: arm64-apple-macosx-.
(lldb) cont
Process 4307 resuming
frame #0: 0x0000000109d281b8
libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather + 400
libpmpi.12.dylib`MPIDI_POSIX_mpi_barrier_release_gather:
-> 0x109d281b8 <+400>: ldr w9, [x24]
0x109d281bc <+404>: cmp w8, w9
0x109d281c0 <+408>: b.lt 0x109d281a0 ; <+376>
0x109d281c4 <+412>: bl 0x109d28e64 ;
MPID_Progress_test
(lldb) bt
* frame #0: 0x0000000109d281b8
frame #1: 0x0000000109d27d14 libpmpi.12.dylib`MPIDI_SHM_mpi_barrier +
224
frame #2: 0x0000000109d27b60
libpmpi.12.dylib`MPIDI_Barrier_intra_composition_alpha + 44
frame #3: 0x0000000109d0d490 libpmpi.12.dylib`MPIR_Barrier + 900
frame #4: 0x000000010224d030 libmpi.12.dylib`MPI_Barrier + 684
frame #5: 0x00000001045ea638
libpetsc.3.17.dylib`PetscCommDuplicate(comm_in=-2080374782,
comm_out=0x000000010300bcb0, first_tag=0x000000010300bce4) at tagm.c:235:5
frame #6: 0x00000001045f2910
libpetsc.3.17.dylib`PetscHeaderCreate_Private(h=0x000000010300bc70,
classid=1211227, class_name="PetscSF", descr="Star Forest",
mansec="PetscSF", comm=-2080374782,
destroy=(libpetsc.3.17.dylib`PetscSFDestroy at sf.c:224),
view=(libpetsc.3.17.dylib`PetscSFView at sf.c:841)) at inherit.c:62:3
frame #7: 0x00000001049cf820
libpetsc.3.17.dylib`PetscSFCreate(comm=-2080374782, sf=0x000000016f911a50)
at sf.c:62:3
frame #8: 0x0000000104cd3024
libpetsc.3.17.dylib`MatZeroRowsMapLocal_Private(A=0x00000001170c1270, N=1,
rows=0x000000016f912cb4, nr=0x000000016f911df8, olrows=0x000000016f911e00)
at zerorows.c:36:5
frame #9: 0x000000010504ea50
libpetsc.3.17.dylib`MatZeroRows_MPIAIJ(A=0x00000001170c1270, N=1,
rows=0x000000016f912cb4, diag=1, x=0x0000000000000000,
b=0x0000000000000000) at mpiaij.c:768:3
frame #10: 0x0000000104d95fac
libpetsc.3.17.dylib`MatZeroRows(mat=0x00000001170c1270, numRows=1,
b=0x0000000000000000) at matrix.c:5935:3
frame #11: 0x000000010067d320
fo_acoustic_streaming_solver_2d`IBAMR::AcousticStreamingPETScMatUtilities::constructPatchLevelFOAcousticStreamingOp(mat=0x000000016f91c178,
omega=1, sound_speed=1, rho_idx=3, mu_idx=2, lambda_idx=4,
u_bc_coefs=0x000000016f91c3a8, data_time=NaN, num_dofs_per_proc=size=3,
u_dof_index_idx=27, p_dof_index_idx=28,
patch_level=Pointer<SAMRAI::hier::PatchLevel<2> > @ 0x000000016f914ed0,
mu_interp_type=VC_HARMONIC_INTERP) at AcousticStreamingPETScMatUtilities.cpp
:794:36
frame #12: 0x0000000100694bdc
fo_acoustic_streaming_solver_2d`IBAMR::FOAcousticStreamingPETScLevelSolver::initializeSolverStateSpecialized(this=0x000000016f91c028,
x=0x000000016f91d788, (null)=0x000000016f91d690) at
FOAcousticStreamingPETScLevelSolver.cpp:149:5
frame #13: 0x000000010083232c
fo_acoustic_streaming_solver_2d`IBTK::PETScLevelSolver::initializeSolverState(this=0x000000016f91c028,
x=0x000000016f91d788, b=0x000000016f91d690) at PETScLevelSolver.cpp:340:5
frame #14: 0x00000001004eb230
fo_acoustic_streaming_solver_2d`main(argc=11, argv=0x000000016f91f460) at
fo_acoustic_streaming_solver.cpp:400:22
frame #15: 0x0000000189fbbf28 dyld`start + 2236
Any suggestions on how to avoid this barrier? Here are all MAT options I am
using (in the debug mode), if that is helpful:
https://github.com/IBAMR/IBAMR/blob/amneetb/acoustically-driven-flows/src/acoustic_streaming/AcousticStreamingPETScMatUtilities.cpp#L453-L458
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231128/41670d92/attachment-0001.html>
