[petsc-users] [EXTERNAL] Re: Unexpected performance losses switching to COO interface
Junchao Zhang junchao.zhang at gmail.com
Tue Nov 28 15:59:03 CST 2023
On Tue, Nov 28, 2023 at 3:16 PM Fackler, Philip <facklerpw at ornl.gov> wrote:
> That makes sense. Here are the arguments that I think are relevant:
> -fieldsplit_1_pc_type redundant -fieldsplit_0_pc_type sor -pc_type
> fieldsplit -pc_fieldsplit_detect_coupling
> What would you suggest to make this better?
Jed, do you have suggestions
> Also, note that the cases marked "serial" are running on CPU only, that
> is, using only the SERIAL backend for kokkos.
I did also look at hpcdb-NE_9-cuda, which also called
MatLUFactorNumeric_SeqAIJ(). But hpcdb-NE_3-cuda called PCSetUp_GAMG().  It
suggests you used different options for them.
> *Philip Fackler *
> Research Software Engineer, Application Engineering Group
> Advanced Computing Systems Research Section
> Computer Science and Mathematics Division
> *Oak Ridge National Laboratory*
> *From:* Junchao Zhang <junchao.zhang at gmail.com>
> *Sent:* Tuesday, November 28, 2023 15:51
> *To:* Fackler, Philip <facklerpw at ornl.gov>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>;
> xolotl-psi-development at lists.sourceforge.net <
> xolotl-psi-development at lists.sourceforge.net>
> *Subject:* Re: [EXTERNAL] Re: [petsc-users] Unexpected performance losses
> Hi, Philip,
>    I opened hpcdb-PSI_9-serial and it seems you used PCLU.  Since Kokkos
> does not have a GPU LU implementation, we do it on CPU via
> MatLUFactorNumeric_SeqAIJ(). Perhaps you can try other PC types?
> [image: Screenshot 2023-11-28 at 2.43.03 PM.png]
> --Junchao Zhang
> On Wed, Nov 22, 2023 at 10:43 AM Fackler, Philip <facklerpw at ornl.gov>
> wrote:
> I definitely dropped the ball on this. I'm sorry for that. I have new
> profiling data using the latest (as of yesterday) of petsc/main. I've put
> them in a single google drive folder linked here:
> https://drive.google.com/drive/folders/14ScvyfxOzc4OzXs9HZVeQDO-g6FdIVAI?usp=drive_link
> <https://urldefense.us/v2/url?u=https-3A__drive.google.com_drive_folders_14ScvyfxOzc4OzXs9HZVeQDO-2Dg6FdIVAI-3Fusp-3Ddrive-5Flink&d=DwMFaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=DAkLCjn8leYU-uJ-kfNEQMhPZWx9lzc4d5KgIR-RZWQ&m=Qn5D9xuzFcMdyuL0I2ruKmU6yeez0NrOx69oUjRaAXTeKD6etHt4USuZgnbqF4v6&s=_Lqg9v8aa4KXUdud3zqSp55FiYkZ12Pp5ZY54_9OvJI&e=>
> Have a happy holiday weekend!
> Thanks,
> *Philip Fackler *
> *Sent:* Monday, October 16, 2023 15:24
> Hi, Philip,
>    That branch was merged to petsc/main today. Let me know once you have
> new profiling results.
>    Thanks.
> --Junchao Zhang
> On Mon, Oct 16, 2023 at 9:33 AM Fackler, Philip <facklerpw at ornl.gov>
> wrote:
> Junchao,
> I've attached updated timing plots (red and blue are swapped from before;
> yellow is the new one). There is an improvement for the NE_3 case only with
> CUDA. Serial stays the same, and the PSI cases stay the same. In the PSI
> cases, MatShift doesn't show up (I assume because we're using different
> preconditioner arguments). So, there must be some other primary culprit.
> I'll try to get updated profiling data to you soon.
> Thanks,
> *Philip Fackler *
> *From:* Fackler, Philip via Xolotl-psi-development <
> *Sent:* Wednesday, October 11, 2023 11:31
> *To:* Junchao Zhang <junchao.zhang at gmail.com>
> *Subject:* Re: [Xolotl-psi-development] [EXTERNAL] Re: [petsc-users]
> I'm on it.
> *Philip Fackler *
> *Sent:* Wednesday, October 11, 2023 10:14
> xolotl-psi-development at lists.sourceforge.net>; Blondel, Sophie <
> sblondel at utk.edu>
> Hi,  Philip,
>   Could you try this branch
> jczhang/2023-10-05/feature-support-matshift-aijkokkos ?
>   Thanks.
> --Junchao Zhang
> On Thu, Oct 5, 2023 at 4:52 PM Fackler, Philip <facklerpw at ornl.gov> wrote:
> Aha! That makes sense. Thank you.
> *Philip Fackler *
> *Sent:* Thursday, October 5, 2023 17:29
> *Subject:* [EXTERNAL] Re: [petsc-users] Unexpected performance losses
> Wait a moment, it seems it was because we do not have a GPU implementation
> of MatShift...
> Let me see how to add it.
> --Junchao Zhang
> On Thu, Oct 5, 2023 at 10:58 AM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> Hi, Philip,
>   I looked at the hpcdb-NE_3-cuda file. It seems you used MatSetValues()
> instead of the COO interface?  MatSetValues() needs to copy the data from
> device to host and thus is expensive.
>   Do you have profiling results with COO enabled?
> [image: Screenshot 2023-10-05 at 10.55.29 AM.png]
> --Junchao Zhang
> On Mon, Oct 2, 2023 at 9:52 AM Junchao Zhang <junchao.zhang at gmail.com>
> wrote:
> Hi, Philip,
>   I will look into the tarballs and get back to you.
>    Thanks.
> --Junchao Zhang
> On Mon, Oct 2, 2023 at 9:41 AM Fackler, Philip via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> We finally have xolotl ported to use the new COO interface and the
> aijkokkos implementation for Mat (and kokkos for Vec). Comparing this port
> to our previous version (using MatSetValuesStencil and the default Mat and
> Vec implementations), we expected to see an improvement in performance for
> both the "serial" and "cuda" builds (here I'm referring to the kokkos
> configuration).
> Attached are two plots that show timings for three different cases. All of
> these were run on Ascent (the Summit-like training system) with 6 MPI tasks
> (on a single node). The CUDA cases were given one GPU per task (and used
> CUDA-aware MPI). The labels on the blue bars indicate speedup. In all cases
> we used "-fieldsplit_0_pc_type jacobi" to keep the comparison as consistent
> as possible.
> The performance of RHSJacobian (where the bulk of computation happens in
> xolotl) behaved basically as expected (better than expected in the serial
> build). NE_3 case in CUDA was the only one that performed worse, but not
> surprisingly, since its workload for the GPUs is much smaller. We've still
> got more optimization to do on this.
> The real surprise was how much worse the overall solve times were. This
> seems to be due simply to switching to the kokkos-based implementation. I'm
> wondering if there are any changes we can make in configuration or runtime
> arguments to help with PETSc's performance here. Any help looking into this
> would be appreciated.
> The tarballs linked here
> <https://urldefense.us/v2/url?u=https-3A__drive.google.com_file_d_19X-5FL3SVkGBM9YUzXnRR-5FkVWFG0JFwqZ3_view-3Fusp-3Ddrive-5Flink&d=DwMFaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=DAkLCjn8leYU-uJ-kfNEQMhPZWx9lzc4d5KgIR-RZWQ&m=GTpC2k9hIdMhUg_aJkeAqd-1CP5M8bwJMJjTriVE1k-j36ZnEHerQkZOzszxWoG2&s=GW0ImGWhWr4rR5AoSULCnaP1CN1QWxTSeMDhdOuhTEA&e=>
> and here
> <https://urldefense.us/v2/url?u=https-3A__drive.google.com_file_d_15yDBN7-2DYlO1g6RJNPYNImzr611i1Ffhv_view-3Fusp-3Ddrive-5Flink&d=DwMFaQ&c=v4IIwRuZAmwupIjowmMWUmLasxPEgYsgNI-O7C4ViYc&r=DAkLCjn8leYU-uJ-kfNEQMhPZWx9lzc4d5KgIR-RZWQ&m=GTpC2k9hIdMhUg_aJkeAqd-1CP5M8bwJMJjTriVE1k-j36ZnEHerQkZOzszxWoG2&s=tO-BnNY2myA-pIsRnBjQNoaOSjn-B3-lWGiQp7XXJwk&e=>
> are profiling databases which, once extracted, can be viewed with
> hpcviewer. I don't know how helpful that will be, but hopefully it can give
> you some direction.
> Thanks for your help,
> *Philip Fackler *
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231128/34e9023a/attachment-0001.html>
Name: Screenshot 2023-11-28 at 2.43.03?PM.png
Type: image/png
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231128/34e9023a/attachment-0001.png>
