[petsc-users] PETSC breaks when using HYPRE preconditioner
Pantelis Moschopoulos pmoschopoulos at outlook.com
Thu Nov 9 05:57:49 CST 2023
Hello everyone,
I am trying to use Petsc coupled with Hypre BoomerAMG as preconditioner in our in-house code to simulate the transient motion of complex fluid with finite elements. The problem is that after a random number of iterations, an error arises when the Hypre is called.
The error that I get in the terminal is the following:
[16]PETSC ERROR: ------------------------------------------------------------------------
[16]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
[16]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
[16]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind and https://petsc.org/release/faq/
[16]PETSC ERROR: ---------------------  Stack Frames ------------------------------------
[16]PETSC ERROR: The line numbers in the error traceback are not always exact.
[16]PETSC ERROR: #1 Hypre solve
[16]PETSC ERROR: #2 PCApply_HYPRE() at /home/pmosx/Libraries/petsc/src/ksp/pc/impls/hypre/hypre.c:451
[16]PETSC ERROR: #3 PCApply() at /home/pmosx/Libraries/petsc/src/ksp/pc/interface/precon.c:486
[16]PETSC ERROR: #4 PCApplyBAorAB() at /home/pmosx/Libraries/petsc/src/ksp/pc/interface/precon.c:756
[16]PETSC ERROR: #5 KSP_PCApplyBAorAB() at /home/pmosx/Libraries/petsc/include/petsc/private/kspimpl.h:443
[16]PETSC ERROR: #6 KSPGMRESCycle() at /home/pmosx/Libraries/petsc/src/ksp/ksp/impls/gmres/gmres.c:146
[16]PETSC ERROR: #7 KSPSolve_GMRES() at /home/pmosx/Libraries/petsc/src/ksp/ksp/impls/gmres/gmres.c:227
[16]PETSC ERROR: #8 KSPSolve_Private() at /home/pmosx/Libraries/petsc/src/ksp/ksp/interface/itfunc.c:910
[16]PETSC ERROR: #9 KSPSolve() at /home/pmosx/Libraries/petsc/src/ksp/ksp/interface/itfunc.c:1082
On the same time, I use valgrind and when the program stops, it reports the following:
==1261647== Invalid read of size 8
==1261647==    at 0x4841C74: _intel_fast_memcpy (in /usr/lib/x86_64-linux-gnu/valgrind/vgpreload_memcheck-amd64-linux.so)
==1261647==    by 0x16231F73: hypre_GaussElimSolve (in /home/pmosx/Libraries/PETSC_INS_DIR_INTELDebug/lib/libHYPRE-2.29.0.so)
==1261647==    by 0x1622DB4F: hypre_BoomerAMGCycle (in /home/pmosx/Libraries/PETSC_INS_DIR_INTELDebug/lib/libHYPRE-2.29.0.so)
==1261647==    by 0x1620002E: hypre_BoomerAMGSolve (in /home/pmosx/Libraries/PETSC_INS_DIR_INTELDebug/lib/libHYPRE-2.29.0.so)
==1261647==    by 0x12B6F8F8: PCApply_HYPRE (in /home/pmosx/Libraries/PETSC_INS_DIR_INTELDebug/lib/libpetsc.so.3.20.1)
==1261647==    by 0x12C38785: PCApply (in /home/pmosx/Libraries/PETSC_INS_DIR_INTELDebug/lib/libpetsc.so.3.20.1)
==1261647==    by 0x12C36A39: PCApplyBAorAB (in /home/pmosx/Libraries/PETSC_INS_DIR_INTELDebug/lib/libpetsc.so.3.20.1)
==1261647==    by 0x126299E1: KSPGMRESCycle (in /home/pmosx/Libraries/PETSC_INS_DIR_INTELDebug/lib/libpetsc.so.3.20.1)
==1261647==    by 0x12628051: KSPSolve_GMRES (in /home/pmosx/Libraries/PETSC_INS_DIR_INTELDebug/lib/libpetsc.so.3.20.1)
==1261647==    by 0x127A532E: KSPSolve_Private (in /home/pmosx/Libraries/PETSC_INS_DIR_INTELDebug/lib/libpetsc.so.3.20.1)
==1261647==    by 0x127A3C8A: KSPSolve (in /home/pmosx/Libraries/PETSC_INS_DIR_INTELDebug/lib/libpetsc.so.3.20.1)
==1261647==    by 0x12C50AF1: kspsolve_ (in /home/pmosx/Libraries/PETSC_INS_DIR_INTELDebug/lib/libpetsc.so.3.20.1)
==1261647==  Address 0x0 is not stack'd, malloc'd or (recently) free'd
==1261647==
This is indeed a very peculiar error. I cannot understand why it happens. In our solution procedure, we split the equations and we solve them segregated. I create two different ksp (1_ksp and 2_ksp) using KSPSetOptionsPrefix. Might this choice create a confusion and results in this error?
Any help is much appreciated.
Pantelis
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231109/b87952e8/attachment.html>
