[petsc-users] [BULK] Re: DMPlex and Gmsh
Sharan Roongta
s.roongta at mpie.de
Thu Nov 9 03:45:34 CST 2023
Hello,
Thank you for the response. I shall try it out.
Sharan
From: Matthew Knepley [mailto:knepley at gmail.com]
Sent: Wednesday, 8 November 2023 23:09
To: Blaise Bourdin <bourdin at mcmaster.ca>
Cc: Sharan Roongta <s.roongta at mpie.de>; petsc-users at mcs.anl.gov
Subject: [BULK] Re: [petsc-users] DMPlex and Gmsh
Importance: Low
On Wed, Nov 8, 2023 at 4:50 PM Blaise Bourdin <bourdin at mcmaster.ca> wrote:
I think that you need to use the magical keyword “-dm_plex_gmsh_mark_vertices” for that
I try to describe the options here:
https://petsc.org/main/manualpages/DMPlex/DMPlexCreateGmsh/
Matt
Blaise
On Nov 8, 2023, at 1:13 PM, Sharan Roongta <s.roongta at mpie.de> wrote:
Caution: External email.
Dear Petsc team,
I want to load a .msh file generated using Gmsh software into the DMPlex object. There are several things I would want to clarify, but I would like to start with “Physical tags”.
If I have defined “Physical Points”, “Physical Surface”, and “Physical Volume” in my .geo file, I get the physical tags in the “.msh” file.
When I load this mesh in DMPlex, and view the DM:
call DMView(globalMesh, PETSC_VIEWER_STDOUT_WORLD,err_PETSc)
CHKERRQ(err_PETSc)
This is the output I get:
DM Object: n/a 1 MPI process
type: plex
n/a in 3 dimensions:
Number of 0-cells per rank: 14
Number of 1-cells per rank: 49
Number of 2-cells per rank: 60
Number of 3-cells per rank: 24
Labels:
celltype: 4 strata with value/size (0 (14), 6 (24), 3 (60), 1 (49))
depth: 4 strata with value/size (0 (14), 1 (49), 2 (60), 3 (24))
Cell Sets: 1 strata with value/size (8 (24))
Face Sets: 6 strata with value/size (2 (4), 3 (4), 4 (4), 5 (4), 6 (4), 7 (4))
I was expecting to get the “Node Sets” or “Vertex Sets” also. Is my assumption wrong?
If yes, then how can one figure out the boundary nodes and their tags where I want to apply certain boundary conditions?
Currently we apply boundary conditions on faces, therefore “Face Sets” was enough. But now we want to apply displacements on certain boundary nodes.
I have also attached the .geo and .msh file (hope you can open it)
The Petsc version I am using is 3.18.6.
Thanks and Regards,
Sharan Roongta
Max-Planck-Institut für Eisenforschung GmbH
Max-Planck-Straße 1
D-40237 Düsseldorf
Handelsregister B 2533
Amtsgericht Düsseldorf
Geschäftsführung
Prof. Dr. Gerhard Dehm
Prof. Dr. Jörg Neugebauer
Prof. Dr. Dierk Raabe
Dr. Kai de Weldige
Ust.-Id.-Nr.: DE 11 93 58 514
Steuernummer: 105 5891 1000
Please consider that invitations and e-mails of our institute are
only valid if they end with …@mpie.de.
If you are not sure of the validity please contact rco at mpie.de
Bitte beachten Sie, dass Einladungen zu Veranstaltungen und E-Mails
aus unserem Haus nur mit der Endung …@mpie.de gültig sind.
In Zweifelsfällen wenden Sie sich bitte an rco at mpie.de
Stay up to date and follow us on LinkedIn, Twitter and YouTube.
Max-Planck-Straße 1
D-40237 Düsseldorf
Geschäftsführung
Dr. Kai de Weldige
<cube_check.msh><cube_check.geo>
Canada Research Chair in Mathematical and Computational Aspects of Solid Mechanics (Tier 1)
Professor, Department of Mathematics & Statistics
Hamilton Hall room 409A, McMaster University
1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada
https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/
Max-Planck-Straße 1
D-40237 Düsseldorf
Geschäftsführung
Dr. Kai de Weldige
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231109/d299c004/attachment-0001.html>
