[petsc-users] Domain decomposition in PETSc for Molecular Dynamics
MIGUEL MOLINOS PEREZ
mmolinos at us.es
Sat Nov 4 09:50:44 CDT 2023
Thank you Mark! I will have a look to it.
Best,
Miguel
On 4 Nov 2023, at 13:54, Matthew Knepley <knepley at gmail.com> wrote:
On Sat, Nov 4, 2023 at 8:40 AM Mark Adams <mfadams at lbl.gov<mailto:mfadams at lbl.gov>> wrote:
Hi MIGUEL,
This might be a good place to start: https://petsc.org/main/manual/vec/
Feel free to ask more specific questions, but the docs are a good place to start.
On Fri, Nov 3, 2023 at 5:19 AM MIGUEL MOLINOS PEREZ <mmolinos at us.es<mailto:mmolinos at us.es>> wrote:
Dear all,
I am currently working on the development of a in-house molecular dynamics code using PETSc and C++. So far the code works great, however it is a little bit slow since I am not exploiting MPI for PETSc vectors. I was wondering if there is a way to perform the domain decomposition efficiently using some PETSc functionality. Any feedback is highly appreciated.
It sounds like you mean "is there a way to specify a communication construct that can send my particle
information automatically". We use PetscSF for that. You can see how this works with the DMSwarm class, which represents a particle discretization. You can either use that, or if it does not work for you, do the same things with your class.
Matt
Best regards,
Miguel
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231104/32054034/attachment-0001.html>
