[petsc-users] Fieldsplit on MATNEST
Matthew Knepley
knepley at gmail.com
Fri Nov 3 09:42:00 CDT 2023
On Wed, Nov 1, 2023 at 9:32 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Wed, Nov 1, 2023 at 3:59 PM Tang, Qi via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hi,
>> I have a block matrix with type of MATNEST, but can I call
>> -pc_fieldsplit_detect_saddle_point to change its IS? I assume it is not
>> possible.
> The detection part will work since MatGetDiagonal() is supported, but we
> do not have code in there
> to take arbitrary blocks from MATNEST since the whole point is to get
> no-copy access. Detection is
> not needed in the case that the blocks line up.
>> Also, I notice there is a small but important typo in the new fieldsplit
>> doc:
>> https://petsc.org/release/manualpages/PC/PCFIELDSPLIT/
>> The first matrix of the full factorization misses A10. I believe it
>> should be
>> [I -ksp(A00) A01]
>> [ I ]
> Yes, that is right.
Fixed: https://gitlab.com/petsc/petsc/-/merge_requests/6993
THanks,
Matt
> Thanks,
> Matt
>> Best,
>> Qi
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231103/af9fe235/attachment-0001.html>
