[petsc-users] error while compiling PETSc on windows using cygwin
Maruthi NH
maruthinh at gmail.com
Thu Nov 2 13:56:21 CDT 2023
Hi Barry,
Thanks for the suggestion. It worked after updating the compilers.
Maruthi
On Thu, 2 Nov 2023 at 9:33 PM, Barry Smith <bsmith at petsc.dev> wrote:
> It could be you would benefit from having the latest Microsoft compilers
> If you do not need C++ you could use --with-cxx=0
> Otherwise please send configure.log to petsc-maint at mcs.anl.gov
> > On Nov 2, 2023, at 11:20 AM, Maruthi NH <maruthinh at gmail.com> wrote:
> > Hi all,
> > I get the following error while trying to compile PETSc version 3.20.1
> on Windows
> > \petsc\include\petsc/private/cpp/unordered_map.hpp(309): error C2938:
> 'std::enable_if_t<false,void>' : Failed to specialize alias template
> > This is the configuration file I used to compile PETSc
> > #!/usr/bin/python
> > import os
> > petsc_hash_pkgs=os.path.join(os.getenv('HOME'),'petsc-hash-pkgs')
> > oadirf='"/cygdrive/c/Program Files (x86)/Intel/oneAPI"'
> > oadir=os.popen('cygpath -u '+os.popen('cygpath -ms
> '+oadirf).read()).read().strip()
> > oamkldir=oadir+'/mkl/2022.1.0/lib/intel64'
> > oampidir=oadir+'/mpi/2021.6.0'
> > if __name__ == '__main__':
> > import sys
> > import os
> > sys.path.insert(0, os.path.abspath('config'))
> > import configure
> > configure_options = [
> > '--package-prefix-hash='+petsc_hash_pkgs,
> > '--with-debugging=0',
> > '--with-shared-libraries=0',
> > '--with-blaslapack-lib=-L'+oamkldir+' mkl_intel_lp64_dll.lib
> mkl_sequential_dll.lib mkl_core_dll.lib',
> > '--with-cc=win32fe cl',
> > '--with-cxx=win32fe cl',
> > '--with-fc=win32fe ifort',
> > 'FOPTFLGS=-O3 -fp-model=precise',
> > '--with-mpi-include='+oampidir+'/include',
> > '--with-mpi-lib='+oampidir+'/lib/release/impi.lib',
> > '-with-mpiexec='+oampidir+'/bin/mpiexec -localonly',
> > configure.petsc_configure(configure_options)
> > Regards,
> > Maruthi
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231103/91468ae2/attachment.html>
