[petsc-users] Error using Metis with PETSc installed with MUMPS
Pierre Jolivet pierre at joliv.et
Thu Nov 2 11:35:00 CDT 2023
> On 2 Nov 2023, at 5:29 PM, Victoria Rolandi <victoria.rolandi93 at gmail.com> wrote:
> Pierre,
> Yes, sorry, I'll keep the list in copy.
> Launching with those options (-mat_mumps_icntl_28 2 -mat_mumps_icntl_29 2) I get an error during the analysis step. I also launched increasing the memory and I still have the error.
Oh, OK, that’s bad.
Would you be willing to give SCOTCH and/or PT-SCOTCH a try?
You’d need to reconfigure/recompile with --download-ptscotch (and maybe --download-bison depending on your system).
Then, the option would become either -mat_mumps_icntl_28 2 -mat_mumps_icntl_29 2 (PT-SCOTCH) or -mat_mumps_icntl_7 3 (SCOTCH).
It may be worth updating PETSc as well (you are using 3.17.0, we are at 3.20.1), though I’m not sure we updated the METIS/ParMETIS snapshots since then, so it may not fix the present issue.
Pierre
> The calculations stops at :
> Entering CMUMPS 5.4.1 from C interface with JOB, N =   1      699150
>       executing #MPI =      2, without OMP
>  MUMPS compiled with option -Dmetis
>  MUMPS compiled with option -Dparmetis
> L U Solver for unsymmetric matrices
> Type of parallelism: Working host
>  ****** ANALYSIS STEP ********
>  ** Maximum transversal (ICNTL(6)) not allowed because matrix is distributed
>  Using ParMETIS for parallel ordering
>  Structural symmetry is: 90%
> The error:
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see https://petsc.org/release/faq/#valgrind
> [0]PETSC ERROR: or try http://valgrind.org <http://valgrind.org/> on GNU/linux and Apple MacOS to find memory corruption errors
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See https://petsc.org/release/faq/ for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.17.0, unknown
> [0]PETSC ERROR: ./charlin.exe on a  named n1056 by vrolandi Wed Nov  1 11:38:28 2023
> [0]PETSC ERROR: Configure options --prefix=/u/home/v/vrolandi/CODES/LIBRARY/packages/petsc/installationDir --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort CXXOPTFLAGS=-O3 --with-scalar-type=complex --with-debugging=0 --with-precision=single --download-mumps --download-scalapack --download-parmetis --download-metis
> [0]PETSC ERROR: #1 User provided function() at unknown file:0
> [0]PETSC ERROR: Run with -malloc_debug to check if memory corruption is causing the crash.
> Abort(59) on node 0 (rank 0 in comm 0): application called MPI_Abort(MPI_COMM_WORLD, 59) - process 0
> Thanks,
> Victoria
> Il giorno mer 1 nov 2023 alle ore 10:33 Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> ha scritto:
>> Victoria, please keep the list in copy.
>>> I am not understanding how can I switch to ParMetis if it does not appear in the options of -mat_mumps_icntl_7.In the options I only have Metis and not ParMetis.
>> You need to use -mat_mumps_icntl_28 2 -mat_mumps_icntl_29 2
>> Barry, I don’t think we can programmatically shut off this warning, it’s guarded by a bunch of KEEP() values, see src/dana_driver.F:4707, which are only settable/gettable by people with access to consortium releases.
>> I’ll ask the MUMPS people for confirmation.
>> Note that this warning is only printed to screen with the option -mat_mumps_icntl_4 2 (or higher), so this won’t show up for standard runs.
>> Thanks,
>> Pierre
>>> On 1 Nov 2023, at 5:52 PM, Barry Smith <bsmith at petsc.dev <mailto:bsmith at petsc.dev>> wrote:
>>>   Pierre,
>>>    Could the PETSc MUMPS interface "turn-off" ICNTL(6) in this situation so as to not trigger the confusing warning message from MUMPS?
>>>   Barry
>>>> On Nov 1, 2023, at 12:17 PM, Pierre Jolivet <pierre at joliv.et <mailto:pierre at joliv.et>> wrote:
>>>>> On 1 Nov 2023, at 3:33 PM, Zhang, Hong via petsc-users <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>>>>> Victoria,
>>>>> "** Maximum transversal (ICNTL(6)) not allowed because matrix is distributed
>>>>> Ordering based on METIS"
>>>> This warning is benign and appears for every run using a sequential partitioner in MUMPS with a MATMPIAIJ.
>>>> (I’m not saying switching to ParMETIS will not make the issue go away)
>>>> Thanks,
>>>> Pierre
>>>> $ ../../../../arch-darwin-c-debug-real/bin/mpirun -n 2 ./ex2 -pc_type lu -mat_mumps_icntl_4 2
>>>> Entering DMUMPS 5.6.2 from C interface with JOB, N =   1          56
>>>>  MUMPS compiled with option -Dpord
>>>>  MUMPS compiled with option -Dptscotch
>>>>  MUMPS compiled with option -Dscotch
>>>>  Processing a graph of size:        56 with           194 edges
>>>>  Ordering based on AMF
>>>>  WARNING: Largest root node of size        26 not selected for parallel execution
>>>> Leaving analysis phase with  ...
>>>>  INFOG(1)                                       =               0
>>>>  INFOG(2)                                       =               0
>>>>> Try parmetis.
>>>>> Hong
>>>>> From: petsc-users <petsc-users-bounces at mcs.anl.gov <mailto:petsc-users-bounces at mcs.anl.gov>> on behalf of Victoria Rolandi <victoria.rolandi93 at gmail.com <mailto:victoria.rolandi93 at gmail.com>>
>>>>> Sent: Tuesday, October 31, 2023 10:30 PM
>>>>> To: petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>>
>>>>> Subject: [petsc-users] Error using Metis with PETSc installed with MUMPS
>>>>> Hi,
>>>>> I'm solving a large sparse linear system in parallel and I am using PETSc with MUMPS. I am trying to test different options, like the ordering of the matrix. Everything works if I use the -mat_mumps_icntl_7 2  or -mat_mumps_icntl_7 0 options (with the first one, AMF, performing better than AMD), however when I test METIS -mat_mumps_icntl_7 5 I get an error (reported at the end of the email).
>>>>> I have configured PETSc with the following options:
>>>>> --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort  --with-scalar-type=complex --with-debugging=0 --with-precision=single --download-mumps --download-scalapack --download-parmetis --download-metis
>>>>> and the installation didn't give any problems.
>>>>> Could you help me understand why metis is not working?
>>>>> Thank you in advance,
>>>>> Victoria
>>>>> Error:
>>>>>  Processing a graph of size:    699150 with      69238690 edges
>>>>> 510522 37081376 [100] [10486 699150]
>>>>> Error! Unknown CType: -1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231102/a8460671/attachment.html>
