[petsc-users] Error using Metis with PETSc installed with MUMPS
Pierre Jolivet
pierre at joliv.et
Wed Nov 1 11:17:59 CDT 2023
> On 1 Nov 2023, at 3:33 PM, Zhang, Hong via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Victoria,
> "** Maximum transversal (ICNTL(6)) not allowed because matrix is distributed
> Ordering based on METIS"
This warning is benign and appears for every run using a sequential partitioner in MUMPS with a MATMPIAIJ.
(I’m not saying switching to ParMETIS will not make the issue go away)
Pierre
$ ../../../../arch-darwin-c-debug-real/bin/mpirun -n 2 ./ex2 -pc_type lu -mat_mumps_icntl_4 2
Entering DMUMPS 5.6.2 from C interface with JOB, N = 1 56
executing #MPI = 2, without OMP
MUMPS compiled with option -Dmetis
MUMPS compiled with option -Dparmetis
MUMPS compiled with option -Dpord
MUMPS compiled with option -Dptscotch
MUMPS compiled with option -Dscotch
L U Solver for unsymmetric matrices
Type of parallelism: Working host
****** ANALYSIS STEP ********
Processing a graph of size: 56 with 194 edges
Ordering based on AMF
WARNING: Largest root node of size 26 not selected for parallel execution
Leaving analysis phase with ...
INFOG(1) = 0
INFOG(2) = 0
> Try parmetis.
> Hong
> From: petsc-users <petsc-users-bounces at mcs.anl.gov> on behalf of Victoria Rolandi <victoria.rolandi93 at gmail.com>
> Sent: Tuesday, October 31, 2023 10:30 PM
> To: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> Subject: [petsc-users] Error using Metis with PETSc installed with MUMPS
> Hi,
> I'm solving a large sparse linear system in parallel and I am using PETSc with MUMPS. I am trying to test different options, like the ordering of the matrix. Everything works if I use the -mat_mumps_icntl_7 2 or -mat_mumps_icntl_7 0 options (with the first one, AMF, performing better than AMD), however when I test METIS -mat_mumps_icntl_7 5 I get an error (reported at the end of the email).
> I have configured PETSc with the following options:
> --with-cc=mpiicc --with-cxx=mpiicpc --with-fc=mpiifort --with-scalar-type=complex --with-debugging=0 --with-precision=single --download-mumps --download-scalapack --download-parmetis --download-metis
> and the installation didn't give any problems.
> Could you help me understand why metis is not working?
> Thank you in advance,
> Victoria
> Error:
> Processing a graph of size: 699150 with 69238690 edges
> 510522 37081376 [100] [10486 699150]
> Error! Unknown CType: -1
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20231101/3bea3a36/attachment-0001.html>
