[petsc-users] GAMG failure
Mark Adams mfadams at lbl.gov
Fri Mar 24 14:21:08 CDT 2023
* Do you set:
    PetscCall(MatSetOption(Amat, MAT_SPD, PETSC_TRUE));
    PetscCall(MatSetOption(Amat, MAT_SPD_ETERNAL, PETSC_TRUE));
Do that to get CG Eigen estimates. Outright failure is usually caused by a
bad Eigen estimate.
-pc_gamg_esteig_ksp_monitor_singular_value
Will print out the estimates as its iterating. You can look at that to
check that the max has converged.
*  -pc_gamg_aggressive_coarsening 0
will slow coarsening as well as threshold.
* you can run with '-info :pc' and send me the output (grep on GAMG)
On Fri, Mar 24, 2023 at 2:47 PM Jed Brown <jed at jedbrown.org> wrote:
> You can -pc_gamg_threshold .02 to slow the coarsening and either stronger
> smoother or increase number of iterations used for estimation (or increase
> tolerance). I assume your system is SPD and you've set the near-null space.
> Blaise Bourdin <bourdin at mcmaster.ca> writes:
> > Hi,
> > I am having issue with GAMG for some very ill-conditioned 2D linearized
> elasticity problems (sharp variation of elastic moduli with thin  regions
> of nearly incompressible material). I use snes_type newtonls,
> linesearch_type cp, and pc_type gamg without any further options. pc_type
> Jacobi converges fine (although slowly of course).
> > I am not really surprised that gamg would not converge out of the box,
> but don’t know where to start to investigate the convergence failure. Can
> anybody help?
> > Blaise
> > Canada Research Chair in Mathematical and Computational Aspects of Solid
> Mechanics (Tier 1)
> > Professor, Department of Mathematics & Statistics
> > Hamilton Hall room 409A, McMaster University
> > 1280 Main Street West, Hamilton, Ontario L8S 4K1, Canada
> > https://www.math.mcmaster.ca/bourdin | +1 (905) 525 9140 ext. 27243
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230324/402e82e9/attachment.html>
