[petsc-users] `snes+ksponly` did not update the solution when ksp failed.
Zongze Yang yangzongze at gmail.com
Mon Mar 20 07:59:56 CDT 2023
Thank you for your clarification.
Best wishes,
Zongze
On Mon, 20 Mar 2023 at 20:00, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Mar 20, 2023 at 2:41 AM Zongze Yang <yangzongze at gmail.com> wrote:
>> Hi,
>> Hope this email finds you well. I am using firedrake to solve linear
>> problems, which use SNES with KSPONLY.
>> I found that the solution did not update when the `ksp` failed with DIVERGED_ITS.
>> The macro `SNESCheckKSPSolve` called in `SNESSolve_KSPONLY` make it
>> return before the solution is updated.
> Yes, this is the intended behavior. We do not guarantee cleanup on errors.
>> Is this behavior as expected? Can I just increase the value of `maxLinearSolveFailures`
>> to make the solution updated without introducing other side effects?
> Yes, that is right. It will not have other side effects with this SNES
> type.
>   Thanks,
>      Matt
>> Best wishes,
>> Zongze
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230320/635d8846/attachment.html>
