[petsc-users] PETSc build asks for network connections
Amneet Bhalla mail2amneet at gmail.com
Sun Mar 19 12:59:10 CDT 2023
I'm building PETSc without mpi (I built mpich v 4.1.1 locally). Here is the
configure command line that I used:
./configure --CC=mpicc --CXX=mpicxx --FC=mpif90 --PETSC_ARCH=darwin-dbg
--with-debugging=1 --download-hypre=1 --with-x=0
On Sun, Mar 19, 2023 at 10:56 AM Satish Balay <balay at mcs.anl.gov> wrote:
> I think its due to some of the system calls from MPI.
> You can verify this with a '--with-mpi=0' build.
> I wonder if there is a way to build mpich or openmpi - that doesn't
> trigger Apple's firewall..
> Satish
> On Sun, 19 Mar 2023, Amneet Bhalla wrote:
> > Hi Folks,
> > I'm trying to build PETSc on MacOS Ventura (Apple M2) with hypre. I'm
> using
> > the latest version (v3.18.5). During the configure and make check stage I
> > get a request about accepting network connections. The configure and
> check
> > proceeds without my input but the dialog box stays in place. Please see
> the
> > screenshot. I'm wondering if it is benign or something to be concerned
> > about? Do I need to accept any network certificate to not see this dialog
> > box?
> > Thanks,
--Amneet
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230319/9d851a06/attachment.html>
