[petsc-users] Question about MatView
user_gong Kim ksi2443 at gmail.com
Fri Mar 17 10:05:49 CDT 2023
PETSC_COMM_SELF generates an error in more than 2 processes.
I would like to use the other method you said, matcreateredundantmatrix.
However, there is no example in the manual. Can you give an example using
this function?
2023년 3월 17일 (금) 오후 11:53, Barry Smith <bsmith at petsc.dev>님이 작성:
>    Use
> MatCreate(PETSC_COMM_SELF, &mat);
>>  PetscViewerBinaryOpen(PETSC_COMM_SELF, "mat.bin", FILE_MODE_READ,
>> &viewer);
>     If it one program running that both views and loads the matrix you can
> use MatCreateRedundantMatrix() to reproduce the entire matrix on each MPI
> rank. It is better than using the filesystem to do it.
> On Mar 17, 2023, at 9:45 AM, user_gong Kim <ksi2443 at gmail.com> wrote:
> Following your comments,  I did an test.
> However, if I run the application in parallel.
> In all processes, it is not possible to obtain values at all positions in
> the matrix through MatGetValue.
> As in the previous case of saving in binary, it is read in parallel
> divided form.
> Is it impossible to want to get the all value in the whole process?
> Thanks,
> Hyung Kim
> 2023년 3월 17일 (금) 오후 7:35, Matthew Knepley <knepley at gmail.com>님이 작성:
>> On Fri, Mar 17, 2023 at 5:51 AM user_gong Kim <ksi2443 at gmail.com> wrote:
>>> Hello,
>>> I have 2 questions about MatView.
>>> 1.    I would like to ask if the process below is possible.
>>> When running in parallel, is it possible to make the matrix of the
>>> mpiaij format into a txt file, output it, and read it again so that the
>>> entire process has the same matrix?
>> No. However, you can do this with a binary viewer. I suggest using
>>   MatViewFromOptions(mat, NULL, "-my_view");
>> and then the command line argument
>>   -my_view binary:mat.bin
>> and then you can read this in using
>>   MatCreate(PETSC_COMM_WORLD, &mat);
>>   PetscViewerBinaryOpen(PETSC_COMM_WORLD, "mat.bin", FILE_MODE_READ,
>> &viewer);
>>   MatLoad(mat, viewer);
>>   ViewerDestroy(&viewer);
>>   THanks,
>>      Matt
>>> 2.    If possible, please let me know which function can be used to
>>> create a txt file and how to read the txt file.
>>> Thanks,
>>> Hyung Kim
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230318/e93409d1/attachment-0001.html>
