[petsc-users] Question about MatView
user_gong Kim
ksi2443 at gmail.com
Fri Mar 17 08:45:44 CDT 2023
Following your comments, I did an test.
However, if I run the application in parallel.
In all processes, it is not possible to obtain values at all positions in
the matrix through MatGetValue.
As in the previous case of saving in binary, it is read in parallel divided
form.
Is it impossible to want to get the all value in the whole process?
Hyung Kim
2023년 3월 17일 (금) 오후 7:35, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Fri, Mar 17, 2023 at 5:51 AM user_gong Kim <ksi2443 at gmail.com> wrote:
>> Hello,
>> I have 2 questions about MatView.
>> 1. I would like to ask if the process below is possible.
>> When running in parallel, is it possible to make the matrix of the mpiaij
>> format into a txt file, output it, and read it again so that the entire
>> process has the same matrix?
> No. However, you can do this with a binary viewer. I suggest using
> MatViewFromOptions(mat, NULL, "-my_view");
> and then the command line argument
> -my_view binary:mat.bin
> and then you can read this in using
> MatCreate(PETSC_COMM_WORLD, &mat);
> PetscViewerBinaryOpen(PETSC_COMM_WORLD, "mat.bin", FILE_MODE_READ,
> &viewer);
> MatLoad(mat, viewer);
> ViewerDestroy(&viewer);
> THanks,
> Matt
>> 2. If possible, please let me know which function can be used to
>> create a txt file and how to read the txt file.
>> Thanks,
>> Hyung Kim
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230317/b1c5f1e3/attachment-0001.html>
