[petsc-users] Question about time issues in parallel computing
    권승리 / 학생 / 항공우주공학과
    ksl7912 at snu.ac.kr
    Wed Mar 15 20:08:50 CDT 2023
Thank you for your reply.
It was a simple problem, but it has more than 1000 degrees of freedom.
Is this not enough to check speedup?
Best regards
Seung Lee Kwon
2023년 3월 15일 (수) 오후 8:50, Matthew Knepley <knepley at gmail.com>님이 작성:
> On Wed, Mar 15, 2023 at 3:38 AM 권승리 / 학생 / 항공우주공학과 <ksl7912 at snu.ac.kr>
> wrote:
>> Dear petsc developers.
>> Hello.
>> I am trying to solve the structural problem with FEM and test parallel
>> computing works well.
>> However, even if I change the number of cores, the total time is
>> calculated the same.
>> I have tested on a simple problem using a MUMPS solver using:
>> mpiexec -n 1
>> mpiexec -n 2
>> mpiexec -n 4
>> Could you give me some advice if you have experienced this problem?
> If your problem is small, you could very well see no speedup:
> https://petsc.org/main/faq/#what-kind-of-parallel-computers-or-clusters-are-needed-to-use-petsc-or-why-do-i-get-little-speedup
>   Thanks,
>      Matt
>> Best regards
>> Seung Lee Kwon
>> Seung Lee Kwon, Ph.D.Candidate
>> Aerospace Structures and Materials Laboratory
>> Department of Mechanical and Aerospace Engineering
>> Seoul National University
>> Building 300 Rm 503, Gwanak-ro 1, Gwanak-gu, Seoul, South Korea, 08826
>> E-mail : ksl7912 at snu.ac.kr
>> Office : +82-2-880-7389
>> C. P : +82-10-4695-1062
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230316/fd4f4b9e/attachment.html>
