[petsc-users] Memory Usage in Matrix Assembly.
Wed Mar 15 06:07:51 CDT 2023
On Wed, Mar 15, 2023 at 2:34 AM Pantelis Moschopoulos <
pmoschopoulos at outlook.com> wrote:
> Dear all,
> Thank you all very much for your suggestions.
> Dave, I am using also the reverse Cuthill–McKee algorithm when I load the
> mesh information and then the simulation proceeds. I can use partitioning
> after the reordering right?
Yes.
> Matt, with PLEX you refer to DMPLEX? To be honest, I have never tried the
> DM structures of Petsc up to this point.
Yes. It can read a variety of mesh formats, but if everything is working,
there is no need to switch.
  Thanks
    Matt
> Pantelis
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Tuesday, March 14, 2023 10:55 PM
> *To:* Dave May <dave.mayhem23 at gmail.com>
> *Cc:* Pantelis Moschopoulos <pmoschopoulos at outlook.com>;
> petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> *Subject:* Re: [petsc-users] Memory Usage in Matrix Assembly.
> On Tue, Mar 14, 2023 at 12:01 PM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Tue, 14 Mar 2023 at 07:59, Pantelis Moschopoulos <
> Dear Dave,
> Yes, I observe this in parallel runs. How I can change the parallel layout
> of the matrix? In my implementation, I read the mesh file, and the I split
> the domain where the first rank gets the first N elements, the second rank
> gets the next N elements etc. Should I use metis to distribute elements?
> Note that I use continuous finite elements, which means that some values
> will be cached in a temporary buffer.
> Sure. With CG FE you will always have some DOFs which need to be cached,
> however the number of cached values will be minimized if you follow Barry's
> advice. If you do what Barry suggests, only the DOFs which live on the
> boundary of your element-wise defined sub-domains would need to cached.
> Note that we have direct support for unstructured meshes (Plex) with
> partitioning and redistribution, rather than translating them to purely
> algebraic language.
>   Thanks,
>      Matt
> Thanks,
> Dave
> Thank you very much,
> Pantelis
> *From:* Dave May <dave.mayhem23 at gmail.com>
> *Sent:* Tuesday, March 14, 2023 4:40 PM
> *To:* Pantelis Moschopoulos <pmoschopoulos at outlook.com>
> *Cc:* petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
> On Tue 14. Mar 2023 at 07:15, Pantelis Moschopoulos <
> Hi everyone,
> I am a new Petsc user that incorporates Petsc for FEM in a Fortran code.
> My question concerns the sudden increase of the memory that Petsc needs
> during the assembly of the jacobian matrix. After this point, memory is
> freed. It seems to me like Petsc performs memory allocations and the
> deallocations during assembly.
> I have used the following commands with no success:
> CALL MatSetOption(petsc_A, MAT_NEW_NONZERO_LOCATIONS,PETSC_FALSE,ier)
> CALL MatSetOption(petsc_A, MAT_NEW_NONZERO_LOCATION_ERR,PETSC_TRUE,ier)
> CALL MatSetOption(petsc_A, MAT_NEW_NONZERO_ALLOCATION_ERR, PETSC_TRUE,ier).
> CALL MatSetOption(petsc_A, MAT_KEEP_NONZERO_PATTERN,PETSC_TRUE,ier)
> The structure of the matrix does not change during my simulation, just the
> values. I am expecting this behavior the first time that I create this
> matrix because the preallocation instructions that I use are not very
> accurate but this continues every time I assemble the matrix.
> What I am missing here?
> I am guessing this observation is seen when you run a parallel job.
> MatSetValues() will cache values in a temporary memory buffer if the
> values are to be sent to a different MPI rank.
> Hence if the parallel layout of your matrix doesn’t closely match the
> layout of the DOFs on each mesh sub-domain, then a huge number of values
> can potentially be cached. After you call MatAssemblyBegin(),
> MatAssemblyEnd() this cache will be freed.
> Thanks,
> Dave
> Pantelis
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230315/c537a94f/attachment.html>
