[petsc-users] Error in configuring PETSc with Cygwin
冯上玮 fengshw3 at mail2.sysu.edu.cn
Thu Mar 2 11:43:16 CST 2023
Hi team,
Recently I try to install PETSc with Cygwin since I'd like to use PETSc with Visual Studio on Windows10 plateform. For the sake of clarity, I firstly list the softwares/packages used below:
1. PETSc: version 3.18.5
2. VS: version 2019
3. Intel Parallel Studio XE: version 2020
4. Cygwin with py3.8 and make (and default installation)
And because I plan to use Intel mpi, the compiler option in configuration is:
./configure --with-cc='win32fe cl' --with-fc='win32fe ifort' --with-cxx='win32fe cl' --download-fblaslapack
where there is no option for mpi.
While the PROBLEM came with the compiler option --with-fc='win32fe ifort', which returned an error (or two) as:
Cannot run executables created with FC. If this machine uses a batch system
to submit jobs you will need to configure using ./configure with the additional option  --with-batch.
Otherwise there is problem with the compilers. Can you compile and run code with your compiler '/cygdrive/d/petsc/petsc-3.18.5/lib/petsc/bin/win32fe/win32fe ifort'?
Note that both ifort of x64 and ifort of ia-32 ended with the same error above and I install IPS with options related to mkl and fblaslapack. Something a bit suspectable is that I open Cygwin with dos. (actually the Intel Compiler 19.1 Update 3 Intel 64 Visual Studio 2019, x86 environment for the test of ifort ia-32 ,in particularlly)
Therefore, I write this e-mail to you in order to confirm if I should add "--with-batch" or the error is caused by other reason, such as ifort ?
Looking forward your reply!
Sinserely,
FENG.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230303/32c7cd7e/attachment.html>
