[petsc-users] Using PETSc GPU backend
Ng, Cho-Kuen cho at slac.stanford.edu
Fri Jun 30 10:00:31 CDT 2023
Paul,
Thank you for your suggestion. I will try different spack install specifications.
Cho
From: Grosse-Bley, Paul Leonard <paul.grosse-bley at stud.uni-heidelberg.de>
Sent: Friday, June 30, 2023 4:07 AM
To: Ng, Cho-Kuen <cho at slac.stanford.edu>
Cc: petsc-users at mcs.anl.gov <petsc-users at mcs.anl.gov>
Subject: Re: [petsc-users] Using PETSc GPU backend
Hi Cho,
you might want to specify the GPU architecture to make sure that everything is compiled optimally.
I.e. "spack install petsc +cuda cuda_arch=80 +zoltan"
Best,
Paul
On Friday, June 30, 2023 01:50 CEST, petsc-users-request at mcs.anl.gov wrote:
Date: Thu, 29 Jun 2023 23:50:10 +0000
To: "petsc-users at mcs.anl.gov" <petsc-users at mcs.anl.gov>
Subject: [petsc-users] Using PETSc GPU backend
Message-ID:
<BYAPR07MB5431A3DACC91A963572D66E4E025A at BYAPR07MB5431.namprd07.prod.outlook.com>
Content-Type: text/plain; charset="iso-8859-1"
I installed PETSc on Perlmutter using "spack install petsc+cuda+zoltan" and used it by "spack load petsc/fwge6pf". Then I compiled the application code (purely CPU code) linking to the petsc package, hoping that I can get performance improvement using the petsc GPU backend. However, the timing was the same using the same number of MPI tasks with and without GPU accelerators. Have I missed something in the process, for example, setting up PETSc options at runtime to use the GPU backend?
Cho
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230630/0a517ccc/attachment-0001.html>
