[petsc-users] Scalable Solver for Incompressible Flow
    Alexander Lindsay
    alexlindsay239 at gmail.com
    Wed Jun 28 13:37:48 CDT 2023
I do believe that based off the results in https://doi.org/10.1137/040608817 we
should be able to make LSC, with proper scaling, compare very favorably
with PCD
On Tue, Jun 27, 2023 at 10:41 AM Alexander Lindsay <alexlindsay239 at gmail.com>
wrote:
> I've opened https://gitlab.com/petsc/petsc/-/merge_requests/6642 which
> adds a couple more scaling applications of the inverse of the diagonal of A
> On Mon, Jun 26, 2023 at 6:06 PM Alexander Lindsay <
> alexlindsay239 at gmail.com> wrote:
>> I guess that similar to the discussions about selfp, the approximation of
>> the velocity mass matrix by the diagonal of the velocity sub-matrix will
>> improve when running a transient as opposed to a steady calculation,
>> especially if the time derivative is lumped.... Just thinking while typing
>> On Mon, Jun 26, 2023 at 6:03 PM Alexander Lindsay <
>>> Returning to Sebastian's question about the correctness of the current
>>> LSC implementation: in the taxonomy paper that Jed linked to (which talks
>>> about SIMPLE, PCD, and LSC), equation 21 shows four applications of the
>>> inverse of the velocity mass matrix. In the PETSc implementation there are
>>> at most two applications of the reciprocal of the diagonal of A (an
>>> approximation to the velocity mass matrix without more plumbing, as already
>>> pointed out). It seems like for code implementations in which there are
>>> possible scaling differences between the velocity and pressure equations,
>>> that this difference in the number of inverse applications could be
>>> significant? I know Jed said that these scalings wouldn't really matter if
>>> you have a uniform grid, but I'm not 100% convinced yet.
>>> I might try fiddling around with adding two more reciprocal applications.
>>> On Fri, Jun 23, 2023 at 1:09 PM Pierre Jolivet <pierre.jolivet at lip6.fr>
>>> wrote:
>>>> On 23 Jun 2023, at 10:06 PM, Pierre Jolivet <pierre.jolivet at lip6.fr>
>>>> wrote:
>>>> On 23 Jun 2023, at 9:39 PM, Alexander Lindsay <alexlindsay239 at gmail.com>
>>>> wrote:
>>>> Ah, I see that if I use Pierre's new 'full' option for
>>>> -mat_schur_complement_ainv_type
>>>> That was not initially done by me
>>>> Oops, sorry for the noise, looks like it was done by me indeed
>>>> in 9399e4fd88c6621aad8fe9558ce84df37bd6fada…
>>>> Thanks,
>>>> Pierre
>>>> (though I recently tweaked MatSchurComplementComputeExplicitOperator()
>>>> a bit to use KSPMatSolve(), so that if you have a small Schur complement —
>>>> which is not really the case for NS — this could be a viable option, it was
>>>> previously painfully slow).
>>>> Thanks,
>>>> Pierre
>>>> that I get a single iteration for the Schur complement solve with LU.
>>>> That's a nice testing option
>>>> On Fri, Jun 23, 2023 at 12:02 PM Alexander Lindsay <
>>>>> I guess it is because the inverse of the diagonal form of A00 becomes
>>>>> a poor representation of the inverse of A00? I guess naively I would have
>>>>> thought that the blockdiag form of A00 is A00
>>>>> On Fri, Jun 23, 2023 at 10:18 AM Alexander Lindsay <
>>>>>> Hi Jed, I will come back with answers to all of your questions at
>>>>>> some point. I mostly just deal with MOOSE users who come to me and tell me
>>>>>> their solve is converging slowly, asking me how to fix it. So I generally
>>>>>> assume they have built an appropriate mesh and problem size for the problem
>>>>>> they want to solve and added appropriate turbulence modeling (although my
>>>>>> general assumption is often violated).
>>>>>> > And to confirm, are you doing a nonlinearly implicit
>>>>>> velocity-pressure solve?
>>>>>> Yes, this is our default.
>>>>>> A general question: it seems that it is well known that the quality
>>>>>> of selfp degrades with increasing advection. Why is that?
>>>>>> On Wed, Jun 7, 2023 at 8:01 PM Jed Brown <jed at jedbrown.org> wrote:
>>>>>>> Alexander Lindsay <alexlindsay239 at gmail.com> writes:
>>>>>>> > This has been a great discussion to follow. Regarding
>>>>>>> >> when time stepping, you have enough mass matrix that cheaper
>>>>>>> preconditioners are good enough
>>>>>>> > I'm curious what some algebraic recommendations might be for high
>>>>>>> Re in
>>>>>>> > transients.
>>>>>>> What mesh aspect ratio and streamline CFL number? Assuming your
>>>>>>> model is turbulent, can you say anything about momentum thickness Reynolds
>>>>>>> number Re_θ? What is your wall normal spacing in plus units? (Wall resolved
>>>>>>> or wall modeled?)
>>>>>>> > I've found one-level DD to be ineffective when applied
>>>>>>> monolithically or to the momentum block of a split, as it scales with the
>>>>>>> mesh size.
>>>>>>> I wouldn't put too much weight on "scaling with mesh size" per se.
>>>>>>> You want an efficient solver for the coarsest mesh that delivers sufficient
>>>>>>> accuracy in your flow regime. Constants matter.
>>>>>>> Refining the mesh while holding time steps constant changes the
>>>>>>> advective CFL number as well as cell Peclet/cell Reynolds numbers. A
>>>>>>> meaningful scaling study is to increase Reynolds number (e.g., by growing
>>>>>>> the domain) while keeping mesh size matched in terms of plus units in the
>>>>>>> viscous sublayer and Kolmogorov length in the outer boundary layer. That
>>>>>>> turns out to not be a very automatic study to do, but it's what matters and
>>>>>>> you can spend a lot of time chasing ghosts with naive scaling studies.
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230628/7d20e136/attachment.html>
