[petsc-users] Problem in some macro when using VS+intel cl
    Matthew Knepley
    knepley at gmail.com
    Tue Jun 27 12:59:09 CDT 2023
On Tue, Jun 27, 2023 at 11:32 AM 冯上玮 <fengshw3 at mail2.sysu.edu.cn> wrote:
> Hi,
> After failure with MS-MPI once and once again, I tried icl+oneAPI and
> succeeded in installing and testing PESTc in Cygwin!
> However, (always however) when I copied the example code on Getting
> Started page on visual studio, there are tons of error like:
> I just wonder where the problem locates, I've googled this error message
> and it seems that it's induced by the difference of compilers, c.f.
> https://stackoverflow.com/questions/42136395/identifier-builtin-expect-is-undefined-during-ros-on-win-tutorial-talker-ex.
> But Intel says that they also provide such thing on icl, and I actually use
> this compiler instead of visual studio cl...
The IDE is not showing the actual error message. Are you sure that your IDE
build has the right includes and libraries? You can
get these using
  cd $PETSC_DIR
  make getincludedirs
  make getlinklibs
     Matt
> Anyway, the project could be built if I delete these error-checking macro.
> Installing feedback (or as a test result):
> When configure on windows, only icl + impi works, and in this case, both
> --with-cc and --with-cxx options need to point out the version like:
> --with-cc-std-c99 and --with-cxx-std-c++'ver'. Other combinations such as
> cl + impi, icl + msmpi, cl + msmpi never work. My tutor told me that older
> version of msmpi may work but I never try this.
> FENG.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230627/cbe43869/attachment-0001.html>
Name: 724CED62 at D9B26517.FA009B6400000000.jpg
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230627/cbe43869/attachment-0001.jpg>
