[petsc-users] GAMG and Hypre preconditioner
Zisheng Ye
zisheng.ye at ansys.com
Tue Jun 27 10:50:30 CDT 2023
Dear PETSc Team
We are testing the GPU support in PETSc's KSPSolve, especially for the GAMG and Hypre preconditioners. We have encountered several issues that we would like to ask for your suggestions.
First, we have couple of questions when working with a single MPI rank:
1. We have tested two backends, CUDA and Kokkos. One commonly encountered error is related to SpGEMM in CUDA when the mat is large as listed below:
cudaMalloc((void **)&buffer2, bufferSize2) error( cudaErrorMemoryAllocation): out of memory
For CUDA backend, one can use "-matmatmult_backend_cpu -matptap_backend_cpu" to avoid these problems. However, there seems no equivalent options in Kokkos backend. Is there any good practice to avoid this error for both backends and if we can avoid this error in Kokkos backend?
2. We have tested the combination of Hypre and Kokkos as backend. It looks like this combination is not compatible with each other, as we observed that KSPSolve takes a greater number of iterations to exit, and the residual norm in the post-checking is much larger than the one obtained when working with CUDA backend. This happens for matrices with block size larger than 1. Is there any explanation to the error?
Second, we have couple more questions when working with multiple MPI ranks:
1. We are currently using OpenMPI as we couldnt get Intel MPI to work as a GPU-aware MPI, is this a known issue with Intel MPI?
2. With OpenMPI we currently see a slow down when increasing the MPI count as shown in the figure below, is this normal?
[cid:9242808d-34af-4b51-8a0b-8295f0a012e5]
Zisheng
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230627/819ace5e/attachment-0001.html>
Type: image/png
Desc: image.png
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20230627/819ace5e/attachment-0001.png>
